Question about Homelite Garden
I'm needing to find out the spark plug gap fo a homelite lil red xl hp 2010241 ut-10741. Can you help? Thanks
    Loyalty:
    Visited the website for 30 consecutive days.
  • 704 Answers
  • terri
    terri Jan 03, 2018
    Thank you obsteiner for supplying the answer to my question to use 0.025 gap.
  • obsteiner Jan 03, 2018
    You are welcome. Spark plug gaps are not super critical. Too narrow is worse than too wide. Small engines are very forgiving and will run with a lot of things way out of spec.
    Thanks for the feedback.
5 Suggested Answers
  • 4088 Answers
SOURCE: homelite ut 10695 spark plug
Gap the plug at 0.020", and the fuel to oil ratio is 50:1. Be sure to use a modern synthetic saw oil, fresh fuel, and mix in it's own container (don't make up more than a gallon at a time unless your business is sawing). Be sure to shake the container thoroughly each time just before adding fuel mix to the tank to prevent oil starvation. Hope this helps!
Posted on Nov 04, 2010
SOURCE: Primer bulb is part of the fuel cap.
I have a Homelite Super 2 chainsaw that has a hole in the primer bulb on the fuel cap...will not prime. Where can
I find a replacement primer bulb fuel cap?
Posted on Jul 02, 2011
  • 123 Answers
SOURCE: need to know the spark
The spark plug gap should be set at .025 to .030 inches for trimmers. Try to set gap closer to .025.
Posted on Aug 04, 2011
hunter19_46m
  • 7482 Answers
SOURCE: spark plug gap for homelite
Hi idone8...
Set your gap using a round feeler gauge to .28 to .32
Please take time to rate me
Posted on Sep 08, 2011
Homelite chainsaw ut 10516 won't start have replaced all electrical parts still no spark why?
Incorrect gap on ignition coil? On/off switch stuck in closed position and grounding out spark?
Mar 30, 2017 | Homelite Garden
Spark plug gap for homelite textron ut 10080c chain saw
Hi idone8...
Sep 08, 2011 | Garden
Need to know the spark plug gap for Homelite 25cc Model UT-20779
Aug 04, 2011 | Homelite Curved Shaft Trimmer Bump Feed...
I have an old homelite super xl saw and what i need to know is the high and low adjustments as well as spark plug gap
For the high and low speed jets turn all the way in and turn counter clockwise 1 1/4 turns to start with and continue a bit more until the saw runs a max speed(go by ear) and idling speed(idle down enough so chain does not spin while finger off triger). For the spark plug gap, go about 20 thousands of an inch. I hope this helps you out.
Jul 15, 2011 | Homelite Garden
Homelite ut 10695 spark plug gap, gas oil ratio?
Nov 04, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
NEED TO REPLACE SPARK ARRESTER ON HOMELITE LITE 26CC STRING TRIMMER
Remove the Torx screws holding the rear cover on. Then remove the larger Torx screws holding the muffler on to the exhaust port of the cylinder. There will be a gasket there. The spark arrestor will be mounted in the opening to the muffler. You can scrape or burn the carbon off of it. If the spark arrestor is real clogged up, then the muffler probably is too. It should also be cleaned. The inside of the engine probably is carboned up too( if arrestor and muffler are). They all should be cleaned of carbon. It helps the engine perform at its' best and breathe like it needs to.
Oct 15, 2010 | Homelite Mighty Lite Lawn Trimmer
No spark superxl ut-10045-c
The following are givens:
1. You replaced the spark plug with a known good one and the malfunction persisted.
2. You did something similar to the following in an attempt to isolate defective parts and you concluded the ignition is not producing spark.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
I found your saw "SXLO Chain Saw UT-10045-C" by following the instructions here:
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
Both the solid state ignition and condenser (most likely failures, but no promises) are NLA at the authorized site, part numbers are still valid. An Internet search for "Homelite YourPartNumber" displays many sources other than eBay.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 03, 2010 | Homelite Garden
Jun 24, 2009 | Garden
Garden Logo
27 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
