Question about Car Audio & Video
Have a vauxhall corsa n reg with a blaupunkt 300 radio at the moment when the radio is turned on it says safe does anyone know the code. numbers i have found on the radio are 90532620 type car 300 d 2fd thank you
    Sergeant:
  • 436 Answers
You need to hold down the as button then switch the radio on, if this dont work then leave radio on for an hour or two then try again.
Posted on Jul 30, 2009
I don't have the code to get my 2001 Vauxhall corsas radio out of safe mode as the car was second hand can you help
Hello if u go to Vauxhall dealership with ur vin number and u are the registered keeper they will give u the code for that car radio
Oct 21, 2013 | Vauxhall Cars & Trucks
I have a vauxhall corsa k reg, radio code serial number is GM020521510634 can anyone help with the safe code ??
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Vauxhall service centre and get them to enter this code for you.
Jan 09, 2013 | Car Audio & Video
I had a new battery fitted to my T Reg Vauxhall Corsa Breeze. The radio which is a Phillips CAR 400 does not now work and when switched on it says 'SAFE'.
SAFE means wrong codes have been entered previously
To reset, leave SWITCHED ON...UNDISTURBED for an hour or more
Make sure you have the correct code.
If not sure post the 14 character Serial Number beginning with GM0400******** found stamped in the metal casing
Feb 02, 2011 | Car Audio & Video
How can i reset car radio blaupunkt 300 rds vauxhall astra it is set to safe
Switch on using the ON and AS buttons pressed together
Then LEAVE SWITCHED ON ...UNDISTURBED for as long as it takes to automatically reset itself
Once reset , enter the correct code
Press AS and your radio should work
Jan 20, 2011 | Blaupunkt Chicago IVDM-7002 Radio/CD/DVD...
How do I input in my radio code for Blaupunkt 2003 vauxhall corsa, if my code was 1742 and I can only use buttons 1, 2, 3 or 4 to use.
Blaupunkt CAR2003 Vauxhall Code Entry
The [ AS ] key must be held in while switching on the set. The set should then display 'SAFE' briefly followed by '10 - - - -'.
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the fourth digit
Press the [ AS ] key to accept. The set will now operate.
blank.gif _uacct = "UA-277454-2"; urchinTracker();
Apr 11, 2010 | Car Audio & Video
Changed battery and radio now in safe mode.dont have code.its a blaupunkt 300 fitted in a corsa.
It is in SAFE mode because of wrong codes being entered.
To restore from SAFE  Press the ON BUTTON and the AS BUTTON (at the same time)and leave SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself.
If you require the code then post another question quoting the 14 character Serial Number found STAMPED IN THE METAL CASING.
It normally begins with either BP or GM ************
Sep 10, 2009 | Car Audio & Video
Need blaupunkt car 2003 code but no serial number
hi,
I need a code for a Blaupunkt Car 2003 (F) radio (Opel Corsa C)
7 649 200 321
GM0203Y7436861
Can anybody help me with a code?
Many thanks!
my email: robertasmaskvytis@yahoo.com
Apr 04, 2009 | Car Audio & Video
Radio code for vauxhall corsa
The units anti-theft program was activated when the battery was disconnected. If you don't know the 4 digit code, try to contact the previous owner or most higher end car audio dealer/installers will offer a service to reset the anti-theft code program, for a fee.
Aduz
Mar 25, 2009 | Car Audio & Video
Blaupunkt 300 f
Hi does it just show SAFE or a number then SAFE?
ie: 6 SAFE
if it does show a number first this is the attempts that you have left to enter the code.
double check that you are getting the ignition voltage to the radio. other than that, you may have a faulty unit.#
Mark
Mar 05, 2008 | Car Audio & Video
Car Audio & Video Logo
399 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
