Question about Janome Sewing Machines
How do I replace a broken bobbin winder on janome JP760?
  • Janome Master
  • 12,731 Answers
For ~$30, you can buy a standalone bobbin winder (Sidewinder) at JoAnn's or from Amazon. Great little accessory as multiple bobbins can be wound without unthreading the machine, plus it saves wear and tear on the machine.
Posted on Jan 01, 2018
SOURCE:
SOURCE: Bobbin Winder won't release
i have a husqvarna rose, i has the same problem when i started using my machine. i was suggested to not wind the bobbin so fast. the reason it gets stuck is because the thread is so tight on the bobbin it actually makes the bobbin a tiny bit smaller, making it hard to get off again. if you dont wind it so fast, it doesn't get so tight.
kylee
Posted on Mar 25, 2008
SOURCE: Janome sewing machine bobbin winder
I had that problem the first time I tried to wind a bobbin. What a mess. The next time I let the thread run through my finger and thumb before reaching the bobbin. I had to do the same on a previous Kenmore.
I've also found that the heavier Bernina bobbins don't 'jump' around.
  • 323 Answers
SOURCE: Bobbin winding message
Under the top cover, on the right hand side where the bobbin winder is, there is a small switch which is activated when the bobbin is being wound. You will need to remove the cover and reposition the switch (it's located towards the front of the machine) to make it work properly.
sewman7
Posted on Nov 25, 2008
  • 980 Answers
SOURCE: singer 328k bobbin winder replacement
Follow these instructions, undo the 2 screws on the right hand side plate where the balance wheel is and take the plate off, undo the screw on the chrome stop motion wheel, undo the stop motion and take it off, take off the 2 pronged washer and notice which way it goes on, not a problem if you can't remember, you should be able to pull the balance wheel back so you can get to the screws on the winder, if you can.t and if you have a problem getting the balance wheel all the way then go the very bottom of the machine and you will see 2 big holes and one of the holes will lead you to a big screw and nylon adjuster, slacken the screw and move the nylon adjust so the belt goes slack, you can not take the balance wheel all the way off to get to the screws on the winder, take the old one off and screw the new one on, whilst you have the balance wheel off it would be wise to put some thin oil on the shaft before you put the balance wheel back on, when you have the balance wheel on and the and the belt round the pulley turn the nylon adjuster so the belt is tight and tighten up the screw, put the side plate back on, put the 3 pronged washer back on, put the stop motion wheel back on and just tighten finger tight then tighten the small screw.
Posted on Nov 22, 2009
  • 16 Answers
SOURCE: Help me !!!!! Got a brother XL2230, bobbin winder broken
Hi, I have the same problem, use a car 'o' ring that should fix it, should cost about
Posted on Oct 01, 2010
Janome excel 5018 decor needle goes up and down when I'm trying to fill the bobbin
Usually, the needle bar moving means that the bobbin winder spindle (with the bobbin) wasn't moved all the way to the right. If you moved the spindle, then there may be a damaged part inside the sewing machine below the spindle. (The spindle may not be engaging the winding mechanism which stops the needle bar.) I've found the bobbin winder is still available at one parts store: https://www.sewingpartsonline.com/bobbin-winder-janome-653508015.aspx . However, there may be other damage inside the machine that could be involved.
See https://www.manualslib.com/manual/994905/Janome-Decor-Excel-5018.html?page=24#manual for the pictures of moving the bobbin winding spindle.
I hope this helps.
Aug 24, 2018 | Janome Sewing Machines
Bobbin winder not winding cotton on spool a part has fallen in side machine how do l take casing off Janome 480 quilter thank you
Am unable to help with your machine but you can purchase a stand-alone bobbin winder called Sidewinder for about $30. Just be sure to verify that your machine bobbins will work on it. The one I have will use either a power cord or batteries. Great little machine because it saves wear-n-tear on the machine plus you can wind bobbins without unthreading the machine.
Customer Reviews Simplicity SideWinder Bobbin Winder Walmart com
Simplicity Sidewinder Portable Bobbin Winder
Amazon com Simplicity SideWinder Portable Bobbin Winder
Jun 05, 2017 | Janome Sewing Machines
Janome 660 sewing machine has broken bobbin winder spindle. I can order a new spindle, but cannot get the cover off of the machine. all screws are out.
You can purchase a stand-alone bobbin winder from the local fabric store (JoAnns or Hancocks) or Amazon.com for ~$25.
Dec 02, 2015 | Janome Jem Gold 660 Sewing Machine
Can I fix a broken bobbin winder on my Janome sewing machine by myself?
If your bobbin winder is malfunctioning and you are unable to resolve the issue, for ~$25 you can purchase a stand-alone bobbin winder at the local fabric store (JoAnns or Hancocks) or even online (Amazon).
Oct 30, 2015 | Janome Sewing Machines
Where can I get a bobbin winder for my Janome JD1722 as it is broken
you can buy a separate bobbin winder at Joanne fabric stores they will wind bobbins for all machines
Feb 02, 2015 | Janome Sewing Machines
Bobbin winder
Access from top, and you can replace the unit with a new one....needs to be ordered through a Janome Dealer
Drop us a line if you have troubles
Contact Us at Bargain Box
Jan 05, 2014 | Janome Memory Craft 9000 Computerized...
Needle up/down button has stopped working - no sound / activity when button is pressed.
Check that the bobbin winder on top of the machine is clicked to the left or disengaged.
Dec 12, 2011 | Janome Sewist 625e
Need to know how to thread bobbin
manuals can be purchased @ janome. com. your machine should have a bobbin winder. Set empty bobbin on the bobbin winder pin. Thread spool of thread though guide(or tension wheel on the top of the machine;NOT the stitching tension.) wrap thread around bobbin to start, and push bobbin toward the flywheel. slowly press foot pedal and bobbin should begin to turn. apply more pressure to foot pedal to increase speed.When full, bobbin winder should kick back to stop.
May 29, 2010 | Janome 2049LX Mechanical Sewing Machine
Bobbin is not filling. It barely turns.
This happened on my Janome 10000...it had to be repaired in a shop.
Jun 07, 2009 | Janome Memory Craft 5700
Sewing Machines Logo
202 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
