Question about Homelite Mighty Lite Lawn Trimmer
My line has snapped but I am unable to go into the mechanism to retrieve, please can you help.
  • 162 Answers
Look for a notch above the guard and rotate the string spool until you see a coresponding notch in the shaft assembly place a screwdriver in both notches then try to losen the string spool screw
Posted on Jul 30, 2009
Iam unable to retrieve my gmail. I have forgotten my password & am unable to log in to change password as I have a land line & not able to receive a text message. Can someone call me @
Hi Jane
Have a look here
Gmail Help
If this doesn't help and you cannot use another email address that you own ( hint you could create another gmail address) Contact google email team using the new address. Tell them you are locked out of your old account. They will be able to help you from there.
Dec 16, 2014 | Google Gmail
Norstar M7324 not showing lines in use and unable to retrieve calls on hold
That might mean that the line(s) is(are) not programmed for that telephone. If you press feature * 0 then one of the line buttons, does it list as a line or blank?
Apr 22, 2014 | NorStar M7324 Telephone
Nelco sewing machine 234F - stitch length knob wont turn
My Nelco Sierra 234F stitch length dial was stuck. Turns out it's pretty easy to repair if you are handy with tools.
Remove top of the machine. Remove set screw holding stitch length mechanism to body about half-way down inside. I loosened the screw and used a magnet to retrieve the screw and washer. Gently pull mechanism out the front, jiggle a bit to disengage rear cylinder from lever and pin inside body. When out remove two screws holding rear cylinder to mechanism and remove, note that the opening in the cylinder should be up when the dial is set to "button hole."
Remove the small snap ring holding the reverse button push rod and spring and pull it out. Remove snap ring holding outer cylinder onto inner cylinder...this probably requires a snap-ring removal tool.
Work the outer cylinder free from the inner cylinder by using lubricant (maybe let it sit over night), twisting with a wrench, whatever it takes. The problem is that the oil/grease between the two cylinders has dried out and become sticky.
Once the outer cylinder is off clean everything and verify the cylinders turn freely when assembled. Lightly file the cylinders smooth if you gouged them when taking them apart. Lubricate with oil or light grease, reassemble and reinstall the snap ring. Reinstall reverse button push rod, spring and small snap ring. Reinstall rear cylinder with the two screws, note orientation of opening in rear cylinder.
Installation is a bit tricky, you have to turn and wiggle the mechanism to get the pin on the lever to enter the side opening of the rear cylinder. Lifting the lever and pin mechanism from the top can help by moving the pin rearwards. It took me a few tries.
Once it's in orient the set screw hole in the outer cylinder under the set screw opening in the body and reinstall the set screw and washer (I used a magnet to lower the pair into the screw hole).
Reinstall cover and you are good to go. If you drop the set screw or washer remove the bottom and retrieve them, or fish them out with a magnet if you can see them.
Jun 01, 2012 | Sewing Machines
I am unable to retrieve data from the usb drive it says The Disk in drive H is not formatted.. i need help to retrieve the data..
there is no way without formatting your usb drive. first format it. but no tension you can retrieve data from your usb drive. for this please use any good recovery software which has license key. thanks
Oct 26, 2010 | Computers & Internet
Opened the cannister to remove the bag. The tube
Steve,
This may be, and I stress MAYBE an issue with lining up the snap on the collar at the end of the hose (black tube). Please look carefully, using a flashlight or other bright light if necessary, to see if there is any indication on the collar for lining it up to 'snap' together. Unless the locking mechanism is broken off this should solve the problem.
Dec 04, 2009 | Miele Cat & Dog 326i Bagged Canister...
Modem settings for Siemens SL2_141
First of all check whether dsl yellow light is on or not.
if it is not on then contact bsnl local branch.
otherwise
remove dsl line from modem.
Then
open internet explorer
type http://192.168.1.1
username= admin
password= admin
click WAN
edit pppoe 0_35_1
connection type=bridging
encapusulating =LLC/Snap-bridge
next
again next
save
save/reboot
close IExplorer
connect DSL line.
if its work plz reply me
findme_rohit@yahoo.co.in
Sep 14, 2008 | Computers & Internet
Unable to retrieve recorded songs
are you putting it in master mode and mastering the track?
thanks,
Nate
Aug 07, 2008 | Tascam DP01 All-In-One Recording Package...
SanDisk won't read
They are typically snapped/glued/molded together. Just have to gently pry at the seams.
Aug 04, 2008 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Homelite Mighty Lite Lawn Trimmer  Logo
221 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
