Question about Samsung Televison & Video
Samsung TV used tda9381ps/N3/3/1774ic nopicture nodisplay plainretrace line
Samsungflattv
    Habit-Forming:
    Scholar:
  • 122 Answers
High voltage is needed to power the screen. Check the high voltage circuit. Take off the rear panel. The high voltage is need where the 120 volts. There is a high voltage transformer and on the output the volts should equal at least 390 volt DC - check it at the capacitor. If not, check the capacitor. The one in the TV is 100 uf rated at 450 volts. I put in a 370 uf rated at 400 volts.
Posted on Jan 01, 2018
4 Suggested Answers
SOURCE:
srinibash_ka
  • 15 Answers
SOURCE: TDA9381PS/N2/3/0660 BASED SAMSUNG TV INSTANT GOES OFF WHEN POWER ON RASTER CAME AND TV TURN OFF WHAT THE POSSIBLE PROBLEMS SHOULD I CHECK?
This fault is in protection circuit.First check the 125V.D.C at sm out voltage.then eprom I.C.(memory) & Set the parameter by opening service mode Stanby>Display>Menu>Mute>Power on if require.
Posted on Jan 12, 2012
Testimonial: "thanks Srinibash Kar sir ..."
gopakumarg43
  • 76060 Answers
SOURCE: lg 21" flat tv using ic tda9381ps n3 /3/1959.The display is white with retrace lines &picture
Check all the voltages at its video output card [CRT base PCB] If all are found OK, check and replace the chroma IC. The most probable cause is defective IC itself. Check its heating effect. Will overheat within minutes after the set is switched ON.
If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences of the author of that site.
Posted on Aug 29, 2016
gopakumarg43
  • 76060 Answers
SOURCE: sinck problem
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Posted on Aug 11, 2017
TDA9381PS/N3/3/1997 Samsung plano tv..my video input is not working plz help me out
Make sure your set to video on the screen if you are then change the main board and it should fix your issue
Oct 30, 2017 | Televison & Video
Sinck problem
Aug 11, 2017 | Samsung Televison & Video
Lg 21" flat tv using ic tda9381ps n3 /3/1959.The display is white with retrace lines &picture
Aug 29, 2016 | LG Televison & Video
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ...
www.dslreports.com > ... > Electronics
DSLReports
Jan 26, 2016 | Samsung Televison & Video
TDA9381PS/N2/3I1041 alernate ic name...?
To my knowledge there is not an alternate circuit. Take a closer look, the number you gave is for a vertical defliction IC.
Nov 12, 2014 | Samsung 24.8 Cu. Ft. Side-by-Side...
Jan 12, 2012 | Car Audio & Video
LG vertical failiure vertical line at the bottom of the crt
replace the vertical driver ic and the proccesor ic
Nov 12, 2008 | Televison & Video
Nopicture
No vertical deflection. Vertical output IC, caps.
Nov 25, 2007 | Televison & Video
Televison & Video Logo
456 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
