Question about Compaq 262585-B21 16-port KVM Switch
The display on my laptop screen
I pressed a button on my laptop and it rotated my screen and i dont no how to change it back when i use it i have to turn it upside down, i need help to know what key to press to get it back
  • Compaq Master
  • 5,660 Answers
Hold the CTRL + ALT keys down, now tap the UP Arrow key. Keep pressing the UP Arrow key, until your screen is in the correct position.
Posted on Jul 30, 2009
    President:
  • 627 Answers
In video card advanced properties there is a rotate option
I don't know which videocard you have but you can go to display settings from control panel click on advanced button and enter to video card settins. There should be the rotate option
Rotate screen back to normal
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Feb 23, 2013 | Gateway Computers & Internet
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Feb 15, 2013 | Samsung N120-12GW Netbook
My son has rotated the screen on my fujitsu lifebook s series so now it is upside down! How do i rotate it back? Please help!
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
Jan 21, 2013 | Intel S6240 Notebook
My screen is sideways and i cant get it back to normal
Right cllick on your desktop and choose personalize. At the bottom of the left panel click display and then click change display settings. Click on the orientation drop down menu and change it to landscape.
Mar 14, 2012 | Dell Latitude E6500 Laptop
Hi have reno scenic 2002 model. changed the battery and code now required for radio. i have the code but when i enter it dont know how to save or store it. any ideas? thanks shane
Philips Renault Code Entry
Turn on the radio and the display will show 'CODE'
Use the Steering Wheel Remote Controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
Dec 23, 2010 | Car Audio & Video
. screen orientation not working
what exactly is it, is it you screen which is rotated, if it is i would suggest you should go to control panel, nvidea control. there should be a menu on the side, in the section display there will be rotate screen, you can adjust your rotation there or any other screen settings, hope this does solve your problem.
Sep 13, 2009 | HP Pavilion tx2510us Tablet PC AMD Turion...
Cant put the code in
===================================Philips Renault Code Entry
Use the steering controls for code entry.
Press the [¬ ] button then rotate the thumb wheel for the correct second digit
Press the [ ] button then rotate the thumb wheel for the correct fourth digit
press and hold the [¬ ] button for up to 10 seconds to store the code
Feb 20, 2009 | 2000 Renault 181
Toshiba laptop screen changed from landscape to horizontal
Try the Ctrl and Alt key in combination with the arrow keys to rotate the display
Jan 08, 2009 | Toshiba Satellite P205-S6287 Notebook PC
Rotating screen display
click again until screen is right. then open mouse config and turn off that button or change it's function.
Jul 01, 2008 | Logitech 9311570403 Mouse
Screen view
Press the following buttons
Ctrl+Alt+UP Arrow Key
That allows you to "toggle" between landscape and portrait settings on your computer...
~~Jasta~~
Mar 16, 2008 | Acer TravelMate 240 Notebook
Compaq 262585-B21 16-port KVM Switch Logo
87 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
