Question about HP LaserJet 4p Printer
Printing or doing a test print. very lite print.allso no print
No print on some of the page and very lite print . need to know what or how to fix . at home . thanks for the help .
    President:
  • HP Master
  • 1,447 Answers
My dear friend it is problem your printer cartridge or your printer laser unit mirror is dirty please service your printer then solve problem
thanks
xptareq
Posted on Jul 30, 2009
    President:
  • 2,185 Answers
Few things to consider:
1. You might be running out of ink from the cartridges. Try replacing.
2. You can clean the printer head for some clogged nozzle.
3. Check your printer settings if it was set to grayscale.
Prints test copy every time I switch it on.
All right so you are getting print test copy every time you turn on or switch on your printer. You can follow the following steps to fix this issue:-
1.. Turn off the printer and wait 10 seconds. Turn it on again
2. Let the printer print the test page.
3. After the test page is printed, disconnect the USB cable connecting the printer to your computer. DO NOT turn off the printer while disconnecting the USB cable.
4. Place the test page on the scanner glass and press the SCAN button on the printer. The ON light will flash as the page is being scanned.
5. Remove the test page when the ON light is steady.
6. Finally, turn off the printer and wait another 10 seconds. Then turn it on again. No more printing test pages! Yay!
(You may now reconnect the printer to your computer via the USB cable.)
let me know if it fix this issue and helpful to you.
Mar 03, 2011 | HP PSC 1510 All-In-One InkJet Printer
Printing error occurs when printing off internet. It will print my emails.
If your printer is an HP, here's your fix...
You probably have an issue with the Smart Web Printing. Go into your add remove programs in control panel (sorry , you didn't specify the OS, so I am quoting XP here) and remove smart web printing.
Ya, that software has caused many an HP tech support specialist no end of trouble.
I eventually told people to start removing it (not exactly company policy) and go figure, everything would start working perfectly!
(But don't tell HP that, it's an "undocumented" solution!)
Feb 24, 2011 | Office Equipment & Supplies
I have an hp 3150 all in one printer. Every time I turn it on to print a document it prints a test page. I am out of color ink so it doesn't print the additional numbers and lines to align the printer. I...
I know your problem and i want to know that have you changed or refill your cartridge?.
if yes
place one plain paper in the tray.
it will print the test paper
print it and place it on the scanner with the printed side down.
press the scan button from the printer
printer will blink the light for some time and stop blinking
now it didn't print test print every time you print
thanks
Jun 26, 2010 | HP PSC 1315 All-In-One InkJet Printer
My Officejet 4315 All-in-One is printing very very slow How do I fix this problem? I have restarted it and unplugged then replugged it and have restarted the computer and it still prints really really...
The very first thing you need to do determine whether the issue is in the Hardware or in the Software for that on the printer .
1. Load plain paper in the tray.
2. Press the Setup button
3. Press 2 to select Print Report
4. Press 4 to select Self-Test Report . The self-test page prints.
Measure the time (in seconds) it takes for the test page to prints.If the test page prints in less than 60 seconds , this is normal print speed and you do not need to troubleshoot.If the test page prints in more than 60 seconds , go to the next step.
Important ;
Some products print faster than others. If the test page exceeds 60 seconds, and other documents you print typically take as long, the print speed is normal. Troubleshoot this issue only if your product is designed to print faster than about 60 seconds a page or if printing is slower than usual.
***** IF THE PRINT SPEED IS MORE THAN 60 SEC.
Check the power supply. to check the power supply you need to follow these steps.
1. Turn the product so that you can access the rear side.
2. Unplug the power cord from the back of the product.
3. Remove any devices between the product and the power outlet, such as surge suppressors or power strips.
4. Plug the power cord directly into a wall outlet.
5. Print and time a self-test again.
If the test page prints in 30 seconds or less , the problem relates to the power supply. Replace devices between the product and the power outlet, or leave the product connected directly to the wall outlet. If the test page takes significantly longer than 30 seconds to print, continue to the next solution.
CHECK THE CARTRIDGE COMPATIBILTY.
Incompatible cartridges can cause the slow printing problem.
Which cartridges you use depends on your country or region. To check the cartridge compatibility you can go to this site (for hp printers) http://www.hp.com/buy/suresupply and check The number on the cartridge label must match the numbers listed on HP SureSupply.
PERFORM A RESET.
1. Press the Power button and turn off the printer.
2. unplug the power cord. Disconnect the data cable(USB,Ethernet depending upon the the product set up). wait for 30 secs. reconnect all the cable and than try to print a test page.
if these steps resolves the issue than you dont need to continue troubleshooting or if the issue persist than Replace the Power supply for your product.
Jul 06, 2010 | HP Officejet 4315 All-in-One Printer
MY X1240 will not print the text .
Did you run test page AFTER new cartridges installation?
Please print text from different programs: Noterpad, Wordpad, Office word, excell, Browser etc..
If you see text in some other program check settings in "text not printing" program : MSWord has a setting in Options blocking texts.
If you never see a text, check "Printer Preferences.." different from "Printer Properties.."
Let we know if fixed by scoring this solution or tell us results for any further support.
Feb 22, 2009 | Lexmark X1240 All-In-One InkJet Printer
After changing the blank ink cartridge a test print was done. Now every time I switch the printer on to print a page I get another test print page before i can print what I need to print. This is stressful...
hi my name is pete and hope you are not stressing out to much here how you fix your printer when you change a blank ink carriage and stop printing off test prints you will notice on the back of the inks theres a chip something like what you would find on a visa card now the printer uses these chips to reconise the carriages are there so the ink will work now unplug the printer from the computer and switch off the printer from the mains leave for 10 minutes so it can reset the inks for you after doing so plug the printer back in but dont plug into computer yet let the printer set it self up when ready plug back in to computer open programme you use and find out if the test page is on or got a tick on it if so click it off and then try to print anymore problems let me know
Oct 06, 2008 | HP Office Equipment & Supplies
Test Page
thats not the test page that is allignment page which is printing.
keep the the printed side of that page which comes out on the scanner glass.press the ---scan ---button.the on /off light will blink, wait till it stops blinking.and after that everything will be normal.
for any thing else let me know.
thanks.
Sep 17, 2008 | HP LaserJet 1200n Printer
Number of pages my printer has printed
You need to print a self diagnostic page. On that page will be listed the number of pages printed from trays and accessories.
To print the Self-Test Diagnostic Page
• Control panel: Press Setup, select Print Report, select Self-Test Report, and
then press OK.
• Toolbox (Windows): Click the Services tab, and then click Print Self-test
Diagnostic Page.
• HP Printer Utility (Mac OS): Click Device Information from the Information and
Support panel, and then click Print Configuration Page.
Thanks and please take a moment to rate this as fixya.
Jul 06, 2008 | HP Officejet Pro L7680 All-In-One Printer
Test page quality bad
When I scan a document it prints out small. How do I change the size?
Feb 21, 2008 | HP Photosmart C4280 Aio Printer
Printer prints test page each time printer is turned on
There may be something initialised to print a test page everytime it starts, just remove printer, uninstall driver and re start. Re install drivers and connect printer when prompted or when installation has finished. This should revert to default settings.
Jan 07, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP LaserJet 4p Printer Logo
142 people viewed this question
Seeker5211
Seeker5211
