Question about HP Pavilion dv1000 Notebook
When i plug in my adapter the charger indicator is not on
    President:
  • 2,185 Answers
You might need to replace your battery pack. This means that the battery is not charging.
Posted on Jul 30, 2009
Manual for ilive bluetooth receiver and adapter lAB13
Have you actually checked the charger is actually working with power coming out of plug that plugs into device.. THe actual charger unit may not be connecting properly into wall socket...
Dec 09, 2013 | GPS
Hi I have a samsung notebook. When I plug in the charger the light comes on to indicate it is charging. But when I press the button to turn it on nothing happens. I have tried turning it on with the...
hopefully maybe the charger is bad ..the light might be on only indicating power coming into the adapter but not out!!!..invest in a new charger and battery
Apr 14, 2013 | Computers & Internet
Sony vaio not charging while charger plugged in
Seemingly your laptop dc jack is dead. How to confirm it? If you should wiggle your laptop charger on a position to let your laptop charge, it indicates your dc jack is loose. Either replace it or repair it. If your dc jack works well, please check your ac adapter. Maybe your charger is dead.
http://www.chargerbuy.com/laptop-ac-adapter/sony-ac-adapters.html
Oct 27, 2012 | Sony VAIO VGN-NS160D/W Notebook
My ibm thinkpad from the year 2000 wont turn on. i have connected the adapter and put the battery. i press the button to turn it on but the laptop wont turn on
1st thing you need to do is to make sure the adapter is working.
check to see if any LED indicator lights up when you connect the charger.
if none of the indicators light up with the charger plugged in, you may need to consider replacing your charger/adapter.
however if the indicator come on, then it is most probably a problem with your power/on switch (at the least) or a problem with your motherboard (at the most)
Mar 31, 2011 | IBM ThinkPad T21 Notebook
It is no longer charging
there are certain issue
  1. Check the plug, if it is working
  2. Check adapter indicator , if indicated is glowing?
  3. Remove battery of your laptop & connect adapter directly ,See if your laptop gets the power
  4. Replace with another adapter, if it starts charging then definately it was a charger problem.In that case you need to buy another charger...
  5. If you laptop does not charg with another charger, then ther might be problem with the laptop..
let me know , if it works....Other wise we will find another troubleshooting steps....
Thanks
Pandeep
Mar 07, 2011 | Toshiba Satellite L305-S5908 Notebook
My toshiba satellite L300 has no power
Please follow these steps VERY CAREFULLY:
1) Unplug the notebook from the ac adapter (charger power cord)
2) Take off the battery pack on the notebook
3) Once the ac adapter and battery is off the notebook, hold down the power button for 15 seconds
4) After 15 seconds, let go of the power button
5) Now plug in the AC ADAPTER (OR CHARGER POWER CORD) ONLY (DO NOT PUT BACK THE BATTERY PACK)
6) Now press the power button once.
7) If the unit boots, the unit suffered a slight surge
8) If the unit does not boot and remains dead, the unit suffered a severe surge and may be burned out and needs replacing
I hope this helps and let me know how it goes afterwards
May 03, 2010 | Toshiba Satellite Pro L300 Notebook
Have lost charger or the 2 prong adapter. Not sure as we have a 16 volt charger with single prong that may be for our light. Need to know what voltage required for the light to be sure.
According to the instruction manual for these swimming pool lights, the charger specifications are the following:
USA and CANADA: 14 VAC,1.5A UL/CSA-approved wall plug
adapter and charger
AUSTRALIA and NEW ZEALAND: 240VAC 50Hz/14VAC 1.5A wall
plug adapter and charger
EU: 220-240VAC 50Hz/14VAC 1.5A CE-approved wall plug
adapter and charger
SOUTH AFRICA: 220-240VAC 50Hz/14VAC 1.5A wall plug
adapter and charger
UK: 240VAC 50Hz/14VAC 1.5A CE-approved wall plug adapter
and charger
Aug 13, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Samsung L100 cant figure out how to charge!!! Adaptor supplied but no battery charger to plug in to mains. Do I need to purchase a battery mains charger???
you can charge the battery through the camera like a cellphone.
plug the USB cable to the ADAPTER then plug it to a wall socket then plug the USB cable connected to the AC power adapter to your camera
the USB cable should have an indicator (RED) if it is already charging and (GREEN) when its done
Jun 23, 2009 | Samsung L100 Digital Camera
Only works when adapter's plugged in.
try plugging and unplugging the charger/ac adapter several times to see if the switch that is built into the jack might be stuck from dirt or corrosion.sometimes you can take a toothpick and get them unstuck too.
Sep 25, 2008 | Icom IC-R5 Handheld Scanner
Dell inspiron b130
check if the ac adapter or charger has a green light on it. if not, replace the charger. for dell chargers, it should have a green light to indicate that the charger is getting power from the wall outlet. if the ac adapter is good, then you might need to replace the mother board as the ac port is integrated.
hope this resolves your problem.
Nov 12, 2007 | Dell INSPIRON 6000 CENTRINO...
HP Pavilion dv1000 Notebook Logo
76 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
