SOURCE: water only stays hot for 5 minutes when I take a shower
Unit needs a new "dip tube" It is cracked and allowing cold in water to mix with all hot water resulting in "lukewarm water". Need plumbing skills to change out at cold inlet top of heater,pull out old,buy new at hdepot 5.99 reinstall.
Please rate Thanks
jj505
SOURCE: Bosch AquaStar 125b ng suddenly goes cold during shower
Does it happen to any other fixture? If not, it's most likely your shower valve and not heater.
SOURCE: rheem tankless water heater error code C4 13??
check diaphrapm valve or micro/switch best of luck
SOURCE: The hot water shuts down for a few minuts then
your unit is undersized or you do not have enough gas supply to run the unit properly.
If you have to many water features running or you have to many gas items turn on at the same time it can cause problems.
SOURCE: My oil fired hot water
It sounds like your thermostat on the water heater isn't working properly. try turning it up higher and if this doesn't work I would have a service techy look at it.
I get a code 25 on my Rinnai. That means the condensation tube is stopped up. It is very cold here so ice must have stopped up the condensation tube. Will have to put a heat tape on the tube to the outside wall.
I just cut the condensation tube running to the outside through a black wall and ran it into a bucket inside. Now I have hot water.
Super. Happy new year
