Question about LG Vu Cellular Phone
My phone won't find my bluetooth headset, any advice?
    Problem Solver:
  • 6 Answers
Ah, My Mother Has This Phone. First Turn On Your Bluetooth And Make Sure Your Phone Is Visible. Next Turn On Your Head Set. It Should Flash Two Different Colors. At That Stage Let Your Phone Search For It. Select The Name Of It And Put The Pass code Then Your On Your Way.
Posted on Aug 02, 2009
Motorola hs850 bluetooth headset won't pair with g five mobile
How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
  4. (Now you can let go of the call button.)
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
May 14, 2012 | Motorola Mobility HS850 Consumer Headset
I have an LG phone and my Discovery 925 bluetooth from Plantronics won't connect anymore. When I have it in discovery mode my phones message states "no devices found."
You want to make sure that there is no other bluetooth interference on your phone and follow the instructions on the link for the Plantronics Discovery 925 (see page 4).
Good luck from Headsets Direct!
Jul 17, 2011 | Plantronics Discovery 925 Bluetooth...
Having issues syncing my Uniden BT112 Bluetooth to my BlackBerry Bold. I used this Bluetooth with another telephone and don't have any of the old packaging. I don't have a pin number. Help!
Please follow the correct instructions below to successfully pair your headset with the phone.Make sure that the headset is sufficiently charged before pairing.
Charge the battery
Before using your headset, charge the battery for at least 8 hours. Charging the battery completely (and keeping it charged) will help you get the longest possible talk and standby time out of the battery.
Pair the headset to your Bluetooth phone
Pairing is like "introducing" two Bluetooth devices and giving them permission to connect to each other. If you want to use the headset with more than one phone, you need to pair it with each phone separately. Once a phone and the headset are paired, they can connect automatically whenever they detect each other.
1. Make sure the headset is powered off and the power adapter is not connected (you can't use the headset while it's charging).
2. Press and hold Power until the LED flashes alternating red and blue. The headset is in pairing mode and should be visible to other Bluetooth devices.
3. On your phone, start a search for Bluetooth headsets or handsfree devices. (This process may take several seconds, and it will be different for each phone; see your phone's manual for detailed instructions.)
4. Your phone should discover a device called a BT108, BT108 headset, BT109, or BT109 headset, When your phone asks if you want to pair with this device, answer yes.
5. When your phone prompts you for a PIN code or password to pair with the BT108 or BT109 enter 0000.
6. When the headset is paired, the LED turns blue and flashes every 3 seconds. Your phone might display a confirmation message, also.
7. Your phone might ask if you want to change the headset's name; generally, you should only change the name if you have more than one BT108 or BT109 headset that you use with this phone.
Connecting to your phone
Most phones connect to the headset as soon as you pair it; if yours won't, turn the headset off and back on. If headset still won't connect, check your phone's owner's manual for additional Bluetooth information.
Once the headset is paired:
Whenever you turn the headset on, it will automatically try to connect to whatever device it was connected to last.
If the headset loses the connection (e.g., if your phone is out of range), it reconnects automatically. To manually reconnect, press Power.
If the headset goes more than 1 hour with no connection, it automatically turns off.
If you need further assistance please leave me a reply.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Uniden BT-108 Bluetooth Headset
Insignia Bluetooh Headphone won't turn on. but can charge
put the charger in your headphones and hold both volume buttons
you should see a slight flash of blue light then press the multifunction to turn it on
Jun 19, 2009 | Insignia Bluetooth Wireless Headphones...
HFBLU-LT100BK Bluetooth keeps "pairing failed"
headset won't pair with me phone and i have tried 0000 and 1234 and 12345
Jan 30, 2009 | Cellular Innovations HFBLU-CX1 Wireless...
Pairing ge 86710
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select 86710once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Jan 28, 2009 | GE Bluetooth In-ear Headset Wireless...
Plantronics 330 bluetooth headset / Nextel Blackberry 7100i performance
After looking through the phones, there many possibilities, wow quite a few. It does not have any recommendations on headsets. The headset is only as good as the the quality you are purchasing. If your phone drops calls it won't be from the bluetooth device. Below is a link to the Explorer Series 300 User's Guide, which may help you.
Plantronics Explorer Series 300 User's Guide
Sep 22, 2008 | Plantronics Explorer 330 Headset
Compatibility
According to the plantronics manual, turn your headset off, the hold the on button for six seconds.. the light will flash blue and red. This means it is in pairing mode.
Go to the bluetooth menu on the i580 and attempt to find the headset... with the headset in pairing mode, it should come up in the screen.. select it and enter the code supplied with the headset of 0000... let me know if you get it..
Aug 21, 2008 | Plantronics Explorer 320 Wireless Headset
My bluetooth
Sorry I post the wrong link before, for plantronics manual it is: http://www.plantronics.com/media/media_resources/literature/user_guides/explorer320_userguide_en.pdf
Jul 31, 2007 | Plantronics Explorer 320 Wireless Headset
LG Vu  Cellular Phone Logo
856 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
