Question about Sony Ericsson Z610i Cellular Phone
Sonny Eriricson Z106i
Hi, The phone just died when i tried to play the executor game. I have tried everything, taking the battery out, charging, It was too much of a coincidence. As soon as i pressed to play the game it died.
What is a executor file? i clicked on it and now my sony ericsson has gone compleatly dead!!!! help.
WON'T TURN ON
Hi,when a phone does not come on, it is either the battery of the phone is dead,
might need to be charge or replaced with another battery.
you can use another battery to test if it is the battery the fault.
The other thing to check is if the phone memory is weak and may need to be restored
back the phone memory.
will need to be flashed.
if too weak to power up the phone all application you downloaded on the phone has
VIRUS and has affected the phone memory.
First Charge the battery for longer hours before using another battery to confirm
if the battery cell is the problem.
If not battery, in think you will have to flash the phone memory for it to come back to life.
You can use the link below to know about how to flash the phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
(unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Aug 07, 2010 | Sony Ericsson W850i Cellular Phone
Executor program
Hi I find the solution to the problem 'executor', the problem is that the man who unlocked phone vort forget to remove the executor program is a program to unlock sony ericsson phones.
So you must ask him to remove the program from your phone, it will very well come when the problem.
And your phone will turn on again.
Nov 15, 2008 | Sony Ericsson K770i Purple 3G Camera...
Sony ericsson w580i pink won't turn on
take back the phone to where it was purchased and get a new one or have it serviced
Aug 16, 2008 | AT&T Sony Ericsson W580i Cell Phone -...
Hii need ur help
delete the executor file from your phone. that file is for unlock your phone. that is no game software.
Aug 13, 2008 | Sony Ericsson W550i Cellular Phone
Stupid executor!
You will need to take the phones and ahve then brought back up again....or you can try www.topsony.com
Jul 05, 2008 | Sony Ericsson W700i Cellular Phone
My k800 is completely dead
It is a very well known issue tha only appears after unlocking. Seriously :)
Go back to the guy that unlocked it and ask him to unlock it again, this time with "enable preloader security bypass" checked then to delete the executor application. If he doesn't know what the above means then I suggest you find another guy that actually knows what he is doing...
Cheers,
Meow
Jul 04, 2008 | Sony Ericsson K800i Cellular Phone
Phone dead after opening java executor
I had the same problem with a k800i, i emailed sony ericsson and they told me what to try and it worked however you do lose everything you had stored on your phone. I believe this will work with most if not all sony ericsson phones. You need to update your phone, here's what to do;
1.Go to www.sonyericsson.com/support
2.Select UK
3.Select your model of handset
4.Click on Sony Ericsson Update Service
5.Click the link, and then click Run or Save.
6.Let the Sony Ericsson Update Service install.
Once you have installed the Sony Ericsson Update Service you will need to launch it. Once it opens simply follow the instructions that you will see on screen. The update should then begin.
Jun 22, 2008 | Sony Ericsson W700i Cellular Phone
Sidekick lx
When you take out your battery wih out shutting down it erases everything but only for about an hour everything does come back it does not erase it forever! Just to let everyone know! Of course if you have an option besides taking out the battery then use that but waiting for it to die is just silly and would take forever!
Jun 19, 2008 | Sharp Sidekick LX Smartphone
Sony Ericsson Z610i Cellular Phone Logo
223 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
