Tis a process so here goes.....
Central Security Module (CSM) enable/disable mode allows autolock feature to be turned on or off. To enter enable/disable mode, close all doors. Ensure ignition switch is in LOCK position. Perform the following steps within 30 seconds:
Turn ignition switch from LOCK to RUN position.
Press power door lock switch UNLOCK button 3 times.
Turn ignition switch from RUN to OFF position.
CSM module should chirp horn indicating CSM module is in enable/disable mode and ready to accept program changes.
Press power door lock switch UNLOCK button once to command CSM module to toggle autolock feature on or off. Press power door lock switch LOCK button once to enable/disable autolock feature. CSM module will chirp one time to indicate autolock has been disabled.
CSM module will chirp once, followed by a longer chirp to indicate autolock feature has been enabled. Press power door lock switch UNLOCK button once, then turn ignition switch to OFF position to exit enable/disable mode. CSM module should chirp once to verify a feature change. Best to you.
Testimonial: "This truck does not have power windows though"
SOURCE: anti theft device for 97 ford expedition
I have 2007 expedition XLT and the interior light blinking all the time what the solution ?
SOURCE: 2000 ford windstar anti theft light flashing vehicle won't start
This means that your key is not being recogonized.Ethier the chip in the key is bad or the patts transciever at the lock cylinder. Do you have a spare key? If not you will have to get 2 new keyss cut and programmed.
SOURCE: Isuzu Trooper anti-theft alarm
Join up the wires in the tailgate catch and the drivers door for the anti theft circuit the nthe unit thinks its allways unlocked so wont sound off .
SOURCE: how do you reset the anti theft system
Try disconnecting your battery cables then wait about 10 minutes. The computer should reset itself. Reconnect the wires to the battery. It is normal for the theft light to blink about every 5 seconds when the ignition key is out or in the off position. This means the system is armed and working properly. Hope this helps. God bless!
SOURCE: 2002 ford explorer xlt 4x4... Vehicle won't start
My 2002 Ford Explorer have the same problem
