Computer when turned on will not boot and makes a long beep continuously and then makes like a siren sound
  • Rik Evans May 11, 2010
    Could be that it can see no memory. Alarms can vary by manufacturer, please post details of the actual machine doing it. In the meantime, try removing the memory and reseating a single chip in it (or try alternate matching memory if you have any to hand).
  • 528 Answers
The long beeps probably mean a problem with RAM. So try replacing it. Check whether the CPU Cooler (the fan on top of the processor) is working. If the fan is not working, the processor gets hot, and a siren sound is emitted. Also check whether power unit fan (at the back) is working. If RAMs are replaced and you still get the beeps, the problem may be with the VGA. (The beep sounds help to identify the problem, but the sounds differ with different BIOS models).
Posted on Jul 30, 2009
    Sergeant:
  • 263 Answers
Power supply, system board, or keyboard problem more than likely psu problem
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
H57h-am2 beep never stop
A computer will alert you to trouble through beeps and other sounds. If you have a problem with the operating system, the computer gives you different beeps when you start up the computer. You hear the beeps in different scenarios, such as three long beeps or one long and one short beep. These beeps can mean different things depending on what computer model you have. A siren sound on a computer means the central processing unit is overheating. This is true for any computer. When the CPU gets hot, it makes a siren sound warning you that your computer is overheating. At that point, the computer should be turned off to prevent damage.
Open the computer and clean it if you notice a lot of dust inside. You can purchase canned air at most stores. Follow the instructions on the can. Check the instructions in the manual that came with your computer on how to clean the inside of it. If there is a lot of dust, that alone can cause the heat sink to overheat. Verify the CPU heat sink is properly installed and the power is connected. Consult the manufacturer's instructions on how to open your computer and find the heat sink. It should give you instructions on how to check that it is properly installed and connected. You should find it in the middle of the motherboard. Make sure the fan is working. Your CPU will overheat if the fan is not working properly. Refer to the manufacturer's instructions for your computer for instructions to check the fan. Replace it if it is malfunctioning.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules make sure that your RAM modules and Cmos battery are securely seated on some motherboards Cmos batteries are soldered in Test all power and data leads that attach from motherboard to your hard drive IDE SATA make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40 pin ide it will be the first to fail check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it restart your computer the found new hardware wizard should activate a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function make sure all leads that are attached to your drives dvd\cd and floppy drive have secure make sure the connections and are not faulty or just replace them they could be faulty a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly so any faulty leads will end up with a computer error also check the keyboard for secure dust free connection ps2 and or usb Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat Thermal compound is a sticky paste that is placed directly onto the CPU. http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
Mar 17, 2013 | HP Pavilion 7955 PC Desktop
Siren sounds on the computer?
Hope this helps.
Nov 22, 2012 | ASUS P5LD2-VM Motherboard
Continuos sound of siren in motherboard
Hi'' sirens used to determine errors on PC, sometimes continuous beeping you will hear, so please check socket wire properly and the Ram , i hope this can help''thanks for using FixYa.com.
Aug 22, 2012 | DFI PS35-BL A Motherboard
Beeps on startup but no video and continues to have long beeps with no video
Check the the cpu, ram and video card are seated properly. If they all are, then the board is defective and will need to be replaced.
Mar 05, 2011 | Abit NF8-V Motherboard
It makes few siren sounds, and then display "boot system failure"
Never heard of a HDD making siren sounds but if you mean a series of beeps from your PC then they are codes which indicate the problem.
See here for how to interpret them.
Sep 02, 2010 | Western Digital Caviar WD450AA 45 GB...
Computer does not boot, and makes a beeping sound
check your RAM...its the main reaon for the beeping sound...check your RAM in another computer...if the beeping sound continues means replace a new one....is this cleared your problem?
Jul 10, 2009 | Computers & Internet
Can't start up computer
The siren sound is a alert sound that your processor is overheated. please check the processor heat sync and fan installed properly?
Apr 18, 2009 | Abit KN9 Motherboard
Cannot boot the system.
When you put the RAM back into the computer did you return them to their original bank? Dual Channel DDR RAM is particular about being in shared bank with the other RAM module; that's why the color code the RAM Sockets in some motherboard designs so you don't them mixed up. Moreover, is the CPU fan spinning for the short time it is powered up?
Nov 27, 2008 | Intel D945GNT Motherboard
Open Questions:
Secure Your Data With Our Online Backup Services ' DataAlign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Online Cloud Backup technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Computer Data Backup is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Business Server Data Backup up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
May 25, 2018 | Quantum Computers & Internet
Computers & Internet Logo
361 people viewed this question
David Payne
David Payne
