Question about Solis Palazzo Espresso Machine
I have a Verona Express VER 1 gs 1 group semi auto coffee machine that allways trips the main fuse when ever i turn on the steam button, if i isolate the wires into the boiler the other parts work and when i put the wires back onto the boiler it trips the main again...what can be the problem?
  • 1,089 Answers
HI
If you disconnect the element wires and the machine works, but when you hook them back up it trips the circuit breaker. Your element is bad (shorted) and need to be replaced.
Posted on Jul 30, 2009
Rancilio coffee machine .no water coming out of the group head . steam coming of the group head
Hi Ewah,
If you are getting steam from the group and no water when you turn on the water button - then you may have a group blockage.
The fix depends on the type of machine you have.
If it is a commercial type - then call in a qualified coffee technician.
If it is a domestic type like rancilio sylvia, the you could try to descale - maybe too late, but worth a go.JURA descaling tablets
If when descaling, no water is coming from the group try leaving the steam tap open when asking for water.That way you may get the descaler liquid moving inside the boiler and it may clear the solenoid valve blockage.
If no joy with that you may need to replace solenoid valve.
230V 9W PARKER SOLENOID
Domestic machines need regular descaling to avoid group blockages.
Mar 18, 2017 | Rancilio Coffee Makers & Espresso Machines
More info
Sounds like either the gigleur on the top of the machine is blocked, or the blockage might be in the flowmeter gigleur.
Apr 01, 2014 | Nuova Simonelli Mac 2000 I Group Espresso...
Just bought the machine. Basically, the problem is that the steam wand goes of on its own (or as soon as I push the coffee button) and that I cannot turn the steam handle at all or do anything to stop...
Hi. Make sure all your buttons are off. (switches all facing the same direction). Then make sure the tap is turned off. Switch main power on. Then switch the coffee on. you should hear the pump start. usually loud at 1st, then it will get quiter as the water is pumped up through the group head. When water is pouring through the group head, switch off the coffee button. Now let it finish heating. If you can get to this stage, then everything is ok. If you cant get it to this stage then you have a problem with the machine. Most likely a themostat on the boiler. Darryn REPAIRER
Sep 22, 2011 | Rancilio Silvia Espresso Machine
Hi, I work with a Faema semi auto 2 group machine, why does the on / off switch have 2 settins on it??? just curious
Setting number 1 - turns on the groups and the inlet solenoid, so that the machine can fill and you can test the groups but it will not heat up. If the boiler is empty or you are setting the machine up for the first time you would turn it to one so that it can fill up, then you would turn to 2.
Setting number 2 - Turns on the everything, so the machine can heat up.
Aug 15, 2011 | Faema FA60081
The brew group is stuck and will not come out
I hope one of this two solutions solve your problem.
1- The brew group is out of place. Turn the machine on. Close the service door.
The brew group is automatically placed in the correct position.
2-Coffee grounds drawer is inserted. Remove the dregdrawer first, then the brew
group.
Jan 15, 2011 | Saeco Odea Giro Plus Coffee Maker
Safety valve cn10 keeps activating about 10 seconds after switch on. any ideas anyone. stafco markus 2 group semi auto
Try this open the steam wand and leave on when turning the machine on, when valve stats hissing with steam close. If that works then the vent valve needs to be replaced, If it blows out hot steam from valve then the pressure stat is not operating properly.
Jun 22, 2010 | EXPOBAR Office Control Espresso Machine
I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Mar 23, 2010 | Saeco Odea Go
No water coming out
Well on a Aroma I allways test to see if its just not air in the machine.
Turn on the machine.
press the coffe button.
Then press the steamer button ( dont turn off the coffe button.)
Do it come out hot water from the steam nossle then after a while?
Then turn of the steam button, if the filter is not blocked there should now come water from the coffe outlet.
Jul 21, 2008 | Saeco Aroma Espresso Machine
Where to fix my Gaggia
If you are unfamiliar with semi-automatic machines you might have neglected to prime the machine: open steam valve with a small container at the nozel, press coffee delivrery button and wait til water runs into the container,the close steam valve and water should come through shower head. This is very basic. If no solution then the head group might be jammed with old coffee grinds. See coffeegeeks forum on subject.
Dec 30, 2007 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Cafe verona delonghi
You need to turn the knob on top to the steam logo. then turn the knob on the side to open the steam valve. then when you get all the steam you need turn the knob back to brewing
Sep 11, 2007 | DeLonghi Caffe Nabucco BCO70...
Solis Palazzo Espresso Machine Logo
205 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
