SOURCE: Kenmore 70 Series Washer Spin Cycle Only issue.
It sounds like one of two things 1,A worn clutch .or 2.motor coupler is about gone,
SOURCE: GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
SOURCE: GE Profile WPRE6100G will not spin
hi thanks for the question. i think the problem is with the lid switch . lifting the lid 10 times wont help if the switch is faulty check the lid switch thanks the appliance doc
SOURCE: GE washer won't agitate or spin
un plug the machine , wait 30 sec. plug back in , open and close the lid completly 5 times with in 30 sec. if the problem is just needing to be reset this will do it if not you need to replace the motor
SOURCE: GE washer no main motor run so no agitate or spin
This is the electronic washer. Unplug for two minutes, plugin then open and close lid 7 times. This will reset motor. Also make sure belt is not broken.
