Question about Grilling
Why does my Traeger Smoker not hold temperature.
    New Friend:
  • 72 Answers
The Traeger has no thermostat, it works by approximating how often the auger needs to push pellets into the fire box. If the temperature is within 20 degrees, Traeger considers that within range. If you live somewhere with extreme weather, this could affect your Traeger's performance. If it's cold outside, set the Traeger to a higher temp (or get one of their insulating blankets). If it's hot, set the Traeger lower. I hope this helps.
Posted on Jan 02, 2018
  • 332 Answers
SOURCE: Hi, i have a traeger smoker and am trying to find
Simplest it to go to treager.com and match the pictures
Posted on Mar 10, 2010
gcken
  • 140 Answers
SOURCE: Our traeger smoker is smoking but is not emitting
You need to replace the element inside the smoker!
Posted on Apr 04, 2010
  • 13 Answers
SOURCE: Traeger smoker - the flame ignites but the fan stopped working
Use White Lithium Grease from a spray can. Blow into the shaft side of bearing.
Posted on Jul 25, 2010
SOURCE: Err message on my Traeger
I had the same problem; I talked to Traeger talked to their rep and he walked me through fixing the problem. There are two wires leading from the temperature probe, these lead back to the thermostat digital controller. With the unit unplugged, unscrew the two screws holding the temperature controller in place. Slowly and carefully pull out, and check that both wires are running into the controller. If either is disconnected, strip a little more wire off the loosened wire, put back in hole and tighten the wire back down. That was the trick for my grill. Reassemble and reconnect power and test it out.
Posted on Oct 17, 2011
  • 17832 Answers
SOURCE: previous entry about igniters is a Traeger smoker
Answered
Posted on Aug 07, 2017
My Traeger grill keeps going off on smoke
Do you get an error messsage that looks like LEr? If a Traeger can't reach 125 for ten consecutive minutes, it will automatically shut down. Try starting at a higher temperature than "Smoke" if it's cold outside. Traeger also makes "blankets" to help your smoker maintain temp in cold climates, but they're quite an investment.
Jan 01, 2018 | Grilling
Burner not working
Traeger Industries burner not working Grills & Smokers ...
www.fixya.com > Forum > Tags > burner not working > Grills & Smokers
Traeger Industries grills & smokers burner not working related questions and answers. Ask your ... Question about BBQ075 All-in-One Grill / Smoker. 1 Answer ...
Traeger Industries water pump not working Grills & Smokers ...
www.fixya.com > ... > Tags > water pump not working > Grills & Smokers
Traeger Industries grills & smokers water pump not working related ... Question about BBQ075 All-in-One Grill / Smoker ... our auger stopped working how can we fixthis. it is not the electrical .when you put pellets in the burner it will light and ...
Support - Traeger Wood Pellet Grills
www.traegergrills.com/support.html
Traeger Pellet Grills, LLC. ... Why won't my grill light? ... Why is my grill running so hot on smoke? .... Large Commercial Trailer. Download manual. View All ...
FAQS - Traeger Wood Pellet Grills
Jan 01, 2016 | Traeger Industries BBQ075 All-in-One Grill...
I keep getting an error msg. When it finally starts, it shuts off with the Err
Hi Terry,
This may help... ...from Treager's site FAQ
"My Unit Goes Out On Smoke
  1. Open the cooking chamber lid and remove cooking grill, angled drip pan and U-shaped firepot cover. Look and see if there is a large accumulation of pellet ash in and around the firepot. If there is, it will need to be cleaned out. Do this ONLY WHEN THE GRILL IS TOTALLY COLD! Replace U-shaped firepot cover, angled drip pan and cooking grills and resume cooking/smoking process.
  2. If this does not remedy the problem, please contact the Traeger Service Department."
From my personal experience, cleaning out the pellet ash is needed when the smoker will not hold a high temperature regardless of the thermostat setting.
In your case, the fire pot may be packed with pellet ash and pellets from the auger jamming.
Good luck.
May 29, 2015 | Traeger Industries BBQ070 All-in-One Grill...
Traeger grill not smoking
This is a common complaint about Traeger grills. Some people have resolved it with smoke pipes which contain pellets that smolder during the cooking process.
Others use different pellets than Traeger pellets but they void their warranty when they do. For me, Traeger pellets seem to put out enough smoke at the low temperatures I use (less than 200 degrees) but if I get above 200, the smoke goes sway.
When I cook pork shoulders, I try to keep the temperature at 180. In ideal conditions the Traeger will fluctuate between 160 and 200, averaging 180. If I can maintain this low-slow cooking temp-speed, I get a good smoke ring and decent smoke flavor.
If I get above 200, I lose much of the flavor but usually have a smoke ring though not as intense as at the lower temps. There are lots of conversations about this on blogs at the Traeger website and at the Pelletheads website.
Jun 14, 2014 | Traeger Industries BBQ100 All-in-One Grill...
Traeger grill get to hot on smoke
If you're cooking when it's hot outside, it's hard to maintain low temperatures. In the heat of summer, I have to tend my grill continually opening and closing the lid to keep the temperature down to my cooking temp of 180. That, of course, lets the smoke escape. If it gets too hot when the temperatures are moderate, i.e. 60s and 70s, the augur may be dumping too many pellets into the fire pot and need realigning. I suggest you contact Traeger customer service at http://www.traegergrills.com and see what they suggest.
Apr 20, 2014 | Traeger Industries BBQ100 All-in-One Grill...
Does not heat to right temp.
You didn't give any specifics which makes it difficult to respond because there are many reasons why a Traeger grill might not heat to the right temperature.
One of the most common is problems is the outside temperature. If it's hot, the Traeger may overheat unless it is tended constantly. When it's cold, the Traeger may not get as hot as it should based on a normal setting and you may have to set it higher to reach the temperature you want.
Other reasons could be mechanical in that the hot rod may not be keeping the firebox as hot as it should or the fan may not be running as hard as it should to get the temperature to the right setting.
If your firebox has not been cleaned, ash will effectively insulate the fire, preventing heat from building up in the cooker.
Some people clean their Traeger thoroughly after every use. Some never clean theirs until something goes wrong. I clean mine after every 4-6 uses, depending on how long my cooking sessions have been.
If I've been cooking pork shoulder low and slow for many hours, I'll clean it more often than if I had grilled steaks multiple times for 15-20 minutes at a time.
Likely, if you're cooking in "normal" outside temperature of 60-80 degrees, your Traeger should be holding fairly close to the temperature you've set. If it's not then you may have a fan or hot rod problem and you ought to contact Traeger to set what they suggest.
Mar 03, 2014 | Traeger Industries BBQ075 All-in-One Grill...
Err message on traeger smoker
Sep 29, 2012 | Traeger Industries BBQ075 All-in-One Grill...
Err message on my Traeger smoker, first time using it
Dec 02, 2010 | Traeger Industries BBQ100 All-in-One Grill...
I'm getting an "Err" message on my digital temperature reading. The grill starts up but then shuts down when the "Err" message comes up.
Remove your grill, inner shield and outer dip plate from the Traeger. Start the Traeger in smoke mode. Observe to see if the blower fan is working. Is the auger turning? Are the pellets dry? Condensation can make the pellets swell and cause plug ups.
Aug 13, 2010 | Traeger Industries BBQ100 All-in-One Grill...
Grilling Logo
368 people viewed this question
Top Grilling Experts
Paul Carew
Marvin
Marvin
Tom Chichester
Are you a Grilling Expert? Answer questions, earn points and help others
