Question about Video Game Consoles & Games
Game disc will not eject ; disc maybe installed in console backwards how do i remove disc from console ?
    Problem Solver:
  • 5 Answers
There should be info on this happening in the manual that you get with it
Posted on Jul 30, 2009
Game disc dosent pop up and when click on stuff it freezes
  • 1
    Press the "Eject" button on the PlayStation 3 console and hold it for at least 10 seconds; if your PS3 has the "force eject" feature included it will eject the disc regardless of whether the console is frozen or not. Turn off the console and turn it back on before inserting new discs.
  • 2
    Unplug the power cord and any other cords from the PS3 console if the "force eject" feature does not work and you own a PS3 Slim. Turn the console upside down so that you have access to the bottom of the console.
  • 3
    Locate the small compartment door on the bottom of the console. Remove the door by pulling it up and off the console; a blue screw and a small hole should be visible inside the compartment.
  • 4
    Insert a Phillips-head screwdriver into the hole. Turn the screwdriver in a counterclockwise direction to manually eject the disc. Once the disc is removed, replace the compartment door and turn the PS3 console back to its correct position before reconnecting the power cable and any other cables you previously removed.
  • Jan 29, 2012 | Sony Playstation 3 (PS3) Console
    Disk won't eject. The disk was put in backwards, and now won't eject
    Hi
    It looks like the disc is jammed inside the console.
    Look for a tiny hole next to the drawer. Push a small paperclip in and it should force the disk out.
    Try this, if it doesn't work let me know
    Mar 06, 2011 | Nintendo Wii Console
    My ps3 is blinking red what do i do?
    You have the infamous YLOD, aka. Yellow Light of Death. This is the number 1 cause of pS3's dying. It is an overheating issue linked to your CPU and GPU (the processor chips) You will need to find a local PS3 repair shop who can repair this. Do not try to attempt repairs seen on the internet yourself as some would suggest.You could make things much worse and render the unit totally unresponsive. The repair process takes about 3 hours.
    IT CAN BE FIXED*
    IS THERE A DISC STUCK INSIDE?
    If you have a unit that is not backwards compatible, any non 60g or 80g then you can retrieve your disc.
    Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
    You will have to have the system repaired so that you can eject the disc the normal way. If the technician cannot repair your system, simply ask him to remove your disc.
    Jan 26, 2011 | Sony Playstation 3 (PS3) Console
    Game will not turn on or eject game . It will beep but thats it .
    You have the infamous YLOD, aka. Yellow Light of Death. This is the number 1 cause of pS3's dying. It is an overheating issue linked to your CPU and GPU (the processor chips) You will need to find a local PS3 repair shop who can repair this. Do not try to attempt repairs seen on the internet yourself. You could make things much worse and render the unit totally unresponsive. The repair process takes about 3 hours.
    IT CAN BE FIXED
    FOR THE DISC THAT'S STUCK INSIDE.
    Jan 20, 2011 | Sony Playstation 3 (PS3) Console
    Games for my PS3 will only play when i first switch my console on
    maybe it has something to do with the lens.i will advice you send it for maintenance.
    Mar 10, 2010 | Sony Playstation 3 (PS3) Console
    Eject button isn't working
    maybe theres no disc or your wii button needs more pressure
    Feb 18, 2010 | Nintendo Wii Console
    Error occurred.press the eject button and remove the disc. turn the power off and follow the instructions in the console manuel.
    Is it saying this all the time or no? Sometimes it's because the disc in entered backwards or it's dirty. Try resetting the Wii. If it keeps telling you this, the lens is dirty. Purcahse a cd lens cleaning kit and you'll be fine.
    Feb 01, 2010 | Nintendo Wii Console
    Put a playstation 1 game in my ps3 an it wont eject out it beeps twice
    Currently the problem i see here is that you may want to get your disc out first and then check if your PS3 is working fine
    Here's what you need to do to eject the disc:
    Hold Eject button down for 6 seconds (while PS3 is on)
    This should force eject the disc, let me know if this helps
    I am not sure which version of PS3 you are having and which ps1 game you are playing, so please check about backward compatibility of your game here
    Nov 23, 2009 | Sony Playstation 3 (PS3) Console
    Wii won't "take in" disks.
    There is a trigger switch that the disc hits when it is inserted, this tells the consol to pull the disc in, when a disc is ejected the proper way the system retracts the trigger so the disc can be ejected, By pulling the disc out with force your son has either broken the trigger and the consol cannot tell that a disc is inserted, or he has pulled the trigger backwards and the disc is not making contact with the trigger...You will have to disassemble the consol to inspect the trigger (unless you can see it threw the slot) and either place it in its proper setting or super glue it back together.. Another option is to send it in for repair...Hope this helps
    Oct 03, 2009 | Nintendo Wii Console
    Problem with Gamecube game on wii
    about Backward compatibility , maybe a wii update firmware...or you can install a modchip to run gamecube backup discs....
    Sep 10, 2009 | Nintendo Wii Console
    Video Game Consoles & Games Logo
    Top Video Game Consoles & Games Experts
    James Wishart
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
