Intel D945GTP Motherboard
Problem for Intel D945GTP Motherboard
Mb have power but not start...
By princetechno on Jul 30, 2009
d945gcl
Best Solution
posted on Jul 30, 2009
Very Helpful)
cyberdyers
Rank: Guru
Rating: 86%, 148 votes
Hi, good day sir, there are several things you should do first.
1. Disconnect all connections to the motherboard.
2. make sure that your Power Supply 4pin 12volt molex and 24 pin molex connectors are tightly plug.
3. Clean the memory port from any dust, plug the RAM module, make sure also the module connector is clean.
4. Plug in the speaker and power switch.
5. Connect a VGA monitor.
6. Reset bios/cmos or simply operate the pc without the battery.
7. Plug the Power Supply to AC mains.
8. test the PC.
9. do this several times if you cant start the PC.
10. if every thing is OK, reconnect your PC and peripherals one at a time.
Hope this helps.keep me inform about your progress. thanks
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Intel D945GTP Motherboard
Questions and Unsolved Problems for Intel D945GTP Motherboard
Do you recommend Intel D945GTP Motherboard?
Answer
Answer
on automatic on mode when pugged at the wall outlet, continuous on mode, can't be put off
Answer
how do i unlock channels on an ntl set top box?
Answer
Erroe asking me to return tray to normal postion and press reset buttun resume printing
Answer
i have anorthgate motherboard SV266M and i need drivers...video and netowrk etc etc
Answer
power supply stopped working I discovered that when the 4 pin wht plug on the MB is in the pc wont... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Intel D945GTP Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14911
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
