Question about Samsung SRP 270A Matrix Printer
SAMSUNG REAR PROJECTION TV STRANBY/TIMER LED BLINKING
SAMSUNG REAR PROJECTION TV MODEL SP-TR-43T8HE
MODEL CODE SP43T8HEX/SHE
TYPE CP43T8 VER 1 SN/ AAFN31FX00001H
AFTER REPLACING THE MOTHER BOARD BECAUSE THE TV SWITCHED IT SELF OFF WHEN SWITCHED ON THE STANDBY /TIMER LED KEEPS ON FLASHING.
  • 3 Answers
SOURCE: Samsung HCN473W 47 in. Rear Projection can't turn on
i know this is a old problem but in case anyone in the future here has this problem, the problem lies in your convergence board ,mainly the stk`s are shot ,you can buy new STK`s for around 15 to 20 dollars and then will need some one to take old ones of and resoldering the new ones on.
anywho if you have this problem unplug or remove your convergence board and then turn on tv and you will see a picture, all colours will be out of convergence but when you put the fixed board back in colours should realign, or you may have to realign a little yourself.
only reason i am posting on this old problem is because was just given this tv samsung hcn473wx/xac for free and decided to fix it and it now works well.
micheal rose
Posted on May 07, 2009
  • 3 Answers
SOURCE: WILL NOT POWER ON, STANDBY, LED, TIMER LIGHTS ARE BLINKING.
Check the capacitors on the power supply first. If any have domed tops or signs of leakage, replace them. I had two go bad on mine. Call electronics parts supply stores first as these are not your average capacitors.
Posted on Aug 18, 2009
  • 380 Answers
SOURCE: My samsung 5067w dlp tv does not turn on, the
First check the color to see if its spinning or not. Replace it if neccessary. If that's ok, replace lamp and ballast.
Posted on Dec 23, 2009
dmon_67
  • 9 Answers
SOURCE: I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Posted on Jul 12, 2010
  • 1043 Answers
SOURCE: I have a Samsung 56"
Actually the Samsung model you have was the first model to come out in 2006 that did not have a color wheel. The LED blinking is actually a self diagnostic program of sorts. Depending on which lights are blinking, and how often, the service manual will tell you where you should start checking or replacing parts and assemblies. I do have most of the codes, so can you tell me if the if the LED light is the only one flashing, how long it flashes, and do any other lights flash at all? Thank you.
Posted on Feb 20, 2011
What is the problem of samsung sp-46l6hv if i turn on the tv after a few second it is a automatic off and the display the button 3 lights is time lamp and standby mode is blinking when i can turn on t
Sounds like lamp inverter board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Oct 03, 2014 | Samsung Rear projection TV Lamp for...
Tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
on Mar 29, 2011 | Samsung HL-R6167W 61" HDTV
I need a rear projection Tv lamp for a Samsung SP 61L2HX. Lamp code BP96-00271C. I live in sydney and i need it today where can i get one from?
Lamps - Mats Electronics 1-800-628-1118 they have lamps for $89.00 free shipping.
EBay is where I got my Lamp for $83.00 free shipping
Encompass Parts Distribution has Free Service Manual for this Model.1-800-638-3328
Jan 13, 2011 | Samsung HLN5065W 50" Rear Projection...
Screen black, lamp light is blinking Help,,,, is there a manual how to fix ?
The"LAMP"LED light indication is blinking or staying on.Mean ur tv projection lamp life is over.Require u to change a new tv projection lamp.Try website like Youtube.com type ur tv make and model and type in tv projection lamp replacement.There will have a tutoring video by some body teaching u how to do the replacement of the tv projection lamp.
Nov 18, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
I have a SP-47Q7HE Samsung rear projection TV that has 3 pictures that are not aligned. Top and bottom of screen distorted concave and convex?? Any advice appreciated
You need to replace your STK ICs they are big black ics will have part number on them you also need to CK 2 reisitors low ohms in same circuit 2.7ohms Mats has the ICs 9.95-14.95 each.
1-800-628-1118.
Encompass Parts Distribution you can order the whole board if they still have any in stock visit their website and type in your model number or call 1-800-638-3328
Jul 16, 2010 | Samsung HCM4215W 42" Rear Projection...
Tv comes on for about two minutes then shuts down. The lights stay lit.
Any LED light indicators on the screen panel said "LAMP"stay lit or blinking?The projection lamp life is over,require a new lamp,if "LAMP" LED light lite or blinking?The projection lamp in the tv now,been in use for at leat 2 years and tv on about 4 to 5 hours a day?The Lamp life span is over,require a new lamp.
Jun 11, 2010 | Samsung SP 56 K 3 HV 56" Projection...
Led stand by light blinking
No power supply proble Google to Encompass Parts Distribution and type in your model number.
Jun 01, 2010 | Sony KP-46WT520 46" Rear Projection...
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Screen went black you could still hear the tv, timer/standby light is blinking. Is there a projection bulb that goes out. Can this be an easy fix?
U have a LED light indicator said lamp on ur tv?It is blinking?If the LED indicator said lamp is blinking.Than yes,ur projection bulb require changing.Yes replacing bulb pretty easy.
May 01, 2010 | Sony KP-53S70 53" Rear Projection...
Blinking timer light nothing works
have you tried the menu and device buttons held in together to activate the led error code feature? Let me know the error code.
Jul 05, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Samsung SRP 270A Matrix Printer Logo
185 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
