Question about Dell E176FP 17" LCD Monitor
Hii iam pankaj i have dell SE178WFP LCD monitor. My problem is whenever i start my pc monitor shows that it is on power save and monitor starts blinking.. what can be the problem and how it can be resolved.
  • pankajk_19ya Jul 30, 2009
    well you had written Try holding down the fn and f8 keys .. what is fn key write it... i am using xp 200 not vista can u guide another resolution for this problem.
    Sergeant:
  • 263 Answers
Try holding down the fn and f8 keys or if your problem is you cannot wake from power saving mode (after your PC goes to sleep, then its probably just the driver for your video card). VISTA has some issues with certain drivers that the PC cannot wake from sleep
Posted on Jul 30, 2009
I have dell 1905FP monitor and the main menu keeps popping up on & off continually...
lindy3456, A technician will need to look at it!!! Whenever very strange things start happening that YOU know should not be occuring on the screen of your LCD display, you can most likely blame it on the "switch-mode-power-supply" being the culprit!!! Whenever contacting fixya for help, you should ALWAYS include some prior history of the monitor, such as approx total "ON" hours unit has seen during it's life, and the warranty status (in/out) If monitor can be moved to another KNOWN GOOD pc you should try that, to see if it still operates the same or does it suddenly "get well" when connected to different PC. What happens when you conncet a good monitor to your PC? Still work OK? Well, anyway it still seems to me that the SMPS is failing and will eventually not "start-up" one day soon. lmistyrel @aim.com Contact me if still not sure of how to deal with this DELL 1905FP unit. You can also read some of my other stuff in my fixya profile under 12fixlouie aka louie12fix here on fixya. Also FYI you may want to visit www.ccl-la.com/badcaps.htm , and www.lcdparts.net and www.badcaps.net to find out the #1 cause of LCD MONITOR problems and what some owners do to fix them. You should also visit YOUTUBE and view some video clips under "LCD monitor repair" and "LCD monitor disassembly" to understand more fully what is REALLY inside your monitor and makes your screen nice and bright!!! If this was of any interest to you ,please rate this on fixya. Bye for now.
Dec 02, 2009 | Dell UltraSharp 1905FP LCD Monitor
Problem with Dell 2100FP LCD monitor
Unplug monitor form AC outlet, wait for few minutes and plug again.
Check cable attache to PC.
Hope this trick will work.
Sep 30, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell Monitor in Power Save mode
Hello there:
i would refer to your users manual to see if there is a power save mode setting on the monitor it'self and to see how to adjust it or contact the manufacture of the monitor . ok ?
hope that this is helpful
Aug 06, 2009 | Dell E173FP 17" LCD Monitor
LG LCD Monitor L1530S problems
Most screens will show nothing or go to power saving mode until the PC is turned on. The monitors need a signal in order to be 'active'.
From your description it could just as well be a problem with the PC rather than the monitor. The easiest way to find out is to connect another PC or laptop to the screen or connect another monitor to the PC unit.
Did you try pressing the Del key or F2 key when you turn on the unit to get into the Bios?
Jules
Jul 16, 2009 | LG L1530S 15" LCD Monitor
Dell flat panel monitor -power button blinks green to amber - no
One reason that this is happening could be that it is on Power saving mode. This happens when the LCD monitor detecs an incorrect timing then thats the time that the LCD goes blank and the power botton starts to blink.
what you need to do is to turn the computer off. Unplug cables attach to the LCD make sure it is also off, once done press the power botton for a couple of 30secs to a minute and then release. After doing so re-connect all the cables and make sure that both ends is tight and secure once everything is ok turn the computer on same with the monitor to check if it solves the problem.
Jan 10, 2009 | Dell Dimension 2400 PC Desktop
Dell Ultrasharp 24IN FP monitor power saves and does not recover.
disable it from going to power save just turn it off when not in use. your monitor could be having issues with its power supply.
Feb 17, 2018 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Dell Monitor Power save mode activate using pc
yes right click on desktop select properties then click on screen saver then increase wait time problem will solved
Oct 29, 2008 | ViewSonic VE155b 15" LCD Monitor
My LCD monitor is going into power saving mode
Hi...there,
Your monitor enter to power saving mode to prevent further damaged. It's seems you got a busted backlight inverter... Need to replaced a new one or repaired it...
Oct 13, 2008 | Computers & Internet
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Flatron L1719S
I think your monitor is unstable. Is it showing power saving when you boot your PC? Does it show something when the Windows XP splash appears?
Jun 05, 2007 | LG Flatron L1750S 17" LCD Monitor
Dell E176FP 17" LCD Monitor Logo
348 people viewed this question
Alun Cox
