Question about Canon PIXMA MX310 All-In-One Printer
Canon MX310 In use/memory light flashing, nothing in memory and unit not in use. Powered down and re powered still the same.
    Novelist:
  • 136 Answers
redtaildesig --
Have you tried to purge the memory? To delete the files in memory:
(I found this at: http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
�� Printing or Deleting a Document in Memory
Press the FAX button, then press the Menu button.
2 Press the [ or ] button to select MEMORY REFERENCE.
3 Press the OK button.
If you'd like to print from memory (I think you already know how,but just in case):
�� Printing a List of Documents in Memory
The machine can print a list of documents stored in memory (the memory list) showing the
transaction number (TX/RX NO.), transaction mode, recipient, number of pages, date, and
transmission time of each document. When printing or deleting documents in memory, specify a
document by its transaction number.
1 Press the FAX button, then press the Menu button.
3 Press the OK button two times.
The memory list is printed.
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
Posted on Sep 09, 2009
I have a separate fax line for my Canon MX310. It goes into fax mode but noting happens. I also cannot receive faxes.
The only reason to call the phone company is if you're not getting a dial tone on that line. Otherwise, have you shut down the printer and tried to reset it to factory defaults. To do that, follow the instructions below:
  • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
  • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
  • 3 Release "Stop/Reset" while holding down the "Power" button.
  • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
  • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
  • 6 Push the "Power" button, then lift the MX310 cover open.
  • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
  • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
  • Good Luck Mark
Feb 20, 2015 | Canon PIXMA MX310 All-In-One Printer
Printer does not print
Instructions
Jul 23, 2014 | Canon PIXMA MX310 All-In-One Printer
MX310 green light flashing and beeping. Won't turn off or reset
You can restart splooler....
--Right click on my computer
--click on manage (a new window open)
--to the left look for Services and application and double click
--this will drop down the some task.
--click on services
--then to your right look for the print splooler
--right click and click on restart.
Mar 04, 2013 | Canon PIXMA MX310 All-In-One Printer
When I try to send a fax I get a redo message and no pages are sent...i have sent many faxes to this number....a message appeared after one page was scanned that said to prress clear and srop...i could not...
Please reset the Printer by following these steps:
Feb 27, 2011 | Canon MX310 Office All-In-One Printer
Canon mx310 says there is a pper jam but I cannot see where the paper is stuck
feed a piece of paper threw and eject it out the other side, then if that fails, try opening and closing the units back, their should be a panel that can be pulled out or opened. check that nothing is obstructing the area, and follow the path of the paper with your eyes, you'll see if anything is out of place. also a simple power down completely unplug unit and plug back in will help.
Dec 21, 2009 | Canon PIXMA MX310 All-In-One Printer
MX310, says receiving fax but nothing comes out.
michael885 -
Your unit has a certain amount of memory designed to store faxes... if they are stored there, here are the instructions for retrieving the fax's from the memory:
Hope this helps!
-- RT
Aug 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Looks like I have an incoming fax: screen reads, "received in mem
You have the fax setting to use memory or no paper loaded.
Go to the fax menu and change it to print.
Jun 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Our Canon MX310 printer is flashing Waiting For Report and the In use/memory light is on all the time. There are not reports to print as far as we can see
  1. Remove all print jobs at your computer
  2. Turn off printer
  3. Disconnect printer power supply
  4. Wait 30 seconds
  5. Reconnect printer power supply
  6. Turn on printer
May 07, 2009 | Canon PIXMA MX310 All-In-One Printer
Beeps when I plug in power
Sounds terminal. The good thing is that machine would have to be under 12 months old. So it is under warranty. I would advise you to get it repaired under warranty as it would be to expensive otherwise.
Mar 08, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
1,841 people viewed this question
old marine
old marine
