Question about Hitachi 57S715 57" Rear Projection HDTV
Picture problems I was watching a movie, when the screen got progressively darker, and the skin colors are now a red hue.  Any help much appreciated.   Thanks
  • MIchael Van Ness
    MIchael Van Ness Nov 24, 2007
    I took the back cover off the tv to have a look inside...i am a hvac tech not a tv tech...thought maybe i would see some obvious damage to the board or smell some electrical damage, when i turned the tv back on, everything was working ok..what happened??
  • jiq5 Dec 11, 2007
    color for most stations off too red and whites are grey blue.
  • 244 Answers
Retrace lines on picture, 60V on RGB transistors
C700 (100nF, 250V) seems to be leaky, but main problem is R723 which had gone from 27R to 1.2M, both on CRT board
Posted on Nov 24, 2007
No green or yellow color
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 29, 2017 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Red blue hue on picture
ur color setting has certain problem. from ur remote control go to color setting and set ur req.color
Mar 10, 2012 | Televison & Video
Television is a Tosiba DLP 72HM195
your tv needs a y-load board its like a grafix card as computers have due to overheating the board components are affected this is a manufacturing fault it tends to happen with samsung aswell
Feb 22, 2012 | Toshiba 72HM195 72" HDTV
Someone pressed 'a button' on the remote - now there is no yellow on the screen - yikes - lots of red and green! How do I fix this?
Go to the menu screen and look for picture options and then look for color or Hue on the menu, this will allow you to change the hue and correct the color balance. I have a Sony and there is a yellow button on mine and it changes the settings to what they call Cinama scene and when I press this it makes the picture darker and more yello. Mine is a Sony and yours may be different.
Dec 31, 2010 | Philips Televison & Video
Toshiba Rear Projection TV picture color is now a greenish hue
Hi, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
If you are not able to adjust the convergence using the remote you will need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Such as: Red moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from
Hope this helps :)
Sep 12, 2009 | Toshiba 50H82 50" Rear Projection...
Picture has become progressively dark 27'' TV JVC AV-27320
disgaussing will not help this problem..i am scared your picture tube problem or try to change the crt socket first it is not cost much
Jul 01, 2009 | Televison & Video
Sony-kp51ws510 picture turns to a blue hue with flickering colors
hello there this is an easy fix unplug the tv and take the back of the set, once inside the set you will see 3 coloured bulbs and a big mirror in the back theses over time get dusty and dirty and if you smoke it can get really bad you simply just need to clean the bulbs and the mirror with computer screen wipes or some sort of window cleaner be sure not to get everything wet inside this should sort if for you nice and clear again!
Thanks For Using FixYa
Feb 07, 2009 | Sony KP-51WS510 51" Rear Projection...
Problem with color
Yes you have a problem in the red crt driver board. Most likely the driver transistor is failing. This is a component level repair, so if you have no experience with TV repair, play it safe and call in a trained tech to assist you in this matter. Good Luck
Jun 05, 2007 | Mitsubishi VS-50609 50" Rear Projection...
Strange picture issues
check near lineoutput transformer low value resistor eiher open circuit or high needs technician
Mar 18, 2007 | Samsung DynaFlat TX-P3064W 30" TV
Sony kv-32hv600 picture problems
Problem 1. Color patches at lower corners. These are caused by magnetic sources close to the TV. Do you have any Speakers close to the sides of the TV? Are they Magnetically sheilded? No? Move them away from the TV. Problem should then resolve itself in a couple of days. Problem2. Screen Slumping. Most likely a problem with the Pin cushion correction ckts. Get a good technician to have look. cost should not be much. Under 100$ plus Technician fees.
Aug 18, 2006 | Sony FD Trinitron KV-32HV600 32" TV
Hitachi 57S715 57" Rear Projection HDTV Logo
65 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
