USB Connection My qustien is :Can I connect an external Hard Drive directlly by USB connection as LAN storage?
  • 143 Answers
You have the LAN to USB converters but i guess no USB to LAN converters in the market
Posted on Jul 30, 2009
I have a spare Seagate ST3160215ACE hard drive and want to use it for desktop external storage. Please advise if it is suitable and what connectors/cables are required to fit into enclosure.
You need an USB hard drive adapter case that supports IDE ATA data connection.
The hard drive fits inside the adapter case and does not require a connecting cable. The adapter case should be supplied with an USB cable.
Mar 14, 2013 | Computers & Internet
External drive not picked up on computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | Samsung G3 Station Desktop External Drive...
A blue and red flashing light and won't connect to computer
Hope this helps.
Nov 22, 2012 | NexxTech new 3.5-inch hard drive enclosure...
Iintend to change my sata hard drive to a SSD hard drive.How do I format before change
When you install Windows on your new SSD hard drive you can then transfer data from your old hard drive using an USB hard drive adapter or install the old hard drive into an USB hard drive adapter case and use it as an USB external hard drive after you have transferred your data to your laptop.
When you connect the USB hard drive adapter to the laptop, the laptop will see it as an external storage device, you can then open the various folders anf files and copy them to your new hard disk.
Apr 07, 2012 | Dell Computers & Internet
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
My computer says check cable connection PXE-MOF:exitiing intel PXE ROM. no bootable device--insert boot disk and press any key. What does it mean, and how do i fix this?
Check your bios and make sure that your boot from lan is disabled, and check the boot order. Make sure that your CD rom is first, then your hard drive, then boot from lan. Boot from lan needs to be one of the lasts you use if you use your laptop for personal use.
Also make sure any USB devices, like flash storage or external hard drives are disconnected from the computer.
May 03, 2011 | Acer Aspire One Netbook 8.9" Notebook
How can I get my Belkin router to read my Seagate storage device so that all computers in the house can access said Seagate storage device?
1) Turn off your wireless router and unplug the external hard drive you want to make wireless.
2) Plug an Ethernet cable to the "Network-attached storage" device, and the other end of the cable to an available Ethernet port on your wireless router.
3) Connect one end of the USB cable to the wireless router's available USB port and the other end of the USB cable to your "External" hard drive.
4) Turn on the both the Wireless router and the External hard drive. Make sure that your Internet connection is still working.
5) Insert the installation CD and run it on your computer. Follow the installation instructions and install any utilities related to your external hard drive. There may be special utilities provided for flash drives that are not needed for hard drives.
6) Create a login name and security password for the "NAS" device during the setup process. When the installation process is completed, you will now be able to use your external hard drive.
Apr 10, 2011 | Computers & Internet
ACER ASPIRE ONE D150 - Wired LAN connectivity problem.
hello ptwebster,
please give more details on your mode of connection,ie is the Iomega drive connected to another computer on your network?is it a Network Storage Device?
Feb 04, 2010 | Acer Aspire One PC Notebook
Hello, I plugged in my iomega 1tb desktop hard drive storage device and the drive does not appear in my drive or computer. I do have the new hardware 'sound' that comes up but I dont have the drive show up...
Iomega 1TB Desktop Hard Drive is a dedicated usb 2.0 plug and play external storage device that has an ability to transfer at 480Mbits/second. having these large capacity storage drive needs a fast connection and additional power source to make sure to run the external unit system properly.
just make sure both power and data cables are properly plugged and connected respectively. if you are using it with a desktop, please always plug your usb connection from the Iomega 1TB external drive to the rear USB port in line where you built-in LAN is.do not plug it in the frontload ports. some motherboard manufacturers uses usb 1 and/or 1.1 only for frontload desktop casing provision.
thank you.
Dec 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Stand-alone networking
What you want is called a NAS, Networked Attached Storage, which is generally a relatively small device with its own hard drives, a network connection, and a dedicated computer to perform file serving tasks and network communications. Unfortunately, your FreeAgent is only a hard drive, with no file server or network connection, so it must be attached directly to a computer through its USB connection if it is a FreeAgent 500GB, or through its USB, firewire, or eSata connection if it is a FreeAgent Pro 500GB.
There are some NAS's which have USB ports, and if you were to purchase one (not cheap), you could connect your FreeAgent to it as additional storage.
Although probably an unsatisfactory answer, I hope this helps you plan your next step.
Dec 05, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
David Payne
David Payne
