Question about Toshiba Tecra M2-S730 Notebook
No display to screen
I got a tecra m2 the problem is the scree, there is no display to it, the screen lights up, but no display just a couple of faint lines on it. but if i plug it into a external monitor it works, on that.
    Sergeant:
  • 263 Answers
Lookslike the screen has given up the ghost then,a replacement screen would cost a few quid and to get a repair expert to put it in even more costly.John
Posted on Jul 30, 2009
  • 805 Answers
May be ur AGP card problem to ur pc. or u can check ur lcd monitor cable that is there any leckage. if not found then u can take step what i say. have u installed ur motherboard driver? if not then install it. if not become ok then plz take it to the professional hardware engineer . thanks
I have a cracked screen (toshiba tecra m2) and have an opportunity to buy a replacement screen from a tecra m2 S630 that is broken. Are the screens interchangeable?
Can't answer your screen question, but I can propose a workaround - your Toshiba laptop has a
monitor port on the back - you can plug in a standard monitor, and ignore the cracked screen
temporarily until you can replace it. hope this helps
The monitor port is the 15-pin analog VGA D-shell (female) port.
The online User's Guide for your Toshiba Tecra m2-S630
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=596874&rpn=PTM20U&modelFilter=M2-S630&selCategory=2756709&selFamily=1073768664
Apr 17, 2011 | Toshiba Tecra M2-S630 Notebook
I have a tecra m2-s730 that displays the boot screen then back light goes out but you can still see image..what could be problem
1) test it to an external source like a tv, or external monitor through the vga ports, svideo ports. If promblem is solved, and everything seems to be going normal, then your screen is history, bad backlighting and needs screen replacement. 2) Bootup screens seems to work fine, ( like it has backlighting and light all work fine and normal) but when it turns over to loading your o/s and it get dark even with a external monitor, then it's a driver issue or your vga chipset is bad and you will need to replace your motherboard, ( in this case it is best to buy a new laptop). 3) Bios error issue, bios has become currupt somehow, you can try loading default value given in the exit tab in your bios menu. Load and save and exit. See if it works, if not your VGA chipset is screw, and motherboard will need to be replaced to fix this issue.
Jan 30, 2011 | Toshiba Tecra M2-S730 Notebook
I have a toshiba tecra m2 when i power on it will display the logo for a sec then go blank i can see that the backlight is lit i tryed powering on again and as soon as i see the logo i pres f2 and it stays...
Dear anthonylopes,
Is this toshiba tecra m2 new? try to send them back to the store you bought from and ask for another new replacement concerning the full guarantee from toshiba! If it's not, try to run the bootable CD (Windows XP as an example) then, if you don't see the dialog or message from Instalation CD, I convince that the problem might be with your inverter!
GoodLuck!
Best Regards,
bionic23
Dec 08, 2009 | Toshiba LCD Display for Tecra M2, M2V
Toshiba Tecra M2 Video and Fan Problems
i think your charger have some problem, check it.
Jun 30, 2009 | Toshiba Tecra M2-S530 Notebook
Display fault
Sounds like a bad screen. If you hook up your computer to an external monitor and it's okay there, then that should confirm it.
Dec 25, 2008 | Toshiba TECRA 8000 13.3" TFT LCD Display...
Driver required NETWORK CONTROLLER for Toshiba tecra m2
i can not find the wireless lan driver for tecra m2
Oct 05, 2008 | Toshiba Tecra M2-S730 Notebook
Toshiba tecra 8100 no display
this problem occurs in the video chipset,because when you hook up the external vga there is no display right?
if you hook up the vga into the monitor it would come display if the problem only with inverter or lcd.
Jul 07, 2008 | Toshiba Tecra M2 Notebook
Tecra M2 screen failure
Bad RAM probably bad system board. You say there are flashes usually you can check any available beep or flash codes. Sometimes they will tell you what has malfunctioned. Check the mfg. website or manual for diagnostic codes. As for the external monitor you will have to press function F4 or F8 or whatever function key you have with a monitor picture to switch to the external display. Hack
Jul 07, 2007 | Toshiba Tecra M2 Notebook
Toshiba Tecra M2-S730 Notebook Logo
197 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
