Question about Apple iPod touch
Dang... i have an ipod touch 16gb.. but it doesn't the wi-fi doesnt' work.. i have the router called the 3 com and i dont have the maual for it.. anyone have anwers?
    Problem Solver:
  • 16 Answers
I think it is that your network might have a password or that you have accidentally selected a different network or that you have to select Ask to join network. Good Luck!
Posted on Jul 30, 2009
How do i find the wifi password for my ipod touch
Step 1:
The wifi password is on your wifi router, hopefully someone wrote it down and taped it to your router, if not you need to loginto your router to find out what it is.
Once you have the password:
Step 2:
On your ipod touch
Verify Wi-Fi is enabled and that you are connected to a Wi-Fi network.
Tap Settings > Wi-Fi. If Wi-Fi is off, turn it on by tapping the on/off icon.
Available Wi-Fi networks appears under "Choose a Network..."
Locate and tap the Wi-Fi network you want to join then enter your password
Jan 29, 2013 | Arris Comcast/xfinity Tm502g/tm722g, 702g...
How to set up wifi
If you're at home with a Wi-Fi router:
Goto "Settings" - "Wi-Fi"
Your router should appear in the list, if it doesn't - try restarting your router.
When you select your router it will most probably ask you for a password. This can be found under your router as MAC or WPA Key
You'll need a password for the majority of wi-fi hotspots you try connect to, although there are apps which will direct you to free hotspots.
May 30, 2011 | Apple iPod touch
Ipod wi fi conection
Wi-Fi Functionality
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, iPod touch will scan for Wi-Fi networks and show a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show a lock icon (307189_1.jpg) next to them.
  3. Option to manually enter your Wi-Fi network name/SSID (if the Wi-Fi network is configured not to broadcast or be displayed to the public). If necessary, enter the password to join.
When iPod touch is connected to a Wi-Fi network, the Wi-Fi icon (307189_2.jpg) in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
Wi-Fi Settings
  1. Turn Wi-Fi on or off.
    Choose Settings > Wi-Fi and turn Wi-Fi on or off.
  2. Set iPod touch to ask if you want to join a new Wi-Fi network.
    When you are trying to access the Internet, by using Safari or YouTube for example, and you are not in range of a Wi-Fi network you have previously used, this option tells iPod touch to look for another network. iPod touch will display a list of all available Wi-Fi networks that you can choose from. Networks that require a password appear with a lock icon (307189_1.jpg).
    If "Ask to Join Networks" is turned off, you must manually join a network to connect to the Internet when a previously used network is unavailable.
    Choose Wi-Fi and turn "Ask to Join Networks" on or off. If you turn "Ask to Join Networks" off, you must join new networks manually.
  3. Join a Wi-Fi network manually.
    Choose Wi-Fi, wait a moment as iPod touch detects networks in range, then choose a network. If necessary, enter a password and tap Join. Networks that require a password appear with a lock icon.
  4. Make iPod touch forget a network, so that the device doesn't join it automatically. Choose Wi-Fi and tap the arrow (307189_3.jpg) next to a network you've joined before. Then tap "Forget this Network."
  5. Connect to a closed Wi-Fi network (an available Wi-Fi network that isn't shown in the list of scanned networks).
    Choose Wi-Fi, then tap Other and enter the network name. If the network requires a password, choose Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. Ask the network administrator which settings to use.
  6. Adjust settings to connect to a Wi-Fi network
    Choose Wi-Fi, then tap the arrow (307189_3.jpg) next to a network.
Dec 27, 2010 | Cisco Linksys Wirelessn Router Black...
My ipod touch is not connecting to the internet even though my wireless router is up and running
DEAR SIR, YOUR IPOD TOUCH IS NOT CONNECTING, IT MAY B THE REASON THAT UR IPOD'S WI-FI IS NOT WORKING OR SETTINGS OF WI-FI ARE NOT CORRECTLY DONE. KINDLY DO SETTINGS PROPERLY, IF NOT, THEN CHECK THAT YOUR ROUTER IS PROCESSING YOUR WI-FI OR NOT. THANKS. PLEASE RATE ME...
Feb 10, 2010 | Computers & Internet
Wi-fi problems
Are you having this problem with a particular network or all networks, if it is a particular network try resetting your router and then reentering the password on your touch.
Mar 23, 2009 | Apple iPod touch
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
HELP
All you should have to do is open Wi-Fi in system preferences. From there, touch the little blue circle next to the Wi-Fi network you're signed. Then, just hit "Renew Lease" at the bottom of the screen.
If that doesn't do it, completely turn your modem, Wi-Fi router and iTouch off. After 5 full minutes, turn on the modem, another 2 minutes later, turn on the Wi-Fi router, yet another minute at least, turn on your iTouch.
If that still doesn't work or you have any questions, feel free to call me.
Dan Crowley, iKnowApple.com 919.280.3101
Nov 04, 2008 | Apple iPod touch
Apple iPod touch Logo
47 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
