Question about Tomtom ONE 130 GPS Receiver
Ths GPS Always freezed up - Tomtom ONE 130 GPS Receiver
  • 3 Answers
No one time
Posted on Jul 31, 2009
GPS freezes
Try to describe it more... But you can restart it - usually hold the power button for more than 5s until it reboots. If it doesn't help, try to update the software. That always helped in my case.
Aug 25, 2013 | GPS
TomTom 910 freeze, long turn on
It is possible that the map data(base) and/or the navigation software is corrupted.
Have you tried running a (fix) disk utility against your (internal or external) storage disk for the GPS ?
For instance, connect the GPS to your PC (Windows), and select (highlight) the (internal) "disk" on the GPS device. Under File - Properties, go to the Tools (tab) and run the "Error-Checking" option.
This utility may fix your data error.
If not, consider doing a restore (from backup) of your GPS disk storage.
Mar 26, 2013 | Tomtom GO 910 GPS Receiver
Help with gps interferanccce
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE
Jan 25, 2011 | Garmin StreetPilot C330 GPS Receiver
How to turn on gps keeps saying gps turned off
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
Jan 23, 2011 | Garmin Nuvi 350 Car GPS Receiver
Update gps
Jan 23, 2011 | Curtis GPD359B GPS Receiver
Evry time used it pop up always your map using more than a yr. how can i updated it?i got it since 006 evrything lost (manual)
Jan 20, 2011 | Pioneer AVIC-S1 GPS Receiver
Trying to find out how to update the Navatlas xnav3550?
I have some problem with my xnav gps(x436),it freezs on me always when i set it up to go some were
Mar 10, 2009 | Dual NavAtlas XNAV3500p GPS Receiver
GPS receiver problem
Does it work with an external antenna hooked up? If it does, it could be a problem with the flip-up internal antenna.
Mar 12, 2007 | Garmin iQue 3600 GPS Receiver
Open Questions:
My tom tom one 130 stays with an orange picture, and a red circle with an X. It also says something about an error when I try to upgrade it... like this.... ERROR: Internal/Malformed#createItemFromDLL/Internal/Malformed: Exception: Lo sentimos pero HOME no puede completar esa tarea. Inténtelo de nuevo más tarde o póngase en contacto con el departamento de atención al cliente. Para resolver los problemas con los elementos almacenados en su dispositivo, le recomendamos eliminar y volver a instalar el elemento. Malformed Item info: name = id = version = 0 locationType = 1252 install location physicalType = 1504 metadata = Severity: 1105 - Internal/Malformed: Malformed: Lo sentimos pero HOME no puede completar esa tarea. Inténtelo de nuevo más tarde o póngase en contacto con el departamento de atención al cliente. Para resolver los problemas con los elementos almacenados en su dispositivo, le recomendamos eliminar y volver a instalar el elemento. Must not be empty Bad value: "" (type: string) Severity: 1105 Stack: 0. chrome://tthome/content/logic/model/ttItemFactory.js:43 let wrapper = new Exception(null, newId); 1. chrome://tthome/content/logic/model/ttItemFactory.js:90 var modelitem = this.createItemFromDLL(dllitem, onlyType); 2. chrome://tthome/content/logic/model/ttItemList.js:55 var models = gApplication.itemFactory.createItemListFromDLL(dllItemList, onlyType); 3. chrome://tthome/content/logic/ttTask.js:315 itemList.addItemListFromDLL(doneLocation.deviceNavItems()); 4. chrome://tthome/content/logic/util.js:79 return func.apply(obj, arguments); 5. chrome://tthome/content/logic/dllUtils.js:73 this._successCallback(this.successText); 6. chrome://tthome/content/logic/dllUtils.js:58 this._success(); CAUSE: Internal/Malformed: Malformed: Lo sentimos pero HOME no puede completar esa tarea. Inténtelo de nuevo más tarde o póngase en contacto con el departamento de atención al cliente. Para resolver los problemas con los elementos almacenados en su dispositivo, le recomendamos eliminar y volver a instalar el elemento. Must not be empty Bad value: "" (type: string) Severity: 1105 Stack: 0. chrome://tthome/content/logic/serverinput.js:84 throw new Malformed("Must not be empty", uc); 1. chrome://tthome/content/logic/serverinput.js:218 var str = this.nonemptystring(uc); 2. chrome://tthome/content/logic/model/ttNavItem.js:265 this._idstr = makeSafe.contentidstr(item.id); 3. chrome://tthome/content/logic/model/subtype/ttVoice.js:36 ttNavItem.prototype.importFromDLL.apply(this, arguments); 4. chrome://tthome/content/logic/model/ttItemFactory.js:39 result.importFromDLL(item); 5. chrome://tthome/content/logic/model/ttItemFactory.js:90 var modelitem = this.createItemFromDLL(dllitem, onlyType); 6. chrome://tthome/content/logic/model/ttItemList.js:55 var models = gApplication.itemFactory.createItemListFromDLL(dllItemList, onlyType); 7. chrome://tthome/content/logic/ttTask.js:315 itemList.addItemListFromDLL(doneLocation.deviceNavItems()); 8. chrome://tthome/content/logic/util.js:79 return func.apply(obj, arguments); 9. chrome://tthome/content/logic/dllUtils.js:73 this._successCallback(this.successText); 10. chrome://tthome/content/logic/dllUtils.js:58 this._success();
Aug 17, 2010 | Tomtom ONE 130 GPS Receiver
See all Tomtom ONE 130 GPS Receiver Questions
Tomtom ONE 130 GPS Receiver Logo
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
