Question about Nintendo Wii Console
Works ok but no color - Nintendo Wii Console
Please check your PAL or NTSC settings on your TV.
if system is set up to work on PAL and your tv is set up to work with NTSC, for example, you will really get no color,
Posted on Jul 30, 2009
Printer has ink but wont print in color test page wont print in color, also aligned printer and it worked in color. cleaned printer head as well which printed all the colors. what else can i do? It seems...
Take color copy, test all colors are OK..Go to printer properties, printing preferences, finishing check is there any check mark on print in black cartridge only? mark on print color..apply..OK.. give print command..
Go to paint draw a color drawing, print it.> check colors if its not printing in color it might be drivers issue.. un install the drivers re install once again check..> if printed in color check the file which you are printed..take another file.. then test..
Oct 29, 2011 | HP Photosmart C6180 All-In-One InkJet...
Printer telling me to replace drum. I replaced all the colors and still not working
you need to reset the counters so the printer knows there is a new drum.
to do so try this:
Turn the printer power switch back on.
Press + or - to choose "Machine Info.".
Press OK to proceed to the next menu level, and then press + or - to choose "Reset Parts Life". Press OK, and then press + to choose "Drum Unit".
Press OK, and then press + or - to choose the color that you replaced.
Press OK two times.
Sep 18, 2011 | Brother HL3070CW Compact Digital Color...
How does one 'colour test' please.
Clean the Printhead & Print a test page by doing the ff:
1. Press the Ink button press the Up or down arrow key to select Test Print, then select Print Quality press OK and press Black or Color START. Check all the colors including the black & check if there are any missing dots and if there are any colors not printing correctly.
2. Press the Ink button on the control panel and select CLEANING press OK.
3. Press the up or down arrow key to select Color press ok and press Black Start.
*After the cleaning process the printer will ask you if the quality is OK, press up or down to select yes or no, and it will ask you whether black or color is ok, once you have selected you're answer press Black or Color START to print another test page. Compare the 1st and 2nd test page if it's improving, you may need to do this 3-5 times or until you get a better quality
Hope this helps Please rate if it worked Thanks!
Apr 03, 2011 | Brother MFC 490cw Color Inkjet...
My Brother inkjet printer (DCP-585CW) is not printing yellow colour.
If the yellow ink is not printing here's what you can do:
1. Press the Ink Management button press the Up or down arrow key to select Test Print, then select Print Quality press OK and press Black or Color START. Check all the colors including the black & check if there are any missing dots and if there are any colors not printing correctly.
2. Press the Ink Management button on the control panel and select cleaning press ok
Hope this helps.
Rate if it worked Thanks!
Apr 03, 2011 | Brother DCP585cw AllInOne InkJet Printer
Cyan ink is coming out purple. Tried putting in brand new toner but still have the same problem!
If the cyan or the blue ink is printing out in purple here's what you can do:
Mar 31, 2011 | Brother DCP 165C Compact Color Inkjet...
Can't get color when playing color movies, picturee is in black and white. sound OK. tv color OK when watching tv only. Visio TV, memorex home theatre vcr. what's the problem.
Any number of problems can cause no color. For example, a very dirty video head, a defective head or even mechanical misalignment to name a few. Try using a wet type head cleaner, they seem to work better for excessive dirt on the video heads which is usually the problem with no color and is the easiest to fix.
Let me know how this works out for you.
Benjamin
Jan 31, 2010 | Memorex Televison & Video
Color rendition is way off on Brother 4050 (4040/4070)
Run a self calibration cycle a couple of times, and also clean the laser scanners.
Nov 22, 2017 | Brother HL-4040CN Laser Printer
450c color problem
The 430 ID is B/W, you need to load the 450C driver to get color, renaming the driver isn't enough.
Oct 13, 2008 | HP DesignJet 450c InkJet Printer
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Nintendo Wii Console Logo
109 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
