Question about Refrigerators
Bad smell in tray at rear of fridge
Hi, I have a small whirlpool fridge with an icemaker compartment (can't find the model no. anywhere, not even in the booklet that came with it). There is a horrible smell coming from a tray at the bottom back of the fridge which is hooked on to some pipes. Can I remove this and if so how - it won't seem to budge. I can see there is brown liquid in there which must be the smell!
  • rubydos Dec 04, 2009
    have a smell at the back of my fridge, there is some water in a tray at the back but i cant take it out cause its contected to some pipes
  • 162 Answers
Maybe you could use a wet/dry shop vac to clean it out
Posted on Jul 30, 2009
Whirlpool fridge making a low, intermitant groaning sound
Is it coming from inside fridge compartment or freezer compartment or from outside back. If it is from freezer compartment and you have no water line connected to ice maker. Then it might be just your ice maker trying to go into fake harvesting mode. Make sure the Icemaker is off. Icemaker arm should be up.
Oct 14, 2014 | Whirlpool Refrigerators
Whirlpool SXS.....1. compressor cooling fan quit so fridge and freezer stopped working. 2. replaced cooling fan and fridge and freezer working again. 3. Now the fridge and freezer works but runs nonst
Check to see if the sensor in the freezer compartment is encased in ice. If so, do a complete defrost and restart the unit. Another possibility is a bad thermostat and/or sensor.
Jul 25, 2012 | Whirlpool Refrigerators
KitchenAid fridge ice cubes taste and smell bad
Permanently place a black coal in your fridge to avoid bad smells.
Apr 12, 2012 | KitchenAid Superba Architect KSCS25INSS...
The icemaker whirlpool gold model GRZSHWPBOZ
either the water valve is bad if so replace it or the tube that delivers the water to the tray is frozen . ck both and replace the one that is bad . hopt this helps mm ..
Apr 06, 2010 | Refrigerators
I have water pooling on my fridge trays and than turning into ice . The water seems to be coming from the vents. How do i get rid of that.
The freezer compartment has a drain hole behind the back wall inside the freezer compartment. The drain hole has probably rusted and has gotten larger. Carefully remove the icemaker and the screws from the back wall inside the freezer compartment. Lift the bottom of the back wall and look to see if the drain hole has gotten larger. You can make a small funnel from an aluminum can to fit over this area directing the water into the drain tube. It worked for me. good luck. Dave.
May 10, 2009 | Whirlpool ET9FHTXM Top Freezer...
A really bad smell coming from the fridge
I had a similar problem with an unbearable smell, not inside, but outside the refregeration compartment. it was from the defrosted liquid that gets stored in a small open tank at the bottom on the rear side of the fridge. over time , particles settle along with water and gives a rooten smell, cleaning this tank solved it.
Hope this helps,
Feb 10, 2009 | Samsung CoolTech Plus / Basic Bottom Mount...
I have a whilpool ed22rf fridge the icemaker cycles but no water goes to the icemaker. i have water @ the fridge,dispenser,and @ the valve
hi thanks for the question. A small tube goes in the ice maker it directs the water in the tray .Some times it will freeze up . check that if not frozen the ice maker water valve is the source of the problem thanks the appliance doc
Sep 29, 2008 | Whirlpool Refrigerators
Very bad tasting/smelling water and ice cubes - Superba KSRS27QAAL05
Since I found that the water itself being fed to the trays and being dispensed was bad. I replace the nylon, reinforced plastice icemaker hose with 1/4" copper supply line. That, along with purging the hopper (getting rid of) any old ice as well as washing the hopper out real good and giving the freezer a general cleaning - seemed to do the trick. No repugnant odor or taste. (I didn't even replace the filter- the cycle is every 6 mos.)
Hope this helps others who may be experiencing this same prob with this type of side by side appliance.
Lou
Jul 30, 2008 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Nov 08, 2007 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
138 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
