Question about Stamina Products Stamina Pro 5300 Silent Magnetic Resistance Upright Bike
My pedal broke off after 2 months. the threads
My pedal broke off after 2 months. the threads are stripped. How do I repair it.
    Sergeant:
    Champion:
  • 246 Answers
Get yourself some J-B WELD. It is packaged in two tubes. One contains liquid steel/epoxy resin, and the other contains hardener.
Works like a normal two part epoxy, but when it dries it is incredibly strong. You can sand and shape it as well. Just mix it as stated on package and put some on your stripped threads and get er back in the hole. Leave some excess epoxy around the outside for extra strength, which you can file, grind, or sand later, but let it set for at least 24 hours before peddling your **** off again.
Posted on Jul 30, 2009
    Sergeant:
  • 308 Answers
You can change the because its hard to repair the threads. just got to a repair man and let him repair it.
Model :x 3519 right pedal stripped
If it is the pedal's threads that are stripped just purchase a new pair. If it is the threads on the crank that the pedal goes into then either replace the crank arm if it's the left side or find a bike shop that can install a "Helicoil" to repair the crank. Threads will be stronger than the original
Jul 31, 2017 | Cycling
There are no threads on the crank arm to screw a pedal on. What do you do now?
1. replace the crank.
2. Purchase a Heli-Coil or other brand at an auto store. It looks like a tube with threads on both sides that will screw in to the stripped hole and there by install new threads. Bring the pedal to the auto store to make sure it will thread in to the "female" threads on the Heli-coil.
The problem is the pedal is steel and the crank arm is soft aluminum. Also, people damage them because one pedal is normal thread and the other is reverse thread meaning you turn clockwise to loosen.
Jul 29, 2014 | Mongoose 26" Mens XR-75 Mountain Bike
Pedal stripped
You will need to have that crank arm replaced. They do make repair threads, but the price to install is just as much as replacing the crank arm. Your local bike shop can provide the correct parts.
Mar 28, 2014 | Schwinn Cycling
Stripped bicycle pedal
Better replace the pedal and most probably the crank arm as well. Sometimes a new pedal can cut the threads true again on the crank arm but the crank arm may need replacement too, depending on the damage. Remember to fit the correct side pedal. The pedal threads differ between left and right and pedals are usually marked "L" or "R".
Jan 04, 2014 | Huffy 26" Womens DS-7 Dual Suspension...
Huffy pedal
You need to replace the pedals( they come in pairs) but you have to make sure the crank arm isn't stripped also...if it is you'll have to replace that as well. That usually happens because the pedal wasn't tightened right in the first place
Aug 12, 2013 | Cycling
The pedal assembly on my blackwater somehow got stripped always had problem with pedals coming off
If the thread on the crank arms that hold the pedals are stripped, you will need a new set of cranks. That is definitely a job for the bike shop. Make sure the pedals are snug in the arm, Right side pedal has right-hand thread, left side (looking down when you are on the bike) has a left-hand (reverse!) thread.
Jul 10, 2011 | Huffy Blackwater Men's 26-Inch Mountain...
Left pedal broke can i get replacement?
All depends on if you stripped the crank arm, you may have to replace your crank arm if you rode with a loose pedal. Pedals are sold in pairs, and there are 2 sizes, a one piece crank is 1/2" and 3 piece crank is 9/16", take your bike to the bike shop and they will tell you if you need a new crank arm or not. It will do no good to just replace your pedal if there is a bad crank arm thread, it will not hold.
Sep 26, 2010 | Cycling
My bicycle pedal is stripped and I can't get one on. How do I fix this? Thanx
Depending on left or right you will first need a crank puller to remove the crank in order to replace it. You will be better off taking it to a bicycle repair shop. Cranks usually only come in sets but the shop may have a spare or they might be able to order you a seperate one. The same applies for pedals. If the threads in the crank are not too damaged you might just need a new set of pedals or one replacement. Hope this helps.
May 21, 2009 | Dunlop Standard Tortex .60mm/ 12pack
Plastic under flush handle stripped.
If the threads are not stripped on the nut or handle it should be fine. IMPORTANT TO KNOW!!! These are left handed threads, Meaning they tighten up the opposite way of a normal nut and bolt. If the threads are bad or damaged, you will have to purchase a new flush handle. They are not expensive at all. $2 - $10 Dollars. But first try screwing the nut on by turning it to the left instead of the right.
Dec 31, 2008 | Pegasus Technologies Two-Piece Round...
Stamina Products Stamina Pro 5300 Silent Magnetic Resistance Upright Bike Logo
176 people viewed this question
Top Stamina Products Cycling Experts
John Egan
John Egan
Are you a Stamina Products Cycling Expert? Answer questions, earn points and help others
