Question about Samsung SyncMaster 920NW Monitor
Pink color My Samsung SyncMaster 920NW Monitor have pink color on upper half of screen.
    Problem Solver:
  • 17 Answers
It could be 1 of 2 thing
1; the cable connecting the monitor to your computer is damaged/not connected properly. This can commonly cause a red/ green/ blue tinge on the screen. Check all connections to see if this is the problem
2; the monitor was dropped or banged causing a "pinch" or crack in the screen.
an easy way to test if this is the problem is to squeeze the casing of the monitor to see if the banding goes away
if this is the case try loosening the screws in the casing
DONT REMOVE THE CASING AS THIS IS A SHOCK HAZARD
P.S. dont squeeze front to back as this can cause more damage squeeze side to side to buckle the screen outwards
Posted on Aug 11, 2009
    Sergeant:
    Champion:
  • 283 Answers
Check the led back light of your monitor. I you cant do-it-yourself better to go to service center
Posted on Jul 30, 2009
Syncmaster 2233 turns pink
There are two possible reasons for the color change that I know about. One is simple to fix: a loose video cable. Check that the cable is correctly and tightly seated to both the monitor and the computer. Try a new cable. (If the cable is permanently connected to the monitor, check the computer side of the connection. The cable screws can tighten the connector to the port.)
The other possibility is that the monitor backlight is failing. There are places that sell replacement backlights ( lcdparts.net is one vendor). Unfortunately, you need to take apart the monitor to get the size for the backlights for your monitor. The backlights are usually on the edge sandwiched into the LCD panel and hardware.
I hope this helps.
Mar 13, 2013 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung Syncmaster 204bw has a red screen
A red or pink tint to the screen indicates that the back light bulbs are failing and are about to burn out. Its time to look for a new monitor.
Mar 17, 2012 | Samsung SyncMaster 204BW LCD Monitor
When i start my PC on the screen where there is pink background color their I see all pink color replaced with small - small red pixels .... I have adjust and done all possible method on Menu(Setting)...
Pink and pink streaks are a sign that the CCFL lamp is about to fail. The CCFL lamp provides the backlight to the monitor.
To confirm that the monitor is faulty and not the video card, connect a different monitor to your computer.
To replace the CCFL lamp requires removing the front screen bezel, removing the LCD screen from the frame and the reflector which is located on the bottom edge of the LCD screen. The CCFL lamp is located inside the reflector and the electrical wires on the ends of the CCFL lamp are connected to the inverter board.
Replacement parts are available from these WEB sites.
LCD screens and Inverters www.lcdparts.net http://www.yallstore.com http://www.shope2.com/ http://www.invertercentral.com/qrySearch.asp?Adword=1500&search=1500&Campaign=Google-Models-NA&gclid=CO3lg7HJlKMCFQcbewodZB2qoQ http://www.nylaptopparts.com/ http://www.ccflwarehouse.com/
May 14, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
Dark screen samsung syncmaster 920 N strange noise behind it
The clicking sound you hear is the power supply board trying to start up, this indicates the board has failed. This is a common problem with all LCD monitors after a few years of use. Parts called capacitors on the power supply board fail and they will keep the power supply from starting up correctly. If you can solder then you can repair the board yourself. Here is a link to a repair guide with pictures and videos showing how to dis-assemble the unit and then what to look for and replace to rebuild the board and get the unit back running.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
I hope this helps, if so please rate my solution.
BuddyMc
Dec 19, 2009 | Samsung SyncMaster 920NW Monitor
VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Sep 11, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung syncmaster 920nw LCD uppar half not clear
I think this is not the problem with the monitor. Pl replace a VGA Card or Express AGP Card and try.
Aug 23, 2009 | Computers & Internet
My screan has lost white colour and now it displays pink colour.
check your video cable....this is a common problem when a certain pin in the connector is loose
Aug 16, 2009 | Samsung SyncMaster 920NW Monitor
My monitor suddenly altered the colors on the screen; white background now appears slightly pink, green appears black. How can I make adjustment to correct the color?
your monitor is either going bad or your display setting are messed up.use the buttons on the front and mess with color option if that don't work then you need a new monitor
Aug 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Added as 2nd monitor, color PINK
Check the cable...are any of the pins damaged, bent or missing? Can you access the Monitors control panel and reset its settings to factory default?
May 17, 2009 | Samsung SyncMaster 920NW Monitor
LCD Monitor Half Screen Pink
sounds like a color balance issue. Check the menu, do a degauss...and then check for the color temperature (reset for default)..
Got backup?
Feb 10, 2008 | Proview PL 566s 15" Flat Panel LCD Monitor
Samsung SyncMaster 920NW Monitor Logo
314 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
