SOURCE: the temperature display in renault laguna
Buy a new sensor from renault £42, find which door mirrow the sensor is in, its the one with a black bump at the bottom of the mirror, take off the door mirror and remove the glass. remove the sensor and cut the two black wires coming from it, solder the new sensor to the ends of the cut wires in the mirror housing. make sure you use waterproff tape to cove the exposed wires. put every thing back as you found it ,,job done I did it and it works
SOURCE: air con and fan display not working
check all the fuses first....or .get a control box from a wrecker and change it.remove the cover plate with a flat blade and the head unit for the climate control has 4 bolts holding it in.
SOURCE: Batt Lo Displayed. I replaced with new batteries.
sometimes you can bend out the battery holders to allow more tention on the batteries but thats only a temporary repair. a new thermostat is needed
Testimonial: "Thanks! It appears that you are right--I even tried other "new"batteries....Off to buy a new thermostat."
SOURCE: Heater not blowing hot air display says lo
when the coils freeze up , from intake of outside air, when using the heat pump mode, the unit will try to defrost the coils before going back to heat mode. mine did this alot. does it kick back to heat after a few mins? also after 2 years , mine started having issues with the exhaust blower control and would go into warp mode and bang noise.seems like common issues for this unit.whether the amana, or haier version.
SOURCE: Air conditioner is turning on
Hello Naeva
Plesae visit the link provided below :
http://www.mylg.co.uk/data%20for%20site/Multi%20F_dx_%20Fault%20Codes%20-%20Nov%2007.pdf
http://www.abacusairconditioning.co.uk/lg%20split%20codes.pdf
http://www.ehow.com/info_7983149_lg-air-conditioner-error-codes.html
