Question about GE Washing Machines
Why has my 4 month old washer been fixed twice for shaking?
    President:
  • 2,559 Answers
It sounds like a defective unit,Have them replace it with a new one.
Posted on Jul 30, 2009
I bought a honda crv at carmax more than a month ago,i returned it twice for the repair of the wobbling which is coming from the wheels but werent able to fix.it shakes when it reaches from 20 to 50 mph..a...
here's some knowledge/amminuation
for you..
http://www.crvownersclub.com/forums/19-maintenance-service/118682-2003-crv-5sp-shakes-under-load-20-50mph.html
Jan 11, 2018 | Honda CR-V Cars & Trucks
Hello. I have a Amana top laod washer. My washer will spin(i can hear it spin and see it shakes as it spin). My washer will not fill with water when I turn it to a washer cycle. No water will fill in this...
If you're not getting any water (hot or cold), you'll need to check voltage coming to the solenoid valve. This is the valve the hoses connect to on the back of the washer. If you're not getting voltage during the fill cycle, your timer is the most likely culprit.
Jan 01, 2018 | Amana Washing Machines
Washing machine is really loud when spinning (sounds like a plane taking off)and if you are sitting on couch one floor down you can feel the couch vibrate and the floor its on shakes like crazy. I was told...
no it is not normal and there so be no reasonable excuse for bad vibrations and shaking on a new machine ,if the setting up instructions and leveling procedures were carried out.
at six months it should be still under warranty so have it fixed under the warranty
Apr 23, 2017 | Maytag MHWZ400T Front Load Washer
GE WHRE5550HWW Excessive Shaking in spin cycle
Replace your stablizers, one of them has broken.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 16, 2008 | Washing Machines
Whirlpool duet sport washer 3.6 WFW8410SW cycle will not start
set it to spin dran cycle and select no spin and push the rinse hold button 4 times it should read c00 on the dis play and go thew to c08 it will lock the door frist and then go thew all the cycles it will flash on a c# that has trouble
Nov 29, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washer wont rinse
you have a pump problem, need to lean washer back ageist wall go under washer. front left take off both hoses stick finger in pump remove all items from pump &hoses should work now
Aug 04, 2008 | Maytag MAH2400A Front Load Washer
Hotpoint BWM 129 washer
ARE THE PADDELS BREAKING OR MELTING.
Jul 16, 2008 | Hotpoint BWM12 Front Load Washer
F11 code washer locks up
We've had this problem for about a yr when i finally firgured out how to correct it. the problem is that the circuit board is attached to the washer, when it starts to shake it causes the connections to loosen and theats the fault code you get. How I fixed this was to suspend the circuit from a bungie strap this will allow the washer to shake all it wants and the circuit board is stable, connections stay tight andwasher works fine, after 6 months not one error code at all
Aug 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Washer
not familiar with this machine being in uk not us but would suspect problem with door interlock. very unlikely to be timer
Apr 18, 2007 | Kenmore 27032
Washing Machines Logo
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
