I drained the tranaxle oil in my 87 chev spectrum but Where do you fill the transaxle with oil? Is there another bolt higher up the transaxle? The manual also calls for 5w 30 oil in the transaxle...is that just regular 5w 30 engine oil?
Toyota Santa Fe engine? there are 3 engines, which one? (size)
is this a Hyundai engine in a Toyota or the reverse? im clueless.
you posted to toy forum section, so>?>>>
first off anything is possible with a plasma cutter. so..... ill not do that
what i will do is post the answer from your missing FSM.
in a word , NO.
2.4 and 2.7L (2 of 3) pasted below Hyundai
2.4L & 2.7L Engines
Before servicing the vehicle, refer to the Precautions Section.
Remove the battery and air cleaner assembly.
Drain the cooling system.
Drain the engine oil.
Drain the transaxle fluid.
Relieve the fuel system pressure.
Disconnect the following electrical connections:
Starter
Alternator
Throttle Position Sensor (TPS)
Power steering switch connector
Oil pressure gauge connector
Back-up lamp switch connector
A/T solenoid inhibitor switch connector
Engine Coolant Temperature (ECT) sensor
Ignition coil
Idle Speed Control (ISC) valve connector
Manifold Absolute Pressure (MAP) sensor
Oxygen (O2S) sensor connector
If equipped with an automatic transaxle, disconnect the oil cooler lines.
Remove or disconnect the following:
Radiator hoses from the engine
Radiator
Engine ground
Brake vacuum hose
Heater hoses at the engine
Throttle cable at the engine
Cruise control cable at the engine, if equipped
Main fuel line at the supply/return pipe
Speedometer cable at the transaxle
Clutch or control cable from the transaxle
Power steering hoses from the pump
Steering dust cover in the engine compartment
Gear box universal joint bolt
Front wheel
Brake caliper and support with wire
Strut lower bolt
Front muffler bolts
Transaxle control rod and extension rod, if equipped with a manual transaxle
Support the transaxle with a jack using the special attachment shown in the accompanying illustration.
Attach the special tool to the transaxle jack and support the transaxle
Make sure all cable, harness connectors and hoses are disconnected from the engine and transaxle.
Engine and transaxle mounting brackets
Sub frame bolts
Drive shaft
Lower the engine and transaxle assembly enough so the front and rear roll stoppers can be removed.
Remove the engine assembly.
To install:
Installation is the reverse of removal but please note the following steps:
Tighten the roll stopper bolts to 36-47 ft. lbs. (50-65 Nm)
Tighten the transaxle mounting bracket bolts to 65-80 ft. lbs. (90-110 Nm)
Tighten the engine mount bracket bolts to 43-58 ft. lbs. (60-80 Nm)
Fill the engine crankcase to the correct level.
Fill the transaxle to the correct level.
Fill the cooling system.
Fill the power steering system.
Start the engine and check for leaks.
Check the wheel alignment and adjust as necessary.
end paste
read the FSM
or
login to alldata.com and read.
or login to mitchels and read.
its all there to read.
There should be a drain bolt facing horizontally near the bottom of the transaxle. Removing that, allow it to drain. Should be another bolt about half way up the case. Fill it up to that hole.
Properly relieve the fuel system pressure.
Negative battery cableExhaust manifoldAlternatorWater crossoverIntake manifoldValve coverTiming coverSecondary camshaft drive chainPower steering return hose retaining bolt from the cylinder head3 M6 external drive bolts from the front portion of the cylinder head10 M11 internal drive cylinder head boltsCylinder head and gasket.
Clean the head mating surfaces.
To install:
Fig. Left cylinder head bolt torque sequence-4.6L engine
Install the cylinder head with a new gasket. Lubricate the bolts with engine oil prior to installation.
Torque the M11 bolts in sequence as follows:
Step 1: 30 ft. lbs. (40 Nm), plus an additional 70 degrees
Step 2: Turn an additional 60 degrees
Step 3: Turn an additional 60 degrees (total 190 degrees)
Torque the M6 bolts to 106 inch lbs. (12 Nm)
Install or connect the following:
Power steering return hose retaining bolt to the cylinder head and tighten to 37 ft. lbs. (50 Nm)Secondary camshaft drive chainTiming coverValve coverIntake manifoldWater crossoverExhaust manifoldNegative battery cable
Change the oil and filter.
Right Side
Negative battery cableExhaust manifoldWater crossoverIntake manifoldValve coverTiming coverSecondary camshaft drive chainElectrical connector from the Engine Coolant Temperature (ECT) sensorNut attaching the coil cassette ground wire to the cylinder headBolt attaching the exhaust crossover pipe to the cylinder headBolt attaching the right transaxle mount bracket to the cylinder headBolt attaching the rear transaxle brace to the transaxleNuts attaching the rear transaxle brace to the cylinder headRear transaxle brace3 M6 external drive bolts from the front portion of the cylinder head10 M11 internal drive cylinder head boltsCylinder head and gasket
To install:
Fig. Right cylinder head bolt torque sequence- 4.6L engine
Step 1: 30 ft. lbs. (40 Nm), plus an additional 70 degrees.
Step 2: Turn an additional 60 degrees.
Step 3: Turn an additional 60 degrees (total 190 degrees).
Torque the M6 bolts to 106 inch lbs. (12 Nm).
Rear transaxle brace over the studs located at the rear of the right cylinder headNuts attaching the rear transaxle brace to the cylinder head, looselyBolts attaching the rear transaxle braces to the transaxle and tighten to 37 ft. lbs. (50 Nm)Nuts attaching the rear transaxle brace to the cylinder head and tighten 37 ft. lbs. (50 Nm)Electrical connector to the ECT sensorBolt attaching the exhaust crossover pipe to the cylinder head and tighten to 18 ft. lbs. (25 Nm)Nut attaching the coil cassette ground wire to the cylinder head and tighten to 13 ft. lbs. (17 Nm)Secondary camshaft drive chainTiming coverValve coverIntake manifoldWater crossoverExhaust manifoldNegative battery cable
Negative battery cableStructural collarA/C compressor bracket to oil pan boltOil pan
Clean the oil pan and all gasket mating surfaces.
To install:
Oil pan gasket to the block after applying engine RTV at the oil pump parting lineOil pan. Torque the bolts to 105 inch lbs. (12 Nm).Structural collarNegative battery cable
Fill the crankcase to the correct level.
Start the engine, check for leaks and repair if necessary.
To install:
3.0L Engine
Negative battery cableStarter motorFront motor mount bracketBending bracesTorque converter dust shieldOil pan
Fig. Oil pan mounting bolt tightening sequence-3.0L engine
To install:
Clean the oil pan all mating surfaces.
Apply RTV gasket material to the oil pan.
Oil pan. Tighten the bolts in sequence to 50 inch lbs. (6 Nm).Torque converter dust shieldBending bracesFront motor mount bracketStarter motorNegative battery cable
3.3L & 3.8L Engines
Negative battery cableEngine oil dipstickDrive belt splash shieldStrut to transaxle attaching bolt and loosen the strut to engine attaching boltsTransaxle case coverOil pan fastenersOil pan and gasket
To install:
Clean the oil pan and all mating surfaces.
Apply a 1 / 8 inch bead of gasket material at the parting line of the chain case cover and the real seal retainer.
New gasket on the oil panOil pan. Torque the bolts to 105 inch lbs. (12 Nm).Transaxle case coverAll bending brace boltsDrive belt splash shieldEngine oil dipstickNegative battery cable
To install:
All Honda manual transaxles use the Honda Manual Transmission Fluid (MTF) as the original factory fill. This oil is similar to a 10W-30 or 10W-40 viscosity engine oil, and this oil can be substituted temporarily. However, the manufacturer recommends the use of their MTF when changing the fluid.
Level Check
The transaxle fluid should be changed every 90,000 miles (144,000 km) or 6 years under normal driving conditions. In severe driving conditions the fluid should be changed every 30,000 miles (48,000 km) or every 2 years, whichever occurs first.
Make sure the vehicle is on a level surface. If the vehicle is raised, make sure the vehicle is safely supported and level
NOTE: Do not confuse the drain plug with the fill plug. The fill plug is in the mid section of the transaxle. The drain plug is near the bottom of the transaxle.
The oil level is checked by removing the oil fill plug on the side of the transaxle. The transaxle fluid should just meet the lower threads of the transaxle fill hole.
Remove the oil level check bolt from the side of the transaxle. If oil runs out, or if oil can be felt near the threaded fill hole opening, reinstall and retighten the bolt to 33 ft. lbs. (45 Nm).
If the level needs to be topped off, pour oil in slowly until it begins to run out then, install and tighten the filler bolt to 33 ft. lbs. (45 Nm).
Cheers,
"Please rate this solution or kindly leave a Testimonial"
You won't find it. The only way to drain it is either to use a siphon pump at the fill tube, or to remove the transaxle drain pan which has several dozen bolts that hold it on. Removing the transaxle drain pan will reveal the filter.
Actually, it's a better idea to have the transaxle flushed and filled with new fluid at a service center that does this, for about $100 or so, every 30k miles, in order to maintain the transmissions internal cleanliness.
Here is the procedure. You DO have to remove the flexplate cover to get to the back 2 bolts. There are also a couple struts on the sides that block a couple bolts, if i recall correctly. I think you can do it in a couple hours.
3.3L & 3.8L Engines
To install:
Caravan, Grand Voyager, Town and Country, Voyager,
2000-2004
Oil Pan - Removal & Installation
2.4L
Engine
Structural collar
Oil pan
To install:
pump parting line
Structural collar
3.0L Engine
Starter motor
Bending braces
Oil pan
To install:
Bending braces
Starter motor
3.3L & 3.8L Engines
Engine oil dipstick
attaching bolts
Oil pan fasteners
Oil pan and gasket
To install:
Apply a
Engine oil dipstick
You didn't list your engine size so please pick the approriate task:
2.0L Engine
Disconnect the negative battery cable.
Raise the vehicle and support safely with jackstands.
Drain the crankcase of oil.
Remove the attaching bolts securing the oil pan to the engine.
Clean the oil and gasket mating surface completely, and allow to dry.
To install:
Apply a 1/8 in. (3.18mm) bead of silicone sealer D6AZ-19562-B or equivalent between the oil pan and engine crankcase.
Install the oil pan using the attaching bolts. Torque bolt to 5-7 ft. lbs. (7-10 Nm).
Lower vehicle, and fill crankcase with correct amount of engine oil.
Start engine and check for leaks.
2.3L Engine
Drain the crankcase of oil, and drain the cooling system by removing the lower radiator hose.
When draining coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze, and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
Remove the roll restrictor if equipped with a manual transaxle.
Disconnect the starter cable.
Remove the starter from the vehicle
Unfasten the bolts securing the rear oil pan to the transaxle case.
If equipped with a manual transaxle, remove the secondary air injection tube at the check valve.
Remove the heater supply tube located at the lower water pump inlet tube assembly.
Loosen the bolts and remove the brackets at the block and water pump inlet tube and A/C compressor line at the pan.
Using a prybar between the engine and body of car, flex engine enough the remove oil pan.
Clean both mating surfaces of oil pan and cylinder block making certain all traces of RTV sealant are removed. Ensure that the block rails, front cover and rear cover retainer are also clean.
Remove and clean oil pump pick-up tube and screen assembly. After cleaning, install tube and screen assembly.
To install:
Apply a bead of RTV E8AZ-19562-A sealer or equivalent, in the oil pan groove. Completely fill oil pan groove with sealer. Sealer bead should be 0.200 in. (5mm) wide and 0.080-0.150 in. (2.0-3.8mm) high (above oil pan surface) in all areas except the half-rounds. The half-rounds should have a bead 0.200 in. (5mm) wide and 0.150-0.200 in. (3.8-5.1mm) high, above the oil pan surface.
Applying RTV in excess of the specified amount will not improve the sealing of the oil pan, and could cause the oil pickup screen to become clogged with sealer. Use ad equate ventilation when applying sealer.
Install oil pan to cylinder block within 5 minutes to prevent skinning over. RTV needs to cure completely before coming in contact with any engine oil. Ideally, about 1 hour at ambient temperature between 65-75°F (18-24°C) is recommended as a drying time.
Install oil pan bolts lightly until the 2 oil pan-to-transmission bolts can be installed.
Install 2 oil pan-to-transaxle bolts. Tighten to 30-39 ft. lbs. (40-54 Nm) to align oil pan with transaxle. Loosen bolts 1/2 turn.
Tighten all oil pan flange bolts to 15-22 ft. lbs. (20-30 Nm).
Tighten 2 oil pan-to-transmission bolts to 30-39 ft. lbs. (40-54 Nm).
Install brackets for A/C compressor line and water pump inlet tube.
If equipped with a manual transaxle, fasten the air injection tube.
its a messy job but drop the (Transaxle) pan, be prepaid for collecting the oil(remove all but 3 bolts, pry pan down allowing oil to drain) unscrew the last 3 bolts change the filter and gasket. bolt back up using criss cross pattern dont overtighten! Re-fill through dipstick(easiest method) dont over fill.
