Question about Refrigerators
Ktn4582sd. the unit does not stop at all. if the power switched off from temperature regulator (by turning till zero mark) the miele starts after long time, 20 minutes 25 minutes.at the back wall collects some layer of ice, not very thick, about 0.3-0.5cm, that usually dessolves. could you image what the problem could be?
  • 3,267 Answers
Your thermostat need replacing if there is no leakage of the refrigerant(freon or CF4), i.e. there is no loss of the refrigerant gas pressure. Also check out the relays looking for a busted fuse .........................sodeep
Posted on Jul 30, 2009
The washing machine starts to fill with water then stops then makes a noise
Mine does so. But after a few minutes it starts tumbling. There are times the machine waits till the desired temperature has reached before the program goes on. If the machine does not go on, there must be a defect.
Jun 19, 2014 | Miele Washing Machines
Miele washer softtronics door will not open
go to this page and proceed according:
http://www.ehow.com/how_8562942_remove-door-miele-washer.html
God bless you
Jul 18, 2012 | Miele Washing Machines
My goodman furnacs says my limit switch is bad blower works but does not ignite .....? its modle gmt070-3 and where is it located
There are several limit switches in the unit there in various places in burner compartment. One on blower housing . One thing that I would try is replaceing your filter and turn the power off to the furnace and try starting the system after power is D/C for 5 minutes.
May 02, 2011 | Goodman GMS90703BXA Heater
I have a Miele Incognito G843 SCVi Plus. In a wash mode, the cycle stops in the first serveral minutes before soap is dispensed and the Drain/Intake light flashes. In Rinse and Hold mode the unit makes...
Hi
First check if the drain hose is not clogged and try to clean it as it can be that the hose is clogged and the water is not draining properly. After that check if the drain pump filter is fine and not clogged, try to clean that as well. After this check the metal filter, impeller cover and the air gap unit. After checking this you can reset the error as follows: turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. Hope this helps...please post back for further assistance.
Daniel
Dec 30, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Shut off before it reaches 150 psi turned up the regulator up but it stops about 60 psi should go to 150 psi
the air regulator only regulates the flow of the air as to how much. their is a pressure switch that turns on and off the power to the compressor when it reaches it's set pressure.
follow the plug wire to a small box this should have the switch arm you flip to start it.
remove the cover with the unit un-plug.
there will be a spring with a nut on top tightening this nut or loosening it will adjust when the pump will cut off.
the best way is to test by adjusting one way and watching the pressure till it hits the desired rating you want.
if it keeps pumping un-plug the unit then back off the nut or tighten till you hear a click then plug the unit back in it should not run then.
drain the air and re try the unit it should cut off at the pressure then if so your fixed look for burnt contacts if their black and have little craters on the contacts then that hole switch should be replaced and you can buy them at the presetting you need.
hope this helps
Sep 03, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Ice crusher not turning
Make sure the temperature is correct. Most ice makers have to work in an environment specified in your manual. If the low freezer temperature is not reached your problems start. Try this first.
Jul 08, 2009 | Frigidaire FRS6R5ESB
I've just moved into a house and my Miele dishwasher only runs a cold to luke warm wash, and doesn't dry the dishes properly.
Hi Shachr,
I'm Harvey the Master Plumber.
Your problem is: You've just moved into a house and your Miele dishwasher only runs a cold to luke warm wash, and doesn't dry the dishes properly.
The d/w uses water directly from the hot water heater. Your problem is common when the pipe length between the two is long. By the time the hot water gets to the d/w it's already filled with the cold water that was sitting in the pipes. Don't dispare! Since the d/w is next to the sink, the next time your d/w is ready to wash just run the hot water till it's hot at the faucet then turn the d/w on, instant hot water for the d/w.
As far as your drying problem, this is common as the d/w gets older. In my humble opinion it's not cost effective to repair. I would be glad it's still washing, but it does mean it's time to start putting a littlr bit away each week and when it fails just buy new.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 15, 2008 | Miele 24 in. Incognito G843SCVi Built-In...
Miele CVA 4070 coffee system
I called Miele hot line & here is the solution to fixed the problem... 800-999-1360.
http://www.miele.com/
Whenyou start the cleaning cycle, Don't stop the process by pulling the plug! Turnthe unit off from inside wait 5+ seconds & turn back on and thecleaning cycle should restart... If you do not use a cleaning TAB..Open& shut the LOOSE coffee Door under the drawer (Top Left) and thecycle will continue.
Aug 25, 2008 | Miele CVA4070 Coffee Maker
Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Apr 14, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
