Question about Sony SPP AQ600 Cordless Phone
Caller unable to hear me
When using my handset, callers are unable to hear me. I can hear them fine, but they can't hear me. Can anyone help?
SOURCE: phone doesn't show caller id numbers anymore.
You need to make sure you have programmed your area code...check the manual for setting up caller ID. You can search for the manual on line...go to
Posted on Dec 25, 2010
0 characters
1 Points
Cannot hear anything on the receiver, nor can anyone hear us
The cable from the base unit to the handset may be faulty or not properly inserted,
Sep 21, 2014 | Aastra Telecom Powertouch/Vista 390 Corded...
I can hear the caller but caller cannot hear me on 29870GE1-A digital answering machine
Hi, Please check whether the mic has gone bad in your handset.
the connectivity is just fine as your are able to hear the caller. but if you think there must be something wrong with the caller's phone, try calling someone else and check.
please let me know if you need more help. Thank you:)
Oct 23, 2010 | GE 29870GE1 Corded Phone
Cannot get a dial tone or hear caller on one of the handsets, but can hear it ring and the caller can hear me. The other handset is fine.
try unpluggjng base unit from power supply and then let handset unit reset to relocate the base unit.
Feb 11, 2010 | Panasonic KX-TG5632 Phone
I can hear caller on handset but they cannot hear me?
We just had the same problem with our AT&T 2462 hand sets. They simultaneously stopped transmitting, and though we could hear the caller, no one could hear us on the other end of the line. We unplugged the base from the power source, took the batteries out of the hand sets, waited 20 seconds, then plugged everything back in and they worked just fine. Hope this helps.
May 03, 2009 | AT&T E2562 Cordless Phone
Callers cannot hear me with one handset
Try them in intercom mode. If the flaky unit still does not work, the something along the microphone circuitry is likely dead. If its in warranty, get a replacement from the store or manufacturer.
Mar 03, 2009 | Panasonic KX-TG1033S Cordless Phone
Handset problem
It sounds like you have a defective handset cord or handset. First, at your phone, switch your handset with another phones handset that you know for sure works. From your phone make a test call. If the caller can now hear you, the original handset from your phone is defective. If the caller still can not hear you, switch your handset cord with another handset cord from another phone that you know works. From your phone make another test call. If the caller can hear you, then your original handset cord is defective. You can purchase another handset cord from your local office supply store. Your phone uses a standard handset cord. It may be difficult to match the original color of your handset cord. Be sure to take your defective handset cord with you, so you can try to match the color. If the caller still does not hear you. Put your original handset and original handset cord back on your phone. Then plug your phone in to another wall jack, that you know works with another phone. The other phone needs to be an identical phone to yours (same number of buttons and same model number. The model number can be found under the phone). Wait approximately 90 seconds, sometimes longer, after you plug your phone into the other wall jack. Now, make another test call from your phone. If the caller can now hear you from your phone with it plugged into another working jack, then you have a defective station port or jack where your phone was originally plugged in at. If the caller still can not hear then you have a defective phone.
Nov 19, 2008 | NorStar M7208 Corded Phone
Vtech cordless phone appears to be mute
Try the "hard reboot". /1/ Unplug power from base station. /2/ Disconnect battery in each handset. /3/ Wait a few minutes. /4/ Reconnect battery. /5/ Re-plug-in power to base station. /6/ Place handset in base station, and wait a few minutes for it to recover.
You may have to reset time/date and/or the handset ##.
Aug 24, 2008 | Vtech 9009111 Cordless Phone
Can not hear caller..
Replace the handset and cord with one from a known working phone. If this solves the problem, order the parts needed. Otherwise, send the entire phone for repair.
Hope this helps!
Feb 14, 2008 | NorStar M7324 Corded Phone
Caller can't hear my vocie when I use hand set
probly it fell or something the speaker needs replacing
Jan 04, 2006 | Vtech VMix Gz2456 Cordless Phone
Sony SPP AQ600 Cordless Phone Logo
110 people viewed this question
Top Sony Phones Experts
Are you a Sony Phone Expert? Answer questions, earn points and help others
