Question about Pure Digital Flip Video Ultra Camcorder
Flip freezes when turning on
I can not turn it off I have to remove batteries. This behavior began after I went thru security at the airport
  • raju19502 Dec 03, 2009
    I have the same problem but does not work even after 3 days and changing batteries. please help
  • raju1950 May 11, 2010
    What causes this problem...has it worked later because of some discharge action for 48 hours??
Can't explain the reason for the problem, but Flip support taught me how to fix it. Take batteries out of camera and let sit for 48 hours. After 48 hours, install a different set of batteries in Flip and turn on. Your problem should be solved. Worked for me the first time and I am currently doing it again for the second time.
Posted on Jul 30, 2009
Stop start will not work new battery fitted
Bad switch, or connections there to. But you need the Ecu error codes read by your favorite auto parts store, or your competent auto repair shop, or your Dealer. Bad codes will prevent start. Also could be this bad behavior began after you replaced the battery? If so your security system has killed your starting system. You will need to get security code and instructions from your dealer via vin number.
May 07, 2015 | BMW 118d Cars & Trucks
Turn off alarm after jump starting car
You need the VW scanner to reset the system and reprogram it after loss of power to the system. Aren't VW's great?
Mar 15, 2014 | Volkswagen Passat Cars & Trucks
I just went though airport security, but now my screen is too dark to work with. I have tried taking out the batterie, and I have restarted my computer a few times. It was working fine this morning.
Airport security probably turned off your screen's backlight. On my Acer Aspire One Netbook it is turned on/off by pressing Fn key and while holding it, pressing F6.
Mar 20, 2011 | Acer Aspire One PC Notebook
Flip video freezes when I turn it on to record
If the camera2_bing.giffreezes, and if it freezes more frequently and you experience decreasingbattery runtime, you may need a battery replacement. If battery replacement doesn't cure it you need a new motherboard.There is a servicethat can fix common issues like the battery screen, on Flip VideoCameras Flip Video Repair
Jan 01, 2010 | Pure Digital Flip Video Ultra Camcorder
Flip Video Mino keeps freezing up, can't shut down or upload
At least the following works on my first generation Flip Ultra camcorder (not Mino). Remove battery, put it back next morning. After that be careful not to touch "on" slider switch on the side of the camcorder while Flip logo is still on the screen. I mean turn the device on by using the slider switch and do not touch that switch again until Flip logo on the screen is gone. Doing the opposite (trying to use the "on" switch again while device is still "booting" and Flip logo is on the screen) will lead to the Flip Ultra freeze.
Jul 27, 2009 | Pure Digital Flip Video Ultra Camcorder
Flip Ultra - freezes at initial Flip screen - will not shut off
I found a fix that worked for mine.
It was doing the same thing, freezing at the "Flip" screen and would not turn off. I did the remove the batteries deal. It worked once but issue reoccured 2 months later and the battery fix didn't fix it.
What did fix it was...
With the camera off, hold down the Right Arrow button and the trash can button at the same time and turn the camera on.
A few seconds later, I was at the start recording screen!!
Good Luck!
Jul 21, 2009 | Pure Digital Flip Video Ultra Camcorder
Strange behavior
Initially, pls try disabling the hibernation feature of your computer.
Other than that, would appreciate if you can post back the make and model of your computer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Computers & Internet
Apple Powerbook G4 17in 1.33Ghz. Tiger OS. Airport problem.
I had a similar problem with my 15" 1.33GHz powerbook G4.
My problem was I couldn't connect to a network right away or at all, or wouldn't properly reconize the card (didn't drop it).
I solved it by removing the airport card from my PowerBook and putting it back into my G4. it should be in the same location.
it's underneath the battery pack.
1. power off your G4
2. remove battery pack
3. there is a latch on the right side (if the charger port is facing down), open it
4. pull back plastic cover tab and gently remove the antenna plug from the airport.
5. pull the plastic tab, until the airport card is removed, keep out for 30+ seconds to ensure it erases any corrupt log file on card it's self.
6 place airport card into the slot again, fully inserting it, it should go 1/8" - 1/4" into your powerbook
7. plug in the antenna plug back into your G4's airport(it should click 2x(very lightly)), flip plastic tab back over top the antenna cord, close you latch.
8. place battery back into your G4
9. plug computer in, turn on and it should work
if not then there is something wrong with the airport card reader, which i don't think it's the case here..
Jan 12, 2008 | Computers & Internet
LCD screen is white
It is not likely that the x-ray machine goofed up your camera's circuit. It is more likely that the vibration on the plane loosened a flex connector, possibly a chip has failed. A reputable repair shop is the answer for this.
Apr 17, 2007 | Fuji FinePix A360 Digital Camera
Pure Digital Flip Video Ultra Camcorder Logo
776 people viewed this question
Top Pure Digital Video Cameras Experts
Rommel Balcita
Ron Dufek
Ron Dufek
sharky633
sharky633
Are you a Pure Digital Video Camera Expert? Answer questions, earn points and help others
