Purchased a Canon i950 for years ago... printing beautifully... did not use for the last two months and now has just stopped printing... reinstalled driver, still same problem - does not print a test page either please advise
Comments:
Aug 02, 2009
- Tried all that was recommended... doesnt work... could it be a compatibility issue with vista?
Black is not printing on my cannon i950 is there a test to run or a way to clean head? all other...
(More)
Black is not printing on my cannon i950 is there a test to run or a way to clean head? all other colors printing Not working with new or old cartrige,
Hello. My Canon i950 was showing 8 yellow flashes indicating the ink waste tank is getting full. I...
(More)
Hello. My Canon i950 was showing 8 yellow flashes indicating the ink waste tank is getting full. I removed the ink pads in the bottom of the unit. I cleaned them and let them dry before replacing them. I followed the code directions and the yellow light does not blink now, just solid green, but it won't print either. Only error message is, problem with printer. Help Please!
Printer: Canon i950. Two problems: The "utility" icon on the computer is grayed out and...
(More)
Printer: Canon i950. Two problems: The "utility" icon on the computer is grayed out and non-functioning. The larger problem is that when I try to print a black document, it comes out a faded, washed out almost pea-green color. I printed a test page - what should be black is pea-green. As I said, the "utility" icon is grayed out and I can't access that. Any suggestions, hints, solutions, etc.? Thanks! mg
Reds are not printing on my canon i950 ink jet printer. (Mac OS X) I have used the utility to...
(More)
Reds are not printing on my canon i950 ink jet printer. (Mac OS X) I have used the utility to perform several cleanings and at least 2 deep cleanings. I used a Q tip with rubbing alcohol to wipe the port where the ink is fed to the nozzle, still no reds. What can I do.
