Question about Philips 42PF7320A 42 in. Plasma HDTV
I have a Phillips HDTV. The screen has a red grid
Red picture tube out of alingment how do you make major adjustment
Its done with the original remote--convergence in the customer menu should be looked at first---call up the crosses or the grid of lines, it has one or the other.
You first want to look to see if red out and then if it will move both up/down and left right where off.
If it will not move in some direction anywhere on the screen the convergence output chips the set uses are bad.
The set will or should have two hidden menus, one will bring up the advanced grid for convergence---input for that with the remote is Mute, 181 or 183----if you call up the wrong one shut set off and try the other number.
It is possible to converge the whole screen there, if memory serves me 7,8,9 change the color being adjusted DO NOT ADJUST GREEN FOR ANY REASON.
two buttons (different on different remotes will move the cursor around the grid (and the remote must have a button somewhere on it with "data" to save the adjustments.
Check in customer menu the convergence first---got movement?
Dec 08, 2012 | Samsung HLP5685W 56" Rear Projection...
My phillips 2006 hd tv has a black line across the screen with a snowy freeze
If you have parallel horizontal black lines on a white background, you can see the separation between the lines when it is viewed at close range (Figure 1). As you view the lines from further and further away,the image gets smaller, you eventually get to the point where you can no longer see the separation between the lines, and it looks like one line. Losing the ability to see separation in the lines is exactly what happens when you sit too far back from an HDTV set. If we apply the same principle to an HDTV, a 1080p resolution HDTV has to fit 1920 vertical and 1080 and horizontal black lines separated by the white space on the screen, (that is the pixel grid of a 1080p HDTV display). Furthermore the spaces between each cell of the grid need to be very small in relation to the area each cell occupies, or you will get a screen door type effect. A bigger HDTV can increase the size of the cells and the separation between the cells, so everything doesn't run together when you sit further back.
Performance chip
May 22, 2012 | Philips Televison & Video
Screen issues
In the customer menu first look for convergence--if this is Akai it is made by Samsung.
in the convergence menu will be either a grid of lines or several crosses--examine and see if your red line is out of position there.
If it is it may just require with the remote adjustment in that menu.
Cleaning will not resolve a red line.
let me know what you find.
Mar 13, 2012 | Akai PT5598HD 55" Rear Projection...
55PW9363 55 in. Rear Projection HDTV-Ready Television: My Phillips big screen has double images and doubl...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 17, 2010 | Philips 55PW9363 55" Rear Projection...
We have a red green color seperation on screen. how do we correct this
You can get the phillips DPTV305 _ DPTV345 convergence repair kit at the following link . The repair kit contains the two ICs 12 resistors and the Deatailed instructions with pictures on CD. Just look under the Phillips repair kits category.
http://www.tvrepairworld.com/
Jul 12, 2009 | Philips 60PP9202 60" Rear Projection...
Phillips flat screen won't work
First, eliminate the possibility that the power cord, itself, is not faulty. Try another power cord from, say, your computer, or something else with the same type of power cord. This is often overlooked
Jan 07, 2009 | Insignia 42" LCD Flat-Panel HDTV
Convergence problem
I have a hdtv my red and blue are offset i need to know how to adjust properly
Dec 15, 2007 | Philips 50P8341 50" Rear Projection...
Philips 42PF7320A 42 in. Plasma HDTV Logo
181 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
