SOURCE: Need wiring diagram or schematic for GE refrigerator
if you look on the back there should be one stuck to the inside of the case near the compressor. if not go here: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=TFX20JRSM
SOURCE: Need a wiring diagram for a Whirlpool ED5VHEXTQO1
I will give the wiring diagram a try but your refrigerator has a simple defrost timer that is most likely the reason for your problem. Give me a few moments and I will give you a photo. Inside the fresh food compartment and behind the control panel is where the timer is located. Sea Breeze
SOURCE: Looking for a free online repair manual or wiring diagram
i do not know if they charge or not but give these websites a try www.alldatadiy.com and www.autozone.com if all fails stop by your local library and get your hands on a Haynes auto repair manual for your car also like to give you this information if you every have any hard to find GM-parts they sells only GM its Schram auto & truck parts 1-800-292-1032 and they website is www.schramauto.com wish you the best of luck Michigan Man.
SOURCE: finding wiring diagram whirlpool refrigerators
take off bottom cover should be on back if not look around compressor they usually leave them stuck around there
