Question about Plumbing
Ejector pump will not shut off automatically after basin empties, I have to unplug it to keep the motor from burning out. What could be the problem?
    Champion:
  • 363 Answers
You either need to repair/replace the float switch, this switch is the device that turns the pump on and off
Posted on Jul 30, 2009
Pump continuosly runs after water is cleared out of basin
The problem is with the float switch. I have attached the manual. There is probably something keeping the float from falling back down. Check you sump basin and make sure nothing (including the power cord) is interfering with float.
Mar 24, 2014 | Hydromatic Pump Hydromatic V-A1...
Tip
IRobot Mirra 530 Tips & Tricks
Tips from iRobot Resources:
Run Mirra only when in the water.
Mirra has a very strong motor system that needs to stay cool for optimal performance and life. Your pool water around the motor helps keep it cool during operation. Therefore Mirra should not be run outside of the pool due to the risk of overheating the motor.
Choose the correct filter canister.
Use the Large Debris Filter Canisters when the pool contains a significant amount of large debris (leaves, insects, etc.) and when the pool is opened for the season or cleaning during the Fall. The Fine Filter Canisters are ideal for filtering small debris such as algae, sand, silt and bacteria and for regular pool cleaning maintenance during the peak of your pool season.
Keep Mirra working at peak performance.
Mirra uses the powerful force of water pumped through its filter to clean and circulate pool water and to propel itself around your pool. It pumps and filters more than a gallon of water every second! Clean the filter canisters regularly by removing them from Mirra, emptying its contents and hosing it out. Keeping the filter canisters clean will ensure optimal cleaning results and strong pump suction.
Allow the motor to cool before removing the robot from the pool.
Mirra's power supply has an automatic timer that shuts Mirra off after each cleaning cycle. Wait 20 minutes before removing Mirra from the pool to allow the pump motor to cool. Turn the power supply off and unplug it from the electrical outlet before removing Mirra from the pool.
on Sep 17, 2013 | iRobot Mirra 530
Pump is running/humming, but not grinding
The pump may have become plugged again immediately
May 28, 2013 | Star Water Systems PowerFlush Sewage...
How do you use the rainbow to **** up a large amount of water from an air conditioner tray
You simply begin with an empty water basin, turn the unit on, and gingerly slurp the water away. Do not plunge the nozzle into a pool of water. Afterall, this is a vacuum cleaner, it moves air and the water/debris you kick-up into the air, not a water pump. The standard basin has a maximum capacity of 2 quarts, before the unit effectively drowns. If you have the special larger basin, then it has a 4 quart capacity. If you are trying to remove a larger volume of water, then you will have to empty the water basin multiple times. Unfortunately, you have to keep a close eye on the water level, so that you do not drown the vacuum.
Mar 23, 2011 | Rainbow E series Canister Wet/Dry Vacuum
Pump keeps tripping the breaker... there's no debris in the basin or lodged in the pump. I'm thinking bad ground or is the pump just shot enitirely?
More than likely the pump motor is not sealed properly and the motor is getting wet. If you have warranty left take it back, as the problem could be severe. I have pulled these pumps apart and used silicone sealant on them, but it doesn't usually hold long if the pump has to run allot. Usually if the pump leaks into the motor, the body has been damaged or warped to the point that repairing them is pointless.
Mar 07, 2011 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
My ejector pump will ot shut off...it is empty what should I do?
The first thing I would do to protect the pump is to shut off breaker or unplug the pump.I'm sure you have already done this but most pumps will not run for extended periods of time without damage to the pump. I would make sure that the float is not rubbing on pit sides or has anything stoping it from shutting pump off. If you have a seperate mercury switch float then I would unplug it from pump and see if that will shut your pump off.
If you take the mercury switch out of the circuit and the pump continues to run then you need a new pump. Thank you.
Jan 19, 2011 | Home
My sump pump wont kick off. There is no water in the sump and the float is fine, but the motor won't shut off. I unplugged the pump as to not burn up the motor, and thinking it may reset itself, but when...
Hello, the pump motor is controlled by the float switch. If your motor is running constantly even when you move the float switch around, then I would say that either the switch is shorted internally, or the wires going to the switch are shorted, thusly causing the motor to run. Is the float on a separate adapter to the pump, or is it wired into the pump?
joe
Jan 09, 2011 | Flotec Automatic Sump Pump Float Switch
Pumb only pumps a small amount out of the basin. Float needs adjusting to go all the way down and empty the basin. How do you adjust the float/bulb to travel farther down without shutting off after only a...
Flotec website shows several submersible sump pumps, and pump types:
http://www.flotecpump.com/asp/productapplication.asp?AId=28
Click product, then click on 'parts and literature' to access manual
Here is a Flotec manual:
http://www.flotecpump.com/pdf/FP525%2811-1-06%29.PDF
Manual for this type of sump pump says:
Quote from manual: Automatic float switch is sealed and factory adjusted for
most home sumps. Turn-on water level is 10" - 12" above
pump base. Turn-off water level is 4" - 6".
The manual also says that running the pump when dry will ruin the seals.
This implies that the water level setting is set so the seals will not be damaged
You might be able to dig the sump deeper, but I don't know if that meets your objective.
Oct 24, 2010 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
What is the routine for resetting the dl error code?
Hi mate first thing I would do is unplug the machine and turn off the water valves red and blue before you take out the drain hose get a basin and keep it with you at the same time put the hose into the basin bring the two down to the floor when the last of the water is empty you should be able to open the door if you can still not open the door take the top off the machine MAKE SURE THE MACHINE IS STILL UNPLUGED if you have a narrow arm you can feel down where the interlock is and move your fingers around the interlock until it releases the lock maybe the pump is blocked our the interlock needs to be replaced
Jul 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Plumbing Logo
244 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
