Question about Samsung Refrigerators
I have a samsung rs2578sh refrigerator. The freezer is okay but the refrigerator is not working.
  • 3 Answers
Firdt, do the rest. Second, turn off the power around 3 hours (so all of the frozen ice will gone) Than turn the power back. Will work. Good luck
Posted on Aug 13, 2009
  • 560 Answers
Check the air circulation fan in the freezer compartment for proper operation and be sure its not frozen with ice. If its ice build up, check the defrost circuit. If the fan is clear but not running, replace the fan motor.
Posted on Jul 30, 2009
How do I get my new Samsung RF220 to be cooler in the refrigerator section? The temperature does not go below 52degrees F. It is set at the coldest setting.
Check for deformed rubber boot that runs entirely around edge of fridge door allowing cold air in fridge to leak out. 2nd possibility: Louvers in wall between freezer and fridge may be stuck in mostly closed position. Force them GENTLY to open. That will allow the cold air to pass normally from the freezer to the fridge to give you proper fridge temps. If these two easy cures don't work, here's hoping that Samsung owes you in-warranty service and parts on your "new" unit.
Oct 12, 2014 | Samsung RF220NCTASR 21.6 Cu. Ft....
Refrigerator won't cool but the bottom freezer works
under bottom shelf there are air inlets to fridge take out tray clean ice frominlets
Jul 22, 2012 | Maytag MFD2560HES Bottom Freezer French...
Freezer wont freeze. Stuck at 35 degree. Fridge side is okay.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 10, 2011 | Samsung RS265LABP Side by Side...
MY SAMSUNG RS2578SH does not work in the cooler area
ck for ice build up in the freezer sde . this will block air flow and prevent cooling .. mm if ice is found you have a defrost failure . caused by a heater / thermo / or control failure .. mm hope this helped . mm
Oct 27, 2010 | Refrigerators
Samsung RS2578sh freezer not working and temp panal flashing
before you call for service
try the unplug reset method
sometimes this unit
freaks and that what happens
just unplug it for a few minuts hopefully it should clear up
bar that your could be looking at a new control board
Oct 29, 2009 | Samsung RS2630SH Side by Side Refrigerator
No longer cooling on either the freezer side or the refrigerator
Unplugged fridge for 24 hours, apparently was frozen up - lot of water on the floor afterwards.
Plugged it back in and has worked okay - occasional noises from the fan, but not all the time.
Apr 05, 2009 | Samsung Refrigerators
Samsung rs2578sh
Yes, you have a faulty defrost heater or thermal fuse, the fault will re-occure within a few weeks. Regards Advisor
Aug 22, 2007 | Samsung RS2578BB Side by Side Refrigerator
Icemaker won't freeze - Samsung RS2578SH
Did you ever get any advice for this problem? Please repost if not.
Oct 07, 2006 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
204 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
