Question about Mastercool 67680 Evaporative Cooler Air Conditioner
Works fine but started making a blowing sound kind of like a rush of air
    Problem Solver:
  • 7 Answers
Maybe the unit has switched to a higher speed, does it have a thermostat that changes speeds automatically?
Make sure the pads are not plugged up. Make sure you do not have a damper somewhere that has partially closed.
Posted on Aug 07, 2009
Upon starting my truck I hear the sound of rushing air for about 30 seconds then ok; why?
I would say more than likely it the radiator cooling fan. For some reason some vehicles, no matter what temperature, the cooling fan clutch engages which makes the cooling fan run at full speed like there's no fan clutch.
It sort of makes it sound like the engine is revving up but it's simply the sound of the rushing air from the fan clutch making the cooling fan spin at full speed.
Hope this helps.
Feb 21, 2015 | 2001 GMC Sonoma Extended Cab
Dell computer modem makes loud rushing sound and won't work
Check connections. Reboot computer. Reboot modem. If no improvement - RESET modem to default. {N.B.: This will remove any changes you have made previously...(Have you checked with the help-desk at your Internet Service Provider?)!} It is usually done by pressing a paper-clip into a hole, usually on the back side of modem, for at least 10x seconds - (check with modem instruction manual). If fault remains after this try another modem. If second modem does the same, then it sounds like a fault in the computer. Check with ISP!
Sorry I can not help more - but you have not given much information; details; etc. I hope this helps - kind regards - 'b'ye - Bruce.
Jul 30, 2014 | Dell Inspiron 531s Desktop Computer
Loud noise when I accelerate
Sounds are kind of hard to describe. Bad exhaust noise can be noticed more when the exhaust is rushed in acceleration. Valve rattle can be created on acceleration as well as "spark knock".
Sometimes an air induction leak can roar when the car is speeded up. Sometimes an air filter is not fully sealed in its' duct and will make noise when drawing in air.
Jan 19, 2014 | 1994 Lincoln Continental
Heater blows cold air
Sounds like the cooling system is low on antifreeze. Have you checked to make sure it is at it's proper level?
Dec 03, 2013 | 2006 Kia Sorento
'97 Jeep Grand Cherokee AC "Works and Stops"
Make sure your fan clutch is working. No fan, no cooling of the condenser, no heat dissipation, no cold air. Start the truck and make sure you feel air movement, a lot.
Aug 11, 2012 | Jeep Grand Cherokee Cars & Trucks
Heating system is getting air bound
If the coolant level was low at some point you might have air trapped in the heater core. Make sure the coolant level is topped up, then drive the car with the heater on for a few days. That might suffice to burp out the air pocket.
Jan 18, 2012 | 2004 Jeep Grand Cherokee
I have an old Kenmore 25,000 BTU Air Conditioner (Model number 253.7792580). Recently it started blowing air that is not really cool, it's actually room temp. It makes a slightly different sound when it is...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 29, 2010 | Kenmore Heating & Cooling
Why do i hear air when i press the brake pedal
well, you don't really hear air when you press the brake pedal. You might hear hydraulic fluid going through the valves in the master cylinder, that sounds like air flowing through a vent. But, I assure you, it is not air.
One can press and pump on the pedal when the car is off and hear the 'rush' of fluid which sounds kind of like air rushing out of an inner tube.
It's a common mistake to believe a rush of air is being heard when pushing on the brake pedal.
Aug 26, 2010 | Chevrolet S 10 Cars & Trucks
Sluggish on start and blows the breaker on compressor 17amp
replace the start capacitor on the motor body,it is located under a metal cover by loosening 2 screws,it is getting weak,also if you leave this breaker jumped,you will soon over heat the motor windings and ruin the motor
Apr 09, 2010 | Hitachi EC119SA Twin-Stack Air Compressor...
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
65 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
