Question about Midland 5001 40-Channels Base CB Radio
Whining in my cb
I"m getting a wine when my truck is running and it kill my sigal so i cant talk and i bought a 35v in line casiter to solve this problrm but it didn't alow enough power to flow to my cb radio ( i have a cheap midland cb)
wyoed1
  • 211 Answers
SOURCE: 75-822 midland radio
You have a bad detector in the radio. Needs serviced. Change the bad detector diode and it should work. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
wyoed1
  • 211 Answers
SOURCE: midland cb model 13-895
Hi Frank, It sounds to me like you may have a bad dectector diode. Other possibilities are cold solder joints in the stand up boards in the IF section. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 08, 2008
  • 13 Answers
SOURCE: midland cb radio
NO. I SORRY. YOU COULD GET IT FROM THE MANUFACTUREE. THANK YOU
Posted on Sep 16, 2008
Communicomm
  • 90 Answers
SOURCE: wiring a midland 78/999 cb radio microphone
Pin 1 = white
Pin 2 = shield
Pin 3 = black
Pin 4 = red
Posted on Sep 29, 2008
JustJeeps
  • 74 Answers
SOURCE: Midland model 1000
turn squelch all the way off , if you still get nothing you have a bad mic
Posted on Nov 21, 2008
Euro grand bar fridge glass front. Have just replaced curcuit as supplied as apparently all had 100 % failure rate! We bought 3 including dual zone wine fridge. Have replaced boatds, but not not cooling...
If these were bought new, it sounds to me like the company still has a problem with their control boards. I would get the manufacturer on the phone and ask to talk to someone in Engineering.
If bought used, be sure they are set up for the proper supply voltage.
Nov 17, 2013 | Furniture
Why does my midland cb radio whine when I crank and rev the motor up
you midland cb is picking up interference from the other electronics in your car/truck(ecu) etc, it helps to connect power source directly to the battery or you can buy an inline noise reducer that goes onto your power line
Dec 27, 2012 | Cars & Trucks
Hi i have a midland 38 plus cb but the recieve is poor i have an excelent swr is there anything i can do to turn the receive up inside?
there is but if u get it wrong then you are stuft. i would just try the earth first cause altho the swr is good if the grounding is poor this will effect sigal.depending on mounting will depend on earth solution
May 01, 2011 | Midland 40-Channel CB Radio CB Radio
I have hooked my the radio to a constant hot and grounded it. The antenna is a midland antenna a is window mounted. All the cables are hooked up but I cannot receive anything and all I put out is a...
You may have a couple issues. First is the whine when you key the mic. Change the mic to any newer 4 pin mic. See if this helps a bit. Also make sure your antenna is a match. Hook up an SWR meter inline and check it. 1-1:5 is the goal but no lower than 2. Your antenna is much of the set up. Spare no cost when purchasing. Do you have one of the older antennas that roll up in the window? I suggest you get at least a Wilson 300 and try that. Window mounted CB antennas do not receive the best at all. And they have no ground plane. You try what I listed and see if that don't help. Let me know if that helps.
Feb 09, 2011 | Midland 1001Z 40-Channels Base CB Radio
I have a 3300hp bought it new in may it has been in the shop every month sence. iv taken it to 6 different cb shops and no one can fix it it will recive well but when i talk on it people can barely...
Hi, my name is John. Welcome to FixYa. Check your antenna, make sure it is grounded good and nothing is blocking it. Have the SWR checked. They will do it for free at Radio Shack or any CB shack. Thanks for choosing FixYa...John
Nov 23, 2010 | Connex 3300 240-Channels Base CB Radio
How do I get back to regular CB channels on the 75-822? All I can get is 27.xx and 26.xx. Where are the 1-40 channels.
I'm guessing that you bought the CB from a person not a company the CB band is between 26Mhz and 27Mhz unfortunately your CB was Modded to talk on Ham radio frequency's what i would suggest is one of two things if you are good at electrical soldering get a schematic and take out the mod or look on-line for a ham radio store like ham radio outlet near you and see if they can un modd it.
if you bought it from a store return it or talk to midland to see if they can fix/reset it at http://www.midlandradio.com/Contact-Us
one other thing until the radio is fixed it is not FCC part 95 or 97 compliant and is therefor illegal to transmit with it
Sep 04, 2010 | Midland 75-822 40-Channels Handheld CB...
Have hand control wireing problem ,,,, need to know what color wire does what ,,,, got the left hand control to wire up on a older bike,,,,, hooking up trun sigals and head light control,,,,what color...
This information applies to the vast majority of Honda motorcycles. Colors for the right handlebar switch are: Grey sends power to the turn signal switch. Light Blue goes from the turn signal switch, to the right turn signals. Orange goes to the left turn signals. Light Green goes to the horn button.
The left handlebar switch: Yellow With Red stripe goes to the starter button. Black wires take power to the headlight switch and the kill switch. White goes to the headlight low beam, Blue to the high beam. Brown / White goes to the tail light, running and instrument lighting. Black / White comes from the kill switch and delivers power to the ignition coils.
I hope this helps.
Nov 06, 2009 | 1982 Honda VF 750 S
Loud whining noise
check alternator bearings for noise
Apr 09, 2009 | 1999 Dodge Intrepid
98 fatboy engine noise.
Harley's do run hot, anywhere from 220 to 240 normally, and a little hotter this time of year. I suggest running a straight weight oil, and a little heavier weight in the summer. I use Valvoline VR-1 30 weight most of the year, and 50 or 60 weight in the hot summer, and I use Lucas 20w50 primary/trans for the primary and tranny. I don't bother with the extremely high prices of the HD oils. For the whining noise, you need to determine which side of the engine it's coming from. Whining will almost always be in the bottom end. There's nothing in the top end that should whine, and if there is whining from the top, it's usually an air leak around the carb. Start by checking the fluid levels in the tranny, and primary. These are the two most common areas to pick up a whining noise. If it's coming from the left, it's going to be in the primary, and usually this is caused by low fluid levels. From the right, it's going to be either the tranny, low fluid, or the oil pump. The oil pump is a gear type system. If you're running a light weight oil, say a 10w40 or HD 20w50, when the engine heats up and the oil thins, it can cause the oil pump gears to whine a bit, especially in the summer heat. So, check the fluid levels, if they check good, then change the oil, since the summer is coming to an end, go with a straight 30 weight. This should clear up the whining noise. If it doesn't, get back to me with the exact location the noise is coming from, and we'll go to the next level of diagnosing the whine, but I believe that this will cure it.
Aug 22, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Midland 5001 40-Channels Base CB Radio Logo
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
