Question about Electrolux E23CS75SS Air Conditioner
Water Leakage My split unit was not cooling as much as it used to. I touk out the filters to clean them, i found a little piece stuck in it (about 1inch size). Anyway, now it is leaking water from the inside unit. Thank you
  • 534 Answers
Sounds as if your condensating drain is clogged. This drain is connected to a drain pan in which your eveporator coil is in. The filter material may have gotten into this pan and covered the drain hole. The way to check is to open the area where the coil is located and look at the tray this coil sits in. This tray should have a hole right in the corner of it. You may need to get a shop vac with a small hose attachment and use it to remove the water in this pan in order for you to see this drainage hole. You may also go to the drain where it is located on the outside of the house (this drain is located by the a/c unit outside most of the time) and using the wet vac, put the house on the end of the drain pipe and have the vaccum pull out alll the debris this way. Good Luck
Dave
Posted on Jul 30, 2009
Water leakage
Your not to clear about your problem. First I need more information. Is it a window unit, or through the wall or a split unit???
Usually when there is water leakage from a window or through the wall unit there could be one of two problems. One being a clogged area in the condensate pan not allowing the condensed water to flow out of the back of the uinit, or two, the unit is not properly tilted outward to allow the water to flow outside.
If it is a split unit and it was previously working fine then it most likely is stuffed with debris and should be cleaned out.
Good luck, I hope I have helped.
Marty
Apr 04, 2014 | Whirlpool Heating & Cooling
SANYO SPLIT TYPE AIR CONDITIONER LEAKING
The leakage is probably from condensation and there should be some sort of drain for it. You should check to see if it is clogged or partially clogged. Also since you say it does it when it hasn't operated for a while you may want to check out where the lines pass through the wall and make sure that it is sealed up there so you don't get leakage from out side.
May 04, 2010 | Sanyo Split System Air Conditioner
Water leakage after cleaning lint trap
make sure that when you replace your filter that there is no obstruction in the filter thread(small stone), i have had many problems with this,if the drain light keeps comming on then check the waste pipe stand.
Apr 07, 2010 | Miele W1926A Front Load Washer
I got a sam sung split A/C while switch on the
just check the gas pressure and gas pressure is ok,may be out door unite is blocked.do the high pressure service
Oct 17, 2009 | Samsung AS1293L Air Conditioner
Water leakage from internal unit of split AC
Draim pans do get dirty and partialy block drain pan. If possible take a shop vac and gently **** out the drain line. This will pull the restriction out of the line and help clean drain pan. Rusty
Jun 05, 2009 | Heating & Cooling
Split ac not cooling
cak split in door unit 1st watar lavel and in sait watar tra blok paip.
Apr 07, 2009 | LG Heating & Cooling
Water in dump box. Saeco Vienna Deluxe.
Had the same problem. I found that the rubber O ring around the plunger was split and leaking water into the dump box. It could also be that your O ring, if not split, is too worn to continue sealing. Try replacing the O ring. I am in process of doing that myself as I just found the problem.
Another possibility is that the filter that filters just before expelling the coffee is clogged and the coffee cannot escape, if that is the case you probably would be getting coffee and not clear water, I would opine.
Feb 17, 2008 | Saeco Vienna De Luxe Espresso Machine
Split System Air conditioner
There normally two types of leakages from the wall unit.
1.The warm air in the room when comes in contact with the cooling coil of heat exchanger (consisting of fine fins where compressed refrigerant evaporates) looses its heat & cannot retain the same moisture content at lower temperature at the point of contact with evaporator. There is a provision of a drain pipe to carry this condensed water to outside water drain. So if the drain pipe is choked or the coupling joint of the drain pipe at the bottom of cooling coil is not proper, there will be water leakage, This can be easily attended by physically looking at the fittings.
2.The second problem can be the leakage of the refrigerant. If there is second type of problem, then there will be very little or no cooling irrespective of continuous running of air conditioner. This can be easily checked by feeling the temperature of outlet air from the air conditioner.
Conclusion-As you have written that there is leakage from the air conditioner, but you have not written whether it is visible or invisible. If the leakage is visible, it is problem number 1 & if it is invisible, it is problem number 2.
If you are not satisfied you are free to ask for more explanations.
Jan 29, 2008 | Heating & Cooling
Leaking water
water leakage from indoor unit
1.clean cooling coil
2. wash air filter
3. check drain tray.if it block then clean it
4. check drain pipe U band.
5.check indoor unit water tray.if damage change by new one or repair it
Sep 04, 2007 | Friedrich QuietMaster RS10J10 Air...
Fujitsu wall mounted air conditioner.
 during Cooling and Dry modes, if the unit is used under conditions of
lower temperature (18C)  the heat-exchanger may freeze, leading to water leakage and other damage.
If the unit is used for long periods under high-humidity conditions, condensation may form on the surface of the indoor
unit, and drip onto the floor or other objects underneath. (About 80% or more)
Increase Temp to 20 and also run coil dry cycle,
Jun 03, 2007 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
436 people viewed this question
Top Electrolux Heating & Cooling Experts
christian nielsen
ivan georgiev
ivan georgiev
Are you an Electrolux Heating and Cooling Expert? Answer questions, earn points and help others
