Question about NEC MultiSync MT830 Multimedia Projector
Mt800 projector have a problem with out projector mt800. the screen becomes all distorted once we start using it. Any ideas of what could cause it or how we can adjust/fix? thanks so much
  • 32 Answers
First I would suggest cleaning the filter on the bottom of the unit where the fan inlet is. Over heating can cause many issues with the video controller in the projector, also shortens the life span of the bulb, always let the unit cool down when turning it off (let the fan run when you turn the power of by top button, never unplug and use the power switch on back. until the fan shuts off.)
Posted on Mar 16, 2008
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
Feb 08, 2016 | Televison & Video
Infocus projected image is distorted
check the screen resolution settings in visa it maybe different than the desktop settings.infocus can execpt many resolutions but not all. try 1280x1024
Jan 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
Olympus u820 image distortions colour and form
One answer time for a new camera the cost to repair is about the same as new.
Mar 15, 2017 | Olympus Stylus Stylus 820 µ Digital 820...
Canon LV-S3 casts a purplish cloud.
yes this happens all the time with lcd projectors, after a while lcd becomes distorted and bad,unfortunately you cant fix that (well thats what i know of anyway).
Jan 15, 2010 | Canon LV-S3 Multimedia Projector
I just replaced the bulb unit in my Toshiba TDP-MT800 projector but when I press the power button nothing happens
Make sure the Lamp is seated correctly and firmly and the microswitch on the lamp door closes. Some projectors require a button sequence to be held down whilst powering up the projector in order to reset the lamp counter and restart it. You could also try the old lamp back in it for a few minutes to see if it starts up using the old lamp, providing it hasn't shattered.
Good Luck
Dec 31, 2009 | Toshiba Office Equipment & Supplies
I have a toshiba tdb-s8 projector & when plugged into the mains nothing happens
you need to replace the power supply. the caps have a tendancy to dry up in toshibas.
Oct 08, 2009 | Toshiba TDP-MT800 Multimedia Projector
LCD projector spots showing up on the screen
there are light filters behind each lcd panel that determine the color of light going through it. because of excessive heat and dust, the filter tends to burn and cause discoloration in the image. if the image is bluish (cyan), the red filter is burning. if it's yellow, the blue is burning. if it's purplish (magenta), the green is burning. the filters will need to be replaced. unfortunately, many companies don't sell individual parts of the optical engine, so the entire engine might need to be replaced.
Aug 20, 2009 | Epson EMP S1 Multimedia Projector
Black line in picture
start with clean lenses- all filter and check.
Nov 18, 2007 | Toshiba TDP-MT800 Multimedia Projector
NEC MT800 Projector with Vertical Lines in picture
The ghosting problem is a combination of both the lcds and driver boards in which case neither need to be truely replaced.. They use a specific voltage to transmit data to the lcds.. Each lcd is different and the driver board is programmed by the factory for the EE setting. Unfortunatly with nec, they do not offer a service mode to go in and adjust the ee settings to correct the electrical convergance. So the only way to fix the problem is to replace the lcd with a newer one who wasnt worn out from long term heat.
Sep 22, 2007 | NEC MultiSync MT830 Multimedia Projector
Toshiba tdp-mt800
Hi there
Have you tried using another input like the Component instead of the DVI. See if it makes any difference.
If not it could be the DMD or your Mainboard.
Most of the time it is the Mainboard - Home Theatre Projectors come out with awesome DMD's , so I doubt it to be the problem.
Hope this is usefull !
Aug 08, 2007 | Toshiba TDP-MT8 DLP High Definition Home...
NEC MultiSync MT830 Multimedia Projector Logo
160 people viewed this question
Top NEC Office Equipment & Supplies Experts
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
