Question about Toshiba Satellite L305D-S5895 Notebook
My tv is just blank after adapter is hooked up
Can i use a vga to s-video adapter to display my computer screen on my lcd tv?
  • nm_perez86 Jul 30, 2009
    that is set up and the tv is still blank
    already did that and still didnt work
    President:
  • 2,559 Answers
Yes,but you may need to press the Fn+F7 or FN+F5 keys on the laptop or go into the control panel and enable presentation mode
Posted on Jul 30, 2009
  • Randy Hough
    Randy Hough Jul 30, 2009
    if you are using the vga port on the laptop,you will need to right click on the desk top,click properties and go into the monitor options and set to show on external monitor or tv.
Computer vga cable/ sansui tv problem
Hello
Nvedia signals cannot be porcessed by Sansui Tv. You have tow options before you to connect your self assembled computer to this tV. The first one is try by reducing the resolution f VGA output. for that, go to Nvidea control [normally will be displayed at the right end of the taskbar] and chage relolution there. By default, the resolution will be 1024/768. Select it to the lowest; 800/600. If the TV display it, just advance it to the next highest; 960/600.
If this does not help you, there is no other way than change the computer's video card to any other, which works on Windows Video Drive. Can be bought from local computer component market, insert it to one amoung the free PCI socket of the computer and do the next proceedings to change over video output from on board video out, and feed this video signal to yur TV. OK.
Nov 01, 2011 | Sansui HDLCD1908 19 in. LCD TV
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
I want to connect my dell inspiron 1525 to my lcd hd ready tv but have no idea how to? Does anyone have any advice?
The 1525has a a hdmi port which you can plug a hdmi cord into. This may not support the audio. the tv and pc should detect the new monitor automatically or you may have to toggle it by hitting F4 key.
Apr 22, 2011 | Dell Computers & Internet
How do I hook up my hp computer to my lg flat screen tv
You can use the TV's VGA port which needs a VGA cable which you can get from a computer hardware store. It's called RGB in on your TV. This is also called PC input.The max resolution you will get is 1,366x768 off your PC.
Jan 25, 2011 | LG 32LG30 32 in. LCD HDTV
Monitor gets signal from computer but doesn't display. Monitor will display message that says no signal when unhooked from computer but will not display menu
Sound like it could be corrupted video driver. I would try holding down the F2 key to reach the system bios. Select vga for the video display if in the bios...then save and restart. If you can't get to the bios screen, try F8 and see if you can get safe mode...if so...it should allow pc to use the vga driver and thus hopefully display will work. If you get in and see windows, then you most likely ned to remove the display driver and reinstall it.
If still not working, try hooking monitor to another video port. Might need to get a conversion adapter to fit to vga port, or dvi port or whatever else you might see.
Jul 06, 2010 | Hannspree HANNS.G HX191D 19" LCD Monitor
I have a tv screen which i use for my computer.I have the hdmi cords going from the video card on the back to my tv.why is it not working
Make sure your t.v. screen supports your display card resolution. Try lowering your display card resolution in display settings. Make sure your t.v. is set to AVI.
Best wishes,
Graemevm
Nov 13, 2009 | Acer Aspire T160 (AST160UA3400) PC Desktop
Why won't my tv display my computer screen
Hi. The best way to hook your computers display to your LCD screen will be to use the VGA input socket. If your video card can support both S-video input and VGA, you can use either one but, the VGA is best for optimal resolution. This is the easy way to do this. Step one, connect the VGA cable to the computers video card and then, run the other end of this same cable to the VGA input slot on the LCD screen.Step 2, next you will make sure that the LCD's input selection is selected to show what is being transferred from the CPU video card by using the input button on the lcd remote control. The lcd(your tv) should be on VGA or PC input signal. Step 3, now, you Will have to also make sure that your video card is set to transfer this signal as well by pulling up your video cards software window and switch to the proper options. once this is done, you should get a signal. Be sure to use the VGA input/output ports on both the lcd television and your cpu for optimal transfer of the video stream. Here is a pic of your back panel. use the input port labeled I for good PC input quality.
Mar 24, 2009 | Proscan 32LB30QD 32 in. LCD TV
Trying to hook compaq presario laptop to philips lcd digital tv
hey fox,
sounds to me like a connection problem. If the compaqs output is vga, you need to convert the input (tv side ) to hdmi, component, s-vidio... what ever you can find. Typically when you hook up your computer to a flat screen or such, its best to try to use the hdmi ports or the rpg. But if thats not available you need to take the outout from your laptop ( whatever type that might be and input it into your flat screen tv. If you input laptop into tv under ( eg..HDMI) then when you VIEW it you need to select the correct source on your flat screen. Such as hdmi or pcmi or rpg.I know that the do sell alot of cables that adapt from one type of connection to another. Typically only one cable is required from the laptop to the flat screen. If you think about it you are only using the flat screen as a monitor.
Feb 14, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Want to connect my Sony vaio VGN-A250 to Sharp 19'' LCD TV
Your laptop will have a VGA output or possibly a S-video out. For the VGA you'll need a standard VGA cable. Plug the cable in to your laptop and the PC input of your TV. If your TV does not have PC input it may have a DVI input. IF it does you can use a VGA/DVI adapter to plug it in. If it doesn't have a DVI input you can use the S-Video output on your laptop with a standard S-video cable. After the connection to your TV is made you will have to toggle alternate display by pressing and holding your [Fn] key and pressing F4, or F5, or another F# key. It's the one that looks like a TV screen. Press once to turn on output, press again to turn off your laptop screen, press again to go back to laptop screen only
Feb 10, 2009 | Sony VAIO A250 Notebook
19'' Dynex TV does not come up as a Computer Monitor.
Follow these steps on the remote :
Press Input,
scroll down and select VGA.
Nov 17, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Toshiba Satellite L305D-S5895 Notebook Logo
131 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
