Question about Water Heaters
Whirlpool hot water heater serial#0426117756 also know as american hot water heater The pilot light won't stay lit. Please help. I have been without hotwater for two days.
    Champion:
  • 363 Answers
Sounds like you need to replace the thermal coupling. This component sends a signal to the gas valve that there is a pilot
Posted on Jul 30, 2009
Does the pilot light always stay lit on this water
Many water heaters today are pilotless.
Call manufacturer with model and serial number
Gene.
Sep 04, 2013 | RTO W4 A.O Smith Gas Hot Water Heater...
My water heater pilot light will not stay lit
1) Copy following link for troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Clean air intake located on bottom of heater of American, State, Craftmaster, Reliance, Whirlpool, Kenmore
http://waterheatertimer.org/images/Flame-trap-inspection.jpg
3) Gas control valve thermostat might be bad.
Dec 06, 2012 | Whirlpool Water Heaters
Whirpool water heater unable to lit
Whirlpool water heaters are made by American-AOSmith.
Approximate age of water heater is unknown, and type of gas control valve is unknown.
Clean air intake located bottom of heater, using a feather duster.
Get more fresh air to the water heater and see if that solves problem.
http://waterheatertimer.org/images/State-select-air-intake-400.jpg
If you have piezo igniter, then check if it is putting off spark.
If there is no gas at the pilot, then gas control valve is probably bad.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
If pilot will light but not stay lit, then change thermocouple.
Watch videos on utube to lean how to replace thermocouple.
For pilot light problems: Read information on following link:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pilot
Jul 27, 2012 | Water Heaters
The pilot won't stay lit on gas hot water tank.
Make sure thermocouple tip is seated inside the burner flame.
Make sure thermocouple is not overtightened. Finger-tight + 1/4 turn.
If the pilot lights, then ECO energy cut off is not tripped, but gas control valve might be bad.
Check color of pilot flame: it should be strong and clear blue.
If pilot flame is weak, or color of flame is yellow-orange: Clean pilot orifice and burner and combustion parts on yearly basis.
Clean air intake screen if applicable.
Increase air supply to water heater. Open a window and see what happens.
Check for adequate draft going up chimney using match under vent hood to see if smoke drafts immediately upwards.
Bleed air out of gas line.
Check gas pressure.
Open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Pilot-outage-troubleshooting.pdf
http://waterheatertimer.org/pdf/Vent-spillage-test-atmospheric-gas-water-heater.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 21, 2011 | Water Heaters
Lowe's hot water heater pilot light will not stay
If it is one of the new ones with the fancy gas control and the blinking light... does the light blink?? or not??
If it is blinking then the pilot should stay lit...
If it will not blink then the sensor is bad or not in the right place...
Or... the gas control is bad... this is happening alot...
If it is brand new... take it back...
heatman101
Sep 05, 2011 | Whirlpool Water Heaters
Pilot light won't stay lit on new water heater
1) Get more air to the water heater and see if problem continues.
2) Read the following pdf-s for things that might apply to your situation.
http://waterheatertimer.org/images/Negative-pressure.jpg
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
3) Read pdfs above first, and then Add a comment with missing information below, for possible do-it-yourself help.
Does this water heater have a blower?
Is gas valve electronic? Or does gas valve have a dial?
If gas valve is electronic, have you checked outlet with circuit analyzer?
Did pilot light work correctly for a while? If so how long?
Where is water heater located? Hot attic? Closet? Garage? Is area dirty and dusty? Has air intake been cleaned?
What color is pilot flame? Clear blue or yellow-or-orange?
Have you inspected inside of combustion chamber for dripping water?
Aug 28, 2011 | American Standard 40 G Natural Gas Water...
I have an old whirlpool gas water heater and the pilot will not stay lit.
Suspects include bad thermocouple, thermocouple slipped down and not in pilot flame, dirty combustion parts and pilot tube, dirty air intake, backdraft caused by other vent fans pulling air down water heater vent, water dripping down vent because of poor venting, air in gas line, low gas pressure, bad gas control valve, hot attic environment, tight house not allowing enough air:
Replace thermocouple:
http://www.youtube.com/watch?v=v0aBPsNg6vo
http://www.youtube.com/watch?v=xGQngzqrIEE&NR=1
Troubleshoot pilot:
Clean combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Aug 24, 2011 | Water Heaters
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
Aug 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot light will not stay lit.
More than likely the thermal couple is defective. The thermal couple is a safety device that shuts the gas off if the pilot goes out. If it is defective the pilot light will not stay lit. The thermal couple is the device that the small copper line goes to. It is mounted beside the pilot flame and the flame much touch the TC for it to work. If the flame is not touching the TC bend it until it is in the flame. If it is touching the TC then replace it.
Jul 28, 2011 | Whirlpool Water Heaters
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
Water Heaters Logo
112 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
