Question about Sony VAIO VGN-S170 PC Notebook
Gabriel175: Laptop now boots and video heatsink/fan now running but screen is "garbled" with horizonal lines. Will attempt re-connecting the screen cable.
  • aaronfoltz82 Jul 30, 2009
    I tried this and the external image looks normal, but I have one other issue.
    When booting a warning pop up comes on telling me "the ATI Control Panel failed to start because no ATI driver is installed or ATI driver is not working properly"
    This happened on my last laptop mobo when the ATI 9700 chip burnt out or didn't work. I would only be able to use VGA mode instead of the full resolution.
    I wish I had another mobo and screen to test out.
    From reading info on the laptop I found there is another intel chip that stores USB info and external/internal vga settings.
  • Sony Master
  • 32,281 Answers
To determine if the LCD is faulty or the video card, connect an external monitor to the video port on the laptop, power up the external monitor first then the laptop. The video data will divert to the external monitor automatically and if you get a normal Windows image the the video card is OK and the fault is the LCD screen or video cable.
Posted on Jul 30, 2009
My acer asipre 4739z laptop starting after a few minutes not work. fan is running battery is ok
Please describe a list of events that takes place from the time the ON button is pressed until the screen goes OFF. Attach an external monitor and press the Function key with the screen key to transfer video. If monitor responds the video is OK but screen is BAD. Then replace Screen. If Monitor does not show video then problem is probably a thermo problem. To correct video chip overheating do the following; First ... Remove Battery. Remove CPU and Video Heatsink and Fan. Clean dust and lint that is blocking airflow in heat transfer grill. Clean dust from inside fan. Clean old heatsink grease from Heatsink and from Video chip and CPU. Apply fresh High Quality Heatsink grease evenly but sparingly to chips. Replace Heatsink following tightening order to spring screws at CPU. Replace covers ... and start.
Aug 30, 2013 | Acer 6-cell Battery For Aspire 4739z,...
Cq71 white line screen
Have you tried connecting to a External Monitor? Does the problem show on the External Monitor? Has the Computer been overheating? Any damage? It may be the Graphics Adapter? Has the Laptop been cleaned? Fan, vents, heatsink? Have you tried booting to Safe Mode? Any Change? Have you done ANY software updates?
May 26, 2013 | Compaq Presario CQ71 Series Laptop Charger...
W2Jb: No video on LCD; corrupted video on external monitor
Ahh, thanks for the clarification. This shounds like the video card has gone bad on the laptop. I believe this becasue you dont get any video at all through the laptop screen but you do on the CRT, indicating that it's not just a bad cable.
If it's an integrated video card (and it probably is) it would be more cost effective to buy a new laptop.
Apr 05, 2010 | ASUS W2Jb PC Notebook
Hp 6720s lap top running - vista does not load
If the laptop runs extremely hot, then CPU will shut down (thermal overload) and will not boot up again until it has cooled down.
Overheating problems is caused by faulty fan (stop spinning) or the fan and heatsink assembly is clogged with dust. Check the fan, it should spin freely and remove and vacuum the dust from the fan and heatsink.
Replace the fan if it is faulty.
Aug 03, 2009 | HP Compaq 6720s PC Notebook
Hello, I have a vgn-s170 laptop that I just installed a new screen and motherboard. the video chip heatsink/fan is not running and the screen does not come on. what can i do
Have you tried connecting it to an external monitor? Are you sure the heatsink fan is not defective? If the screen works on an external monitor you know the video card is good. As long as the cable is plugged into the motherboard to provide power for the heatsink then it's either a bad heatsink fan or the motherboard connector for the heatsink is bad. My money is on the heatsink fan if you can get video from an external monitor.
Jul 30, 2009 | Sony VAIO VGN-S170 PC Notebook
IBM A31 2652 Video garbled video at boot
This is very possibly a hardware problem, namely a crack in the motherboard. Sorry, no easy or cheap fix for it if that's the case.
Feb 18, 2009 | IBM ThinkPad T42 Notebook
update monitor driver
your screen may be going
how old is the system
Jan 26, 2009 | IBM ThinkPad A31 Notebook
IBM Laptop A31 2652 Garbled video even at initial boot screen
Connect an external monitor to the laptop, power up the monitor first and then bootup the laptop. The Windows image will automatically divert to the external monitor.
If the images is OK then the video card is OK.
From the description of the fault, it indicates that the fault could be a faulty video cable or video connector. Try reseating the video cable/connector on the motherboard.
Get back to me if you still have problems together with any error messages etc.
Jan 25, 2009 | HP Compaq Presario F750US
BSoD, Garbled Screen, Boot Failure.
If you are getting garbage on the screen before windows tries to load the laptop probably has a bad motherboard.
It's possibly only the video output is going bad on it, try hooking it to an external monitor and see if you get the same weird stuff on that screen.
Good luck, let me know how it goes
Nov 15, 2007 | Compaq Presario X1000 Notebook
Sony VAIO VGN-S170 PC Notebook Logo
122 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
