Question about Remote Controls
Brand new samsung 52 inch lcd and the remote will not control the direct tv
I have a samsung tv and a samsung home theater system and the remote that came with the new tv will work everything but the direct tv. Is there any codes out there that I could try and if they do not work is there one remote I can buy to use to make them all work.
  • 6 Answers
SOURCE: Remote code for Sony Home Theater
Try 0035, 0032, 0000, 0636 and 1232
If that does not work try searching for codes:
1. Turn on your TV.
2. On the remote control, press TV
once. Then press and hold Setup
until the TV key blinks twice, then
release Setup.
3. Enter 9 - 9 - 1. The TV key will
blink twice.
4. Aim the remote control at the the
TV and slowly alternate between
pressing Power and TV.
Stop when the TV turns off. A
working code has been found.
NOTE: In the search mode, the
remote control will send IR codes
from its library to the selected device,
starting with the most popular code
5. Press Setup once to lock in the
code.The TV key will blink twice.
6. To search for the codes of another
device, repeat steps 1 to 5, but
substitute the AUX key for the auxiliary
device you are searching for.
Posted on Oct 29, 2007
  • 52 Answers
Here's a link to the user manual for the remote. There's a section with codes for programming your devices.. Also, it says, if code isn't listed, there is a "code search" function on the remote..
Posted on Mar 19, 2008
SOURCE: Program Comcast remote to operate Samsung 46"LCD
The answer depends whether its a Comcast DVR Remote or a regular one. The DVR codes are 4 digit -- the others are 5 digit. I got 0060 to work for my DVR remote.
Posted on Jun 02, 2008
SOURCE: comcast remote and need code for a samsung ht-tq85 home theater
Posted on Aug 02, 2008
SOURCE: Need vizio code for Samsung remote!!
I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
Posted on Dec 29, 2008
SOURCE: Broksonic TV code for RcA RCU704 remote control
I had a similar problem with a 1994 vintage Broksonic TV. I called the company (Hatzlachh Supply Inc. @ 800-333-9099). Broksonic TVs are not compatable with any universal remotes! You need an original factory remote. Remote for my set cost $20.00 plus shipping for a total of $24.95.
James Benson
Posted on May 27, 2009
0 characters
1 Points
Need code and directions to program a samsung flatscreen
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Dec 18, 2015 | Samsung Remote Controls
I want to set my samsung home teather remote to my vizio tv the remote is a ah59-02291a
Need the model number of the samsung Home home theatre system to give to correct code.
Aug 13, 2011 | Remote Controls
My remote for the samsung htc550 home theater system does not switch back to the set top after I have switched it to my tv. I no longer have a working remote for it and do not know how to switch it back....
Press the BD Receiver / TV button twice in quick succession. The light should now be orange which indicates it will operate the Home Cinema system....Pressing it twice again in quick succession will turn the light green indicating it will operate the TV.....Unfortunately the useless operator manual with the system does not tell you this....
Apr 29, 2010 | Samsung TV Remote Control
Need Program Code
Samsung Codes 013-015-053-055-033-112
Mar 24, 2010 | One For All URC-8910 LCD Remote Control
Logitech 1000 universial home theater remote turns
Ensure that you do not have the power command added as an additional command in the Activity, and decrease the repeat setting for your TV. The followinf link will tell you how to decrease the repeats.
Nov 14, 2009 | Logitech Harmony 1000 LCD Touchscreen...
Direct TV remote quits working - conflict with Samsung LCD?
Turned power saving feature on the TV to low and moved the receiver about four feet away from the TV and the remotes work fine now.
Sep 03, 2009 | Samsung TV Remote Control
Samsung 52....TV will not turn off
Call who you bought the TV and remote from and get it replaced with there warranty. No reason to put yourself through a headache when you are covered under warranty.
Feb 22, 2009 | Samsung Remote Control
How to select the correct device in drop-down box when programing
Sony Home Theater System - 'Mini System' Samsung Blue-Ray DVD Player - 'DVD' VCR Orion - 'VCR'
No matter what you enter the devices as, the software will determine what it actually is and set the type.
Hope that helps.
Jan 13, 2009 | Logitech Harmony 520 LCD Remote Control
Direct tv remote control - tv volume
PaulTulsa is actually incorrect, Directv remotes do allow this function. I had this problem too... but was able to fix it. You have to go back into the system settings menu. Depending on your receiver (I have the hr21-100) press "Menu" then scroll to "Parental, Fav's & Setup" then "Sytem Setup" then "Remote" then select "Program Remote". Scroll to "TV" then select the brand name (I also have a Samsun tv). Follow the directions to change the code of the remote and manually go through the codes they have posted. The second one worked for me. Good luck.
Feb 17, 2008 | Universal Remote Control DIRECTV Universal...
Lg remote codes
Programming u-verse remote for LG4270 (LCD 42inch) worked fine with code 1346.
This is a "Plasma" code according to U-Verse technical support, but was suggested with perfect result.
Jan 05, 2008 | Directed 434MHZ Remote Control
Remote Controls Logo
174 people viewed this question
Top Remote Controls Experts
Are you a Remote Control Expert? Answer questions, earn points and help others
