Question about Nokia E51 Cellular Phone
New adapter tried
The new adapter doesnt work either....problem still there..
    Problem Solver:
  • 7 Answers
May be their is a loose connection into your adapter. . . It is much better to open it and to recconect the loose connection.
Posted on Jul 30, 2009
KERNAL_SECURITY_CHECK_FAILURE
Possibly a bad battery or power adaptor. Try running with the battery out of the laptop. If that doesnt work try a new power adaptor. If after all that, it still doesnt work, it may be your mobo(motherboard). A power surge can easily destroy a mobo.
Feb 06, 2014 | ASUS Computers & Internet
My laptop touchpad doesnt work properly when i charge my laptop.
If your new adapter is not compatible with your Acer Aspire in voltage and current, your laptop maybe can't work well. Check your new adapter and ensure if it is the same with the original adapter.
Apr 17, 2010 | Dell F3534 Touchpad
My usb adapter light does not work and can not get connection to internet have tired putting the adapter on main computer and also no light or response could the usb adapter be burned out? and when I plug...
If you have tried in 2 computers and if it is not working.
try with latest software
and if that doesnt work go for a replacement if it is under warranty
else go for new USB adapter.
If ur issue will resolve please rate this,.
Regards
TecKC
Dec 27, 2009 | NetGear RangeMax WPN824 Router
Works on small bottles \low flow on 5lb tank with adapter hose
t urn tank off disconnect from grill make sure knb is in off position reconnect make sure fitting is all the way on tank reconnect and try again if this doesnt work you may need new hose weber has had problems with thier hoses call them and order new one or call bbq galore and ask for 4ft adapter hose 214 696 0030
Aug 17, 2009 | Weber Q Grill
Toshiba Laptop Wont Boot.
yes,if the battery doesn't charge with the ac adapter or turn on with it pluged in.it is common on comuters for the power adapter on the motherboard to go bad after a while.downfall of the laptop is that it is very hard to replace it(desktop easy because it is not built into the motherboard)you can either buy a new motherboard or a new laptop.if you got any more questions feel free to email me at gamecrazy944@yahoo.com
Aug 03, 2009 | Computers & Internet
Wusb100 has poor signal and is new
U r facing the same issue which my bro was facing ,
Well the problem then is not from ur adapter its from ur router ...
Just increase the channel width and the channel on ur router ...
if it still doesnt work uninstall te adapter and install its once again ...
Thank u ...
Jul 09, 2009 | Linksys WUSB100 Wireless Adapter
My dell vostro 1000 laptop's display aint working. The screen remains black. Even the battery light doesnt glows. Only the power light comes on. Please help.
hi,
try these two things if both don't work you should call dell tech support
1) take out the battery and the ac adapter and then push and hold down the power button for 15 seconds, this releases flea power in the laptop and makes it work sometimes
if it didn't work
2) take out the battery and put in the AC adapter and try to start your laptop on AC adapter alone, if it starts that means either your battery or *********** board is bad, you can check if the battery is bad by replacing it with a new battery and if it works with new battery that means the old battery was bad but if it only works without battery with ac adapter and new battery also didn't work, that means motherboard is bad, Call dell tech support
If you think the info given by me was helpfull please do rate me
Regards
Ltoso
Jul 07, 2009 | Computers & Internet
I have a Dell and net adapters doesnt work
Uninstall and reinstall LAN drivers and Broadcom drivers.
Press Windows key and R key simultaneously to open Run Window.
Type "devmgmt.msc" and click on OK.
This will open Device Manager.
Click on "+" sign next to Network Adapters and right click on the network adapter and select Uninstall.
After uninstalling right click on Network Adapters and select scan for hardware changes.
This will reinstall the drivers.
Sometimes windows prompts you to restart the computer to reinstall the drivers automatically.
You can even reinstall the new LAN and Broadcom drivers from your Dell website provided they have new version of these drivers.
After reinstalling the drivers, check if the adapters work.
If the adapters still don't work, the issue could be with the hardware.
You may even try with recovering your PC using Dell Factory Recovery.
Before performing Recovery, take the backup of your hard disk as the Recovery process will restore your notebook completely to factory settings.
Jun 15, 2009 | Dell Latitude D600 Notebook
My inspiron1521 ac adapter is not recognize
You probably need a new AC adapter. The best option is to find someone else with the same laptop adapter and try theirs. If it works then you know you need a new adapter. You can try and go to a store and purchase a generic one for you laptop if you do not have someone to swap with and take it back if it does not work. If it is still under warranty then Dell will send you a new one.
Jun 14, 2009 | Dell Inspiron 1521 Notebook
I cannot get power from 12 adapter - 2007 Camry
Try rotating the device end of the plug(part in the socket), sometimes it doesnt connect the two links inside.
Also it could just have a short in it. even though the car is fairly new.
Try another device, and check to see if it's not the device chargers itself. Try to use your cigarrette adapter. If that doesnt work than you have a short in the wiring. IT is easily and cost freindly to replace.
Good luck.
Feb 16, 2009 | 2007 Toyota Camry
Nokia E51 Cellular Phone Logo
22 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
